Question about Frigidaire ATF6000ES Front Load Washer
Just replaced the door strike and lock latch and washer does not start.
The door lock light comes on most of the time, but the machine still won't start. I checked all the obvious things -- water line, water in waste line, electricity, resetting. It has an error code E31 when I check the diagnostic panel. Also, if I push ******* the door after the lock light is on, it makes a buzzing sound (but still doesn't work). Any ideas how to fix this?
zeusfaber
  • 247 Answers
SOURCE: front load washer
Easy things first: Check the water hoses are all connected, the taps are on, and that the hoses aren't kinked. Everything after that involves poking around live terminals. If you aren't happy doing this, then don't be ashamed to call someone else in. Turn the power off. Remove the top panel from the machine. On the inside of the back panel near the top, you will find the fill valves (on a few machines, there is only the one). These are the items that the fill hoses you checked a minute ago plug into. Follow the hoses inside the machine from the soap dispenser back to the valves to identify which valve is the one which washes soap into the machine at the very start of the cycle. On the top of this valve are two terminals. Attach the leads of a multimeter to these, and select an ac volts range that will stand seeing mains voltage. (If you haven't got a multimeter, suggest you buy a cheap one from the local hardware shop - it will come in handy for all sorts of things once you have it). Turn the machine on and start a wash cycle. If the meter shows mains voltage across the terminals of the valve, and yet no water is flowing into the machine, you need to replace the valve. This is a cheap part to buy, and not difficult to do yourself. IF you don't find any volts across the valve, it's worth trying the other valves to make sure you haven't got the wrong one, but then it's beginning to look like a controller problem - at which point it's worth paying someone else to come in and look at it: Once expensive parts get involved, you either need to be sure you know what's broken, or be sure you can take unneeded, but briefly installed replacement parts back. Before removing your meter leads, don't forget to turn the power off. A.
Posted on Jun 30, 2007
localwonder
  • 6784 Answers
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
Posted on May 29, 2009
  • 4 Answers
SOURCE: Frigidaire washer starts to fill with water then stops
That is not the solution.
Start the machine and immediatly press the "Start" and "Pause/cancel" button at the same time. Then you will get and ERROR code. Look on the cheat sheet packed with the machine to find out what is really wrong. That will give you the real answer.
Appliancepartssuppliers.com
Posted on Dec 22, 2009
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
Posted on Sep 11, 2010
livewire874
  • 618 Answers
SOURCE: I have an ATF8000FS1 front
There is next to no adjustments so if the door dropped then the hinge must be bent . You may be able to very gently pull up on the door and re-align it but most likely you will have to replace the hinge.
Posted on Feb 26, 2011
My washing machine will not lock to wash i have replaced the locking mechanism assembly and the lock lid light just blinks and click near the computer board what els should i try please jelp
How to fix a washing machine door lock in a Hotpoint ...
? 4:21
https://www.youtube.com/watch?v=p14EEa4AYGM
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF In this video, ... How to fix a washing machine door lock in a Hotpoint washing machine ... How to open a washing machine door that won't open normally.
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock the lockand switch assembly might be defective. This is a very ... The Kenmore Elite HE3 is awashing machine by Kenmore. ... Preview my answer. Post my ...
washing machine wont work. the door will not lock to start ...
www.shopyourway.com > Manage My Life > Questions
Manage My Life. washing machine wont work. the door will not lock to start the cycle. all the lights still ... Kenmore HE3T front load washing machine will not start.
How to Fix Washer That Won't Start ' Washing Machine Repair
www.partselect.com/Repair/Washer/Will-Not-Start/
Read on to learn how easy it is to fix the washing machine yourself... ... found on front load washing machine is the door switch and the door lock and strike.
Jan 23, 2016 | Washing Machines
Front load washer, GLTF2940WH. Why won't it start and why won't the door lock?
Hello D, thanks for your inquiry!
From the information you have provided your Frigidaire washer, GLTF2940WH, will not start and the door will not lock. This could be a possible problem with your door strike, door latch, or control panel. I would suggest checking over your strike and latch to assure there is not physical damage. You could also perform a reset, just in case it is a communication issue, by disconnecting power from your washer for at least ten minutes. If that does not help resolve your issue I would suggest having a professional technician out to perform proper repairs. This will prevent you from purchasing multiple unnecessary parts. -Matt
Jun 04, 2015 | Frigidaire Washing Machines
My Frigidaire washer would not run. When pressed the start button, will immediately goes to Paused. The model #FAFS4474LA0. Thanks.
Thank you for your inquiry!
From what you are describing it sounds like a possible issue with your door latch assembly or control panel. If your latch is not catching the door strike or the strike is not sitting securely inside of the latch it could cause the washer to pause because it is not sensing that the door is locked.
It could also be a sensor within the control panel causing the issue and if that is the problem the control panel would need to be replaced. I recommend reaching out to a professional for further assistance to avoid any unnecessary part purchases. -Matt
Sep 25, 2014 | Frigidaire FAFS4474LA Washer
Whirlpool duet ghw9100lw lights on, not locked and still won't start
Just above where the washer door strike goes into the latch is a small round piece of plastic that activates a switch in the latch- is that still there? It will push in and come out as it is spring-loaded.
Oct 22, 2012 | Whirlpool Washing Machines
WFW9200SQ00 Whirlpool washing machine. Door strike doesn't go in the latch, seems a mechanical issue. There is a little white pin inside the latch on the way. Any ideas what can be wrong?
Does the door strike seem to be broken and is that what you see inside of the latch asm.? if no the strike is ok i suspect the latch itself has broken apart and your seeing a internal part of it through the opening where the strike fits into, in which case the latch/lock assambly would need to be replaced.
The part numbers are
DOOR LATCH ASM. 8183270
DOOR STRIKE W10217552
GENE
Oct 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The door wont lock, My 11month child can open anytime. even when it's full of water Please help Many thanks Matt
No nod # but all front load washers lock or should/// ether your door strike is broke or the door switch latch is not locking..sometimes the door strike can work but be wore so the latch won't grab it sence the door strike is cheaper I would try that first......If I helped you please vote if you need more help please ask..and good luck
Feb 05, 2011 | Washing Machines
Problem
That is a door lock error code...check the latch and door strike for any damage, also try unplugging washer wait awhile and plug back in. If still get the f/dl than its time to replace either the door latch assembly or the main computer that controls it. Hope this helps - the doc
May 26, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
46 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
