Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
TV RCA Hi u posted about the 52 in. you actually fixed and UHHH that is where I am no tv at all but it does blink 3 times but that is as far as I get... any suggestions?
  • 3 Answers
Im not going to tell you its an easy fix TL. U have to be able to solder and have the guts to do it yourself. You ever had any experience with electronics? email direct at: timcole258@gmail.com or give a call 770-328-3404. Im in GA so bear in mind Im on Eastern TIme Zone. Ihave a class on Sat morning so leave vmail if you call. -Tim
Posted on Oct 25, 2008
52" rca hdtv monitor power flashes 3 times after pushing it and tv does not turn on.
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. 3 blinks occur if any of them is puffed up on top. To resolve this issue you'll have to replace all the 3 capacitors CP150 2200UF 16, other 2 are 220UF 35v they will be green with gold writing on them. Also re solder all pins on Fly Back Transformer (FBT). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 10, 2010 | RCA R52WM24 52" HDTV Projection Television
I have a RCA D52W17 rear projection T.V. When I turned the power on the green light flashed 3 times then shut off and now it won't go on at all.
Hi
Thanks for using FixYa. 3 blinks in your RCA D52W17 rear projection are caused due to 3 capacitors (CP114, 120 and 150) which are located on the deflection board. If any of these capacitors goes bad you’ll have to replace them with the exact same ones. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | RCA D52W19 52" Rear Projection Television
Rca 52 3 years old will not come on blinks a code 12
Where you are posted it shows a 12yr old TV if thats so replace high voltage Block
Dec 12, 2009 | RCA P52926 52" Rear Projection Television
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Thomson tv projection "52" light blinking.
It apears you have a low voltage problem. This is not an in home repair and may be time to consider purchase of new model. Hope this helps good luck
Jul 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 in tv
ON Deflection board there is 3 capacitors that most of the time will cause set not to startup cp150-cp114-cp120. values 2200uf 16v, two 220uf 35v, you buy caps at Radio Shack.
Dec 28, 2008 | RCA D52W19 52" Rear Projection Television
52 inch rca rear projection tv wont turn on
I have the same problem. I had someone come look at it and he showed me the problem but a terrible price, so i didnt have it fixed. The reason the light blinks is there is a problem and the safety mech is kicked in which shuts the TV off. If you take the back of the TV off, about 15 screws, you will see right in the front on the left side a part shaped like the letter "C". The number on top of mine is S5 19 2. That is the part that needs to be replaced. Now to find the part on the internet and figure out how to change it out. any suggestions?
Oct 29, 2008 | RCA D52W19 52" Rear Projection Television
52 in rca tv
does the light blink 3 times when you press power? Let me know exactly what happens when you press the power button. Please respond to this same post when replying.
Aug 07, 2008 | RCA D52W19 52" Rear Projection Television
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
