I need to change the filter in my Carrier Weathermaker 8000. WHERE IS THE DOOR?
    Scholar:
  • 121 Answers
There is a filter on the bottom of the unit. You will either have to remove the bottom panel in the front. Or thereis a thin acess panel down in the front of the unit.
Posted on Oct 24, 2008
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 58TUA doesn't work
The switch could be defective but more likely the furnace blower is failing.
Dec 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Carrier weathermaker 8000
The filter should slide out of a built in rack from the side of the furnace by the return inlet. It should have the size on it or you'll have to measure it. It may also be inside the bottom door. Pull the door up and out, the filter will be on one side or the other. Unless you have a special Hepa or electronic filtering system.
Dec 12, 2013 | Heating & Cooling
Carrier 8000 weathermaker 92000 btu
If it works with blower door off sounds like it's not getting enough return. What's the statics? Try an adjustable limit, I think they go to 210. Good Luck!!
Jun 13, 2017 | Carrier Heating & Cooling
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
NO HEAT???? freezing
go to the furnace, there should be a service switch on the outside of the unit.  make sure the door is on good, does the blower motor come on?
Nov 15, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 8000 weathermaker filter
The filter should be located in the front there should be some kind of tab to pull out the filter.
Oct 15, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
HEY< so this is an upflow system, there can be only 2 spots, 1 below the fan in a little rack, or follow the return air vent system ,(thats the sucking side,) and theres a large grill that sucks air in thats the filter grill, If you unlatch the door, and open it you can measure the inside lips that holds the filter, thus the filter grill! But it this filter is hard to fit, then theres only a plain grill and you need to add a filter inside the air handling unit below the fan cage,, and add a"blue MO-hair type filter , size to-cut and add below the fan!Thank-you-very-much!
Aug 30, 2008 | Heating & Cooling
Heating & Cooling Logo
650 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
