Question about Insignia 37" LCD Flat-Panel HDTV
Removing Insignia 37' TV from Stand
Can anyone tell me house to remove the Insignia 37" 1080 LCD HDTV from its stand
There are 7 screws on the back of the tv - should be a phillips, once you have taken all out pull the tv up. If you figure this out I would be willing to buy the stand off you. I removed mine since moving and thought I did not need and threw it away, now need a stand. Email me at co45lt@gmail.com if you are interested.
Thanks
Posted on Nov 02, 2008
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn Abenton716@aol.com
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
Sep 22, 2011 | Toshiba 37HL67 37 in. LCD HDTV
I need stand for my insignia tv 42inch.
Tries websites like Ebay.com,Amazon.com to buy a used or a new tv base stand.
Mar 14, 2011 | Insignia 42" LCD Flat-Panel HDTV
37LG30 TV. The swivel stand is very wobbly. How do I fix?
Remove the actual stand (4 bolts are hidden in a sunken down spot for them on the back of the tv.
Once the stand is out of the tv, look down to where the swivel joint is at, you should see 4 screws that are going towards the bottom of the stand, those will be the loose screws.
I just fixed mine.
Dec 12, 2010 | LG 37LG30 37 in. LCD HDTV
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
Note: Extreme care should always be used when removing
without tools.
sliding the pedestal stand away from the TV.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
I need an Insignia TV stand for a 42" LCD HDTV
Try the T.V. manufactures website, E-Bay or the store where you got the T.V. from.
Jul 15, 2009 | Insignia LCDTV26 26 in. Television
Removing television base
You will need a phillips head screwdriver. There are four screws on the back of the TV that go into two rather long "legs" that go a few inches into the bottom of the TV. Just remove those screws and lift the TV off the stand. If you have your owner manual it will show you exactly where the screws are located otherwise just look for the heads of phillips head screws.
Mar 20, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
LN37A550 FLAT SCREEN TV
To remove the base stand, place the TV face down on a smooth surface. Place a cloth underneath it to protect the screen. Remove the 4 phillip screws from the stand. The stand can now be removed. The set can with a cover plate you can use to cover the opening.
See page #86 in the User Manual.
Mar 15, 2009 | Samsung LN37A530 37 in. LCD HDTV
Removing the stand on Insignia LCD 26F TV
My insignia 26 inch dvd combo TV stand can be removed by removing the access cover to your input connection. There are eleven black phillip-head screws. The three bottom screws also hold the plastic base cover in place. Remove all eleven screws and pull the stand out from below. The four philip-head screws on the back center of the TV is for the location of the wall bracket mount. Good luck.
Jan 26, 2009 | Insignia LCDTV26 26 in. Television
Blue ray wont play movies on new tv
Are you sure the tv is 1080p capable? Usually when "mode is not supported" is displayed, it means that the tv can not handle the signal format that is being input to it. If you are using HDMI, then signal formatting is usually handled automatically. If you are using component video, you will probably have to tell the PS3 to step down the signal to either 1080i or 720p.
Jan 10, 2009 | Insignia 37" LCD Flat-Panel HDTV
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
Insignia 37" LCD Flat-Panel HDTV Logo
186 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
