Question about Grilling
Where can I buy a burner plate for Wonderfire 2610 (LP) gas heater?
I need to replace the burner plate (is this the Matrix Burner 5083?) for a Wonderfire 2610 gas heater (propane). I have the Lytherm gasket material, but I need a new burner plate.
  • 32 Answers
SOURCE: jenn air 32 in. 4 burner gas grill
HAVE YOU TRIED THE ORIIGONAL TANK? SOME COMPANIES HAVE SPECIFIC TOLERANCES FOR FITTINGS THAT MAY NOT WORK W/ OTHER ITEMS.
Posted on Apr 08, 2008
  • 10865 Answers
SOURCE: Side burner on propane gas grill burns with orange
here is a link to a page that shows what the colors of the flame should look like and what causes the orange instead of the blue flame. http://www.appliance411.com/faq/gas_range_flames.shtml
I would begin by checking to be sure you do not have a spider or a cob web in the burner partially blocking the gas or the air intake.
Posted on May 12, 2009
SOURCE: Need a Manual & Parts List - BBQ Galore Turbo STS 4 Burner (LP)
I have the manual you are looking for.
Send me your email address and I will send it to you.
rayh2o@yahoo.com
Posted on May 25, 2009
SOURCE: 1st burner goes out when 2nd burner is turned on
I had the same problem. They original regulator and hose were poorly designed for this model. There isn't enough room underneath without crimping the hose. I bought a standard regulator and shorter hose combination a Home Depot for about $20. It makes a 90 degree turn coming out of the tank and does not kink the hose.
It was worth the $20.
Posted on Jun 03, 2009
  • 9 Answers
SOURCE: I need to know how to remove the stainless steel burners and replace them.
Call Weber to receive free warrenty burners. Have model and serial number found inside one of the doors on your grill. I just received them in the mail about a week ago and just replaced my burners today. Here is what I did.
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Posted on Jun 26, 2009
Burner comes on at 3.any lower goes out.6 inch yellow flamestarts on rite side under pressure.not burner rite of burner
Troubleshooting :: AZ Patio Heaters and Replacement Parts
azpatioheaters.com/pages.php?pageid=11
How do I replace starting striker switch on a tall patio heater? How do I clean ... Why is my burner flame low? Why does ... Why does my pilot light, but goes out when heateris turned on high or low? Why do I get a yellow flame and black smoke? ... 6. Can I convert my LP gas patio heater into a natural gas patio heater? NO.
Nov 17, 2015 | Heating & Cooling
I have a VC Wonderfire model 2610. The pilot flame is perfect blue on both sides... however, when I hit the switch for the main burner to come on...the pilot goes out... any ideas ???
You may have moved the safety sensor or pilot flame tip. The pilot light heats a wire. The wire is the safety sensor. The wire has to be clean and in the pilot flame near the flame tip.
Jan 10, 2015 | Heating & Cooling
How do I convert my rheem water heater from lp to natural gas model#21vp40-1p
Call Rheem
Generally the company does not support changing type of gas since propane burns much hotter and has more pressure than natural gas.
You need different gas control valve, and need cast iron burner and orifice than matches that specific gas control valve.
http://waterheatertimer.org/images/IMG_1826-LP-burner-450.jpg
http://waterheatertimer.org/Water-heater-manufacturers.html
Gene
Sep 14, 2014 | Water Heaters
Need gas control unit& burner for water heater 40 gallon
Reliance is AO Smith.
Each gas control has identifying information on side of gas control valve. Make sure you order for NG natural gas or LP propane gas, since these are two different gas control valves.
Google search the gas control number and results will show.
Copy following links for more help:
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Sep 03, 2012 | Reliance Water Heaters
Can i get parts to convert my capn cook 4 burner bbq grill to lp
The BBQ's Galore grills are the only ones that are approved to be field converted. All you need a 4 LP Gas Burner Orifices and a Hose Regulator Assembly to hook to a LP Gas grill tank. You can buy the orifices from BBQ's Galore and the Hose/Regulator Assembly from any hardware store or home improvement center that sells grills & accessories for about $30.00. Gas grill burner orifices are pretty universal, so any LP Gas ones should work.
Hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
We like to convirt LP Water Heater to Natural Gas Water Heater, PG & E told us to replace pilot burner orifice. My question is , 1- is it possiable to do that? 2- If it is What is the part number...
yasharer,
Yes it is possible to convert any gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner. I have a tip at http://www.fixya.com/support/r7207798-changing_gas_appliance_from_natural_gas which explains everything you will need to know to get the part and change it out.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 10, 2010 | Heating & Cooling
I need tips on installing a new burner plate and gasket on a Wonderfire 2610 gas heater
I have a Wonderfire gas stove and it's easy to replace the burner plate and gasket. Hardest thing is getting the bolts out. Use a vise grips and you won't strip them. I don't use any adhesive on the gasket just clean everything off and replace.
Oct 08, 2010 | Heating & Cooling
Need instructions and part # for lp conversion kit on MGR5765QDS
Your conversion jets are usually located beneath the hinge area or the back panel on that stove and are mounted on a plate which holds all of the LP jets in a row. there is no need to buy a conversion kit, since it is already supplied. The jets mount on the burner control itself as it enters the gas flow tube, and the oven jet mounts just before the large burner under the plate in your oven area. Just remove that large oven floor plate and you will see it.
Mar 23, 2010 | Maytag MGR5765QDS Stainless Steel Gas...
I have a natural gas heater and propane tank? How can I make it work?
You will need to change the burner orifces from Nat Gas to LP also may have to ajust the pilot
Dec 01, 2009 | Heating & Cooling
3 burner charmglow gas gril
I am replacing burners and I need to know if the burners if they go tightened or loose.
Oct 20, 2009 | Brinkmann Charmglow Stainless Steel LP...
Grilling Logo
266 people viewed this question
Top Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
