Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips tv top corners and bottom going 3d
I have a tv with model # 60pp92 0217f or e10839 depending on which tag you are looking at. both the top corners and botom center are going 3d. Do you think this is convergence ics problem? If so or not could you give any repair advice? thank you, mike.
  • akjno11 Oct 24, 2008
  • Philips Master
  • 3,459 Answers
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and fiphilips tv top corners and bottom going 3d - bb0cf99.pngre...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Mar 25, 2010
HELLO , I have sound but no pitcher MODEL #51PW9303/17F
If the picture was somewhat 3d looking before with colors out of line etc--what you have is a convergence problem that has got worse.
Seen a number of sets with this problem--on this model only way to know is locate the two chips, get at them and unsolder all pins on each--if set then comes on (will look bad) you know both chips need to be replaced.
If this is beyond you set is old enough to just replace it--average shop cost for this is over 200 parts and labor.
Let me know if you have questions.
Jun 11, 2012 | Philips Televison & Video
I have a friend with a Philips 60PP9202 TV, and she describes her problem as: "The top/bottom corner of the picture is kinda waved and the color is blue/red (3D like)". Would anyone have an...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Philips 60PP9202 60" Rear Projection...
I have a 60in philips top and the bottom of the screen look like 3D without glass the middie look all rigth
This tv have a problems call convergence,it dead.The tv convergence board require 2 convergence ICS and some or all it resistors are dead.These parts must be change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 10, 2010 | Philips Magnavox 51MP392H Rear Projection...
1/2 picture doubled while other half is normal. Philips E10839
Its a convergence problem which is common. Goto www.TvRepairKits.com and get a kit for your model
Jun 03, 2010 | Philips Televison & Video
Covergence and still nothing
OK if the Fuses go so do the drive transistors, you will have to replace them, trace out to them, and replace, check them out, probably open circuit.
http://www.eserviceinfo.com/downloadsm/36783/Philips/Magnavox_8P5431C%20/%208P6044C101.html
Go there download the schematic, actually a service manual for your TV, it's in a zip, format and it is a PDF inside.
Apr 17, 2010 | Televison & Video
Wavy color lines on left bottom corner. letters somewhat blurry.
Projection TV2_bing.gif sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Feb 28, 2010 | Philips Magnavox 9P6034C 60" Rear...
I lost my picture I still have sound but no picture.
I have a Philips Magnavox Projection TV.
I had dish satelight install on my TV. It worked well for two days, then the picture started showing in a square box. I ffixed the convergence and it seemed okay. The next day I turned on the tv and it had sound, but no picture. When I press the status button, the picture would come on then go right back out. Now I don't have any sound or picture. Here is the model information:
Brand: Philips Magnavox
Model #: 9P6040 C104
Serial #: 51190366
Chassis # PTV843
Manufactured: Nov. 7, 2000 (3910K071H)
TV Receiver Listed: 347K E10839
Amps: 3.7
HZ: 60
V: 120
Can someone please, please help me!
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Fixed coolant now picture looks great but cornrs look 3d
You need to replace Both of your convergence ICs they are Big Black ICs will have Part number on them
STK392-150 Call Mats Electronics 1-800-628-1118
Nov 12, 2009 | Philips 46PP9302 46" Rear Projection...
My phillips 51'' floor model tv has yellow in the top and bottom corners of the screen as well as a white halo. How do i fix? Thanks
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Aug 01, 2009 | Philips Televison & Video
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Dec 30, 2008 | RCA HD52W59 HDTV Projection Television
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
