Why is there no picture on my monitor. there are no light showing that there is power
    Genius:
  • 1,212 Answers
Your power supply is likely kaput. If it is internal to the monitor- replacing the electrolytic caps on the power supply section may remedy it. If it is external- swap with another supply of similar or greater ratings and make sure the coaxial connector is both right size and polarity.
Posted on Feb 12, 2012
When I turn on computer,monitor doesn't show anything sometimes 1,2 hours , and then finally I can see descktop on computer...All that time,monitor is trying to show picture (I can see like blinki
This is a known symptom of a failure in the power supply board. Here is a link to a repair guide that shows how to dis-assemble and the unit and then what to look for and replace on the power supply board to bring the unit back to working condition.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is a picture of the power supply board that needs to repair.
I hope this helps, if so please rate my solution.
BuddyMc
Feb 22, 2012 | Samsung SyncMaster 940N Flat panel Monitor
When I came home today the blue monitor light was on, but there was no picture. When I moved the mouse to get the monitor up, the light went out. I've tried unplugging it and plugging it into...
Here is a link to a repair guide for the LG L196WTQ. It sounds like you have a power supply failure and the guide shows how to open the unit, check the power board and then what to replace if you do find bad capacitors.
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/
Problems like wavy or flickering picture, flashing power light, slow to display the picture or no power at all are all symptoms of a failed or failing power supply board.
BuddyMc
Jul 25, 2011 | LG L196WTQ Monitor
Screen trys to show desktop, but quickly fades to
Since the power led button is on, the problem with your monitor is the that the picture board of your monitor has develop fault, that is why it tries to show your desktop and quickly fades away.
The picture board of your monitor is bad and will need to be replaced in other for it to display.
The best thing for you to do is to take your monitor to a local repairer or any service center within your vicinity to help with the replacement of your picture board because the fault is not something you can fix on your own in other not to complicate issues.
Take care.
May 04, 2010 | ViewSonic VX924 19" LCD Monitor
Monitor shows no picture. out of ideas, sos
1.check out the monitor led light is glowing,, if it does'nt ur monitor have power problem or fuse blownout,
2. remove the data cable (from monitor to pc) and switch on the monitor if it is on problem with ur motherboard else contact me i'll give u other soltion prajwal_yes@yahoo.com
Mar 04, 2010 | Computers & Internet
My Acer Al1715 monitor does not display a picture the power is fine as the green light flashes but no picture at all
The light should come on steady. Your monitor most likely has the typical failed capacitor problem. The Power Supply board in the monitor most likely has some capacitors that have failed, visible signs include swelling of the ends of the parts, but they can fail without showing any visible sgns. Replacement of the capacitors often restores operation.
Feb 02, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
LG L196WTQ monitor just quit working. won't turn
Look in the power supply section first for bad caps, post back what you find inside, pictures will help a lot to guide you through, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 24, 2010 | LG L196WTQ Monitor
No picture on monitor - green power light blinking
There's an internal electronic part/s of your monitor that is cold soldered / defective. I suggest to bring the unit to an authorized service center to properly diagnose & fix the problem. regards
May 28, 2009 | NEC MultiSync 75 17 in.CRT Conventional...
Power of the Monitor keeps going out.
You need to look inside your pc and check and see if the video card is plugged in tight. Sometimes if it is loose, and it isnt connected, and causes the monitor to not show any picture, but still has power.
Jan 16, 2009 | Sony SDM-HS95 19" LCD Monitor
Viewsonic E53 monitor
Base on the information given to me.
I think your computer is on sleeping mode.
first thing check if the video cable is not loose connecting the pc.
because what would happend, if it is loos it would turn on and off at times.
The other thing you can do.
right click on the desktop.
go to properties
go to screen saver
click on power
adjust the time you want your monitor to shut off.
Dec 06, 2007 | ViewSonic G90fb 19" CRT Monitor
Blank Screen..Will not power off
The flash light test only works with lcd monitor as they have back lights. Double check the connections again, also, if you can borrow a monitor try it on your pc, it may be your graphics driver needs to be uninstalled and re-installed, but you will need a monitor to see.
Dec 13, 2006 | Proview PS 776 Monitor
Computers & Internet Logo
David Payne
David Payne
