Question about ASUS (wifibralinkuay) 802.11b Wireless Adapter
My asus K601J laptop wireless card is going out. how do i replace it?
My wireless card will connect to my wireless network, but will sometimes loose the signal. I have to reset my laptop to get it to connect to my network.
  • ASUS Master
  • 32,281 Answers
Make sure the latestwireless card driver is installed in the computer.Locate the wireless routerhigher and away from concrete and brick walls, foil-insulated walls. Locate the wireless routeraway from cordless phones and microwave ovens these can cause interference.You could be gettinginterference from other wireless access points or wireless routers in yourarea. Check the wireless broadcast channels in your area, and select one thatis unused or one that has the weakest signal strength.
Posted on Feb 12, 2012
Why doesn't it connect to wifi?
if it was working fine and you have done nothing different then it could be the wireless card. you can buy them ( usually from ebay ) and install it yourself ( usually under a flap underneath the laptop ) other reasons are. if you can see the name of your broadband when you click bottom right wireless icon then you have not entered the correct code to connect ( they have to be in caps ) if you can not see the name of your broadband when you click on the wireless icon then your wireless function is turned off ( hold the blue FN button usually bottom left of keyboard then press the wireless key usually along the top of your keyboard to turn it on ) there will be a slight delay after you press "on" so press once and wait a few seconds to see if it starts scanning for networks. if wireless is on and you dont see your broadband router in the list of networks or there is no networks showing then you need to replace the wireless card inside .so to sum up,if you can see your router on the list of available networks the code is wrong that you entered,if you see no networks the wireless is either turned off or your card has gave up
Nov 29, 2015 | ASUS Computers & Internet
How do i alter sensitivity for ASUS K601J inbedded mouse
Go to start, control panel, mouse. Here you can change your mouse settings to whatever you want - be it sensitivity or left-hand/right hand mouse.
P.S. If you are in category view in control panel, switch over to classic so you can have direct access to mouse settings.
Feb 23, 2013 | ASUS Computers & Internet
Having problems connecting with wireless network with my Asus k73e bbr7 laptop
This pc nodel doesnt had a factory network device.you need to buy a network card or usb.
Jan 31, 2013 | ASUS Computers & Internet
To whom can help, The wireless is not working on my ASUS Eee PC 1000HA. It's working on every other laptop in my house so, it is turned on, it's just not working on my Eee PC 1000HA. Thank you, Dr.M.Seus
Right click the wireless icon in the lower right hand corner by your clock and click view available wireless networks. Then select configure advanced settings. Click on the wireless networks tab.
In the lower part of the screen select your wireless network and remove it. Reboot the laptop
Once back on, view available wireless networks again, double click yours and join it again. It may ask you for your password so make sure you have that handy.
Mar 01, 2011 | ASUS Eee PC 1000HA Notebook
My wireless internet isnt working on my ASUS laptop. The yellow exlamation mark is on the signal bar icons and when i go into the device manager the network adapters and tunneling pseudo-interface have the...
you will need the drivers updated or replace the network card. if the drivers from Asus do not repair the problem, then i suggest a new adapter. here is an inexpensive one from eBay.
http://cgi.ebay.com/Broadcom-54M-mini-pci-wireless-WIFI-laptop-network-card-/320521450172?pt=LH_DefaultDomain_0&hash=item4aa09132bc#ht_2166wt_978
i also recommend changing the antenna whenever you change the wireless network adapter.
http://cgi.ebay.com/WiFi-Antenna-laptop-wireless-mini-PCI-network-card-/220724436636?pt=LH_DefaultDomain_0&hash=item3364339e9c#ht_2091wt_862
since you did not list the model of the laptop this is my best guess at what you will need. if you can send the model number i could double check this application for you.
If you have any problems let me know and please leave positive feedback for me. Jethro
Feb 03, 2011 | ASUS Computers & Internet
Asus U52F laptop -- 1 week old, a few days ago the internal wifi network adapter started randomly shutting itself off here and there throughout the days. Occasionally it switches itself right back on, but...
Sounds like a faulty wireless card or the card is installed with the wrong version driver.The wireless card itself sounds to be bad and needs replacing
Jan 10, 2011 | ASUS U52F-BBL9 Laptop
My wireless switch is on but not working. It says
could be a bad switch or your adapter may be disabled in "network settings" check that first
Sep 28, 2009 | Sony VAIO PCG-K25 Notebook
Can't get wireless to connect
Depending on your OS, you could check the device mang. and if your 802.b wireless is not found, look for other flags or problems.
Turn off your wireless switch and remove and re-install your network system.
If after completed, you do not see the wireless install when loading, remove the wireless card and try again, removing from device mamg., re-booting and re-installing wireless card.
Sometimes the wireless card looses connection and needs to be physically removed, system re-booted and re-installed to work.
If that does not work, try exchanging the wireless card for another.
Removing the entire network from the system and re-booting is the best way. Shoot down after re-booting and re-install wireless card.
Restart unit, if it see's the wireless card, it will show loading network device. If it does not see the card, it will not load it.
Hope this helps
Jul 27, 2009 | ASUS Eee 4G Notebook
Can't find any network
Same **** here .... All I am finding all over the internet is people complaining about this card. WTF how Asus could make such a pice of **** ??? My card sometimes connects to the router sometimes doesn't and when it does the speed it terrible really. Did almost everything with it so far nothing helped. I wonder if I can take it back and ask for money back.
Mar 11, 2009 | ASUS WL-138G 802.11g/b (wl138g) Wireless...
Changed router settings and now unable to access the network and internet
Just reset the router (there should be a reset button somewhere on it) it will default to open system. Then go back in and select WEP with 64 or 128 bit security. Generate your KEY and next time it connects enter the KEY. You should be set to go!
Jul 28, 2008 | ASUS Computers & Internet
ASUS (wifibralinkuay) 802.11b Wireless Adapter Logo
103 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
