Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Dishwasher isn't draining
I have a kenmore ultra and it will not drain after the wash cycle!! Help?
  • weberangie29 Nov 29, 2008
    dishwasher not draining
IS THERE A QUICK FIX FOR THE SLOW DRAIN ? IT DRAINS BUT TAKES A WHILE 1 HR ,I PURCHASED IT USED AND I NOTICED THAT THE LIQUID SOAP SPILLED OUT AND NOT SURE IF IT COULD CAUSE THE DRAIN TO STICK ? ALSO WHERE IS IT LOCATED ? IS IT EASY TO REMOVE? THANKS RICH
Posted on Oct 26, 2008
reg501
  • 413 Answers
SOURCE: Kenmore Ultra Wash Dishwasher does not drain
Some Kenmore DW have a check valve attached to the sump that may have a blockage. Remove toe panel, look for a long, white, plastic fitting attached the front, right side of the sump. Remove the drain hose from the valve. Unscrew the valve from the sump and inspect for debris inside the valve.
Posted on Jun 14, 2008
rickzilla
  • 706 Answers
SOURCE: Kenmore Ultra Wash III Dishwasher will not drain properly
From the sound of things, your dishwasher drains faster than your sink drain ( via the garbage disposal) can drain it off.. You may have a problem with the way your sink drain/trap is vented and there is too much back pressure to drain down quickly.. When you run water from your sink, does it take a long time to drain down or if you fill your sink up and drain it, does it drain slowly ? That may be your problem.. Hope that helps.
Posted on Aug 26, 2008
leroyal
  • 2120 Answers
Fixerfailure, is the knock-out plug still inside if the garbage disposal inlet?
Stick a screwdriver in there to make sure.
spazmo1969, could be the rubber flapper is broken off in the pump discharge outlet.
Posted on Jan 06, 2009
rylee_smith
  • 8619 Answers
SOURCE: kenmore ultra wash dishwasher model 15752000 is
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Oct 22, 2009
Testimonial: "i appreciate your response to my problem. I will check the items you mentioned."
  • 127 Answers
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Posted on Oct 25, 2009
Water is not competed drained out after all wash rinse and dry cycles are complete. No signs of any leakage on floor or under machine.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Mar 20, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
My Kenmore Ultra Wash Dishwasher Model#665.13842K600 doesn't fully drain a the end of the cycle. There is always dirty water left in the bottom of the unit.
Dishwasher Problems - Water will not drain out
heatman101
Oct 02, 2010 | Dishwashers
My kenmore ultra wash plus is not draining
Hi
Thanks
Rylee
Nov 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore ultra wash dishwasher model 15752000 is not draining completely after cycle has finished
Hi
Thanks
Rylee
Oct 21, 2009 | Kenmore Dishwashers
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher, water not going through the jets
when you hear the motor running during the wash cycle, check to see if the washer is actually draining instead of washing. this would indicate a stuck open drain valve. (the same motor/pump that washes the dishes, also drains the unit)
Feb 07, 2009 | Kenmore Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
119 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
