SOURCE: Globe commercial Meat slicer
I'm not familiar enough with globe slicers to be an accurate source of info. Sorry.
SOURCE: The blade on this berkel 827e bogs down to a stop
most times the belt fill slip if you overload it and no they don't have oil holes
SOURCE: Rival Meat Slicer Model 1037 Pin for blade
i too need a pin for this modle. has anyone solved this problem for that person?
SOURCE: BERKEL 825 THIS IS NOT
Did you hook up the wires to the right spot if you have them backwards it wont work message me back with the diagram that you have as well as the part if your positive you wired the switch correctly also sometimes when you order parts you can get a part in that is defective as well even though it is new you can also take the swith back out of the unit and perform a continuity test on the switch itself to check to make sure that it is not defective if you are unable to do these electrical tests with a multi meter i suggest you call a technician any further questions message me back Thanks Again
Rick
SOURCE: Can we use common mineral oil to lubercate a
Mineral oil is safe to use. You NEVER NEVER want to use any type of vegetable oil or pan spray. It will do more damage than good to your slicer. The good food machine oils are a just a high quality mineral oil.
