Question about Sewing Machines
I want fix circuit board of my bernina 1030
I realize that the problem is in the circuit board of the machine. The foot control doesn´t work because power don´t come on the motor enough and the foot control t's ok
    Novelist:
  • Sewing Machines Expert
  • 166 Answers
I have found that the bernina machines in this general product range (i.e. with the slide-in processor boards) do tend to suffer from dry-joints, randomly throughout the boards. If you take the double-stack boards out after removing the handwheel-end cover, separate the two boards, carefully and dont loose the plastic spacers on the securing screws. Best thiong is just to go through the board carefully with a magnifying glass, re-soldering any joints that show signs of having 'frozen' when manufactured. Also, carefully clean the two connectors that provide interconnection between the control board and main processor board with a suitable contact cleaner. I also make a point of removing any surplus flux that may still be on the board from manufacture, using the above cleaner. Most symptoms tend to be when the machine randomly swaps between stitches. The rotary controls are special and not commercially available, so if they get 'scratchy', unsolder them first and give them a good spray with contact cleaner to remove any surface contamination on the potentiometer surface. Icant help with a circuit diagram. By the way, if the motor isn't running properly, the problem is on the power supply 'L'-print on the back of the machine - not the main control board. There is an adjuster on the PSU that is used to set the motor speed. Make a note of its position and just try rotating it back-and-forth a few times, again to clean the track, then return it to approx where it was - this might cure the problem. Again, I dont have a circuit diagram of the 'L'-print.
Posted on Feb 14, 2012
  • 8 Answers
SOURCE: When i switch on my Bernina Artista 180 it blows
4 amp??? More likely 1.6 slow blow. The problem solution is changing the power supply, called a Classic L-print. Typical on the 130/180 Bernina.
Posted on Sep 06, 2009
Zenqi
  • 208 Answers
SOURCE: I have a Bernina Sewing Machine with a Control Board that smoked
Bernina does not sell individual components for PCBs, rather they have an exchange program for the entire board. But you have nothing to lose and much money to save if you can obtain the parts and replace them yourself. You should be able to get the caps and resistors from any electronics supply.
Posted on Oct 01, 2009
Testimonial: "Terrific- that sorted that out as I could not easily find Bernina Service. I will go and buy the bits."
  • 1116 Answers
SOURCE: bernina artista 180 keeps warning to check top thread
Refer to your manual for maintenance and clean the machine as indicated. A sensor may be blocked by lint.
If this continues, the machine will need to be serviced by an authorized Bernina repair tech.
Posted on Mar 25, 2010
  • 22 Answers
SOURCE: Foot pedal not working on bernina 1030 but there
The problem with you bernina is coming from the circuit board located on the back of the machine, there ar e a couple of fuses you might want to replace, if you change out the fuses and still no power the board will need to rebuilt aprox cost$150.00
Posted on May 03, 2010
SOURCE: I have a Bernina 180
Unfortunately no, I think that the 185 and beyond use the same emb module. The 180 if I remember correctly, has the memory and card reader in the module itself and may have a different plug. I do know for sure that the 180 hoops will definitely not fit on the newer modules. Sorry to disapoint, Allen
Posted on Feb 03, 2011
I have a Bernina 1030. When I put a presser foot #57 on the needle hits the presser foot. The presser foot covers the wide hole in the back.
Hm, I'm at a loss here unless the presser foot you have is not the correct one for your machine. I believe some presser feet for older Berninas may not work on the 1030-1230 machines. If you have the original #37 1/4" foot for your machine, you might compare the differences between the two feet and you might see where the problem lies.
Understanding Bernina Sewing Machine Shanks Sewing Parts Online Everything...
1 4 INCH 37 PATCHWORK FOOT for BERNINA OLD 830E 830 817 eBay
FWIW, I have both the #37 and #57. The #57 (or actually any of the 1/4" presser feet that are touted as "accurate 1/4") really does not solve the "scant 1/4" seam" for quilting because it still makes a 1/4" that is too wide. The best method I've found is to set a ruler under the presser foot. Set it so the needle tip rests lightly on the 1/4" mark and then mark the outside edge of the ruler with painter's tape on the needle plate. Then use the edge of the painter's tape as your 1/4" edge. If you find your 1/4" is still not "scant" enough, move the painter's tape a tinge until you get it where you want it.
https://www.connectingthreads.com/tutorials/How_to_Sew_an_Accurate_Quarter_Inch_Seam_Allowance__D95.html
Dec 08, 2017 | Bernina Sewing Machines
Bernina 1230 nothing happens when pedal is depressed.
Hmm, wonder if it could be a board or ????? You've already tested the foot control and it seems to be okay, so the problem would appear to be in the machine itself. Does the light work? That may be another clue.
May be time for a service call.
FWIW--Here are a couple of posts on a Bernina group:
  • Nov 17, 2015
My Bernina 1230 has lost its electric connection. My mechanic says that I need a new power board for $270, $30 for shipping from Bernina, $100 for installation, and $70 for the initial service--a grand total of $470.
I bought a 1230 this summer and finally dropped it off for service with
a very reliable OSMG though not a Bernina tech.
He had the machine all tuned up and ready to go, decided to try it one more time, and the machine didn't move. Tried another foot control, and still nothing.
The theory is the internal circuit board is the problem.
I know that some of you have had local electronics guys fix the circuit board problem, instead of shipping it to Bernina headquarters."
Jan 06, 2016 | Bernina Sewing Machines
Bernina 1030 starts by itself and runs very slowly some time after parking the needle at the top
This is most likely a fault in the foot control. Normally supplied with this machine is a Type 10 and this can be fixed quite easily but probably not by the machine's owner unless you have some electrical and mechanical experience.
If you have knowledge of and access to a multimeter, you can test it. What working properly, you will find the following:
Pedal released: resistance is infinite (anything around 4k Ohms or less and the machine will run).
Heel pressed: resistance is about 10k Ohms.
Toe steadily pressed from nothing to all the way down: resistance is infinite then after a small depression, jumps to about 4k Ohms steadily decreasing to zero as the pedal reaches all the way down.
Your problem, being at the point where the pedal isn't pressed suggests that there's some contamination in the pedal. It's also possible that you have a type 365 pedal (as used on the 930) and this is more likely to give this kind of trouble due to the use of carbon brushes in this foot pedal.
Feb 07, 2014 | Bernina Sewing Machines
My bernina 1030 won't feed material
Make sure the feed dogs are in the raised position and that the presser foot has been lowered before beginning to stitch.
Feb 11, 2013 | Sewing Machines
Bernina 180 pressure foot settings
it sounds like the feeddogs are not holding the fabric against the
presser foot,, check the feeddog to see if they are up, where you
can feel them with your finger in the needle plate area
Aug 02, 2012 | Bernina Artista 180
Benina foot pedal doesn't work
type in browser sewing machine parts in panama central america & see what comes up
or if you have a phone directory check for sewing machine shop & see if they can order one
Mar 09, 2012 | Bernina Artista 180
I need a Bernina 830 condenser
Do you mean the multi-part condenser that's used across the motor windings, or the one in the foot controller ?
Oct 28, 2011 | Bernina Artista 180
Foot pedal not working on bernina 1030 but there is power to the machine (the light comes on)
Apr 21, 2010 | Bernina Sewing Machines
Almost-certainly due to the main switching transistor having blown, however this is not necessarily an easy fix ... very often when this happens it takes a number of other components with it ... I had one last week where no less than 10 other components had got fried (and I do mean fried beyond recognition, due to somebody having put a bigger fuse in - doh! - dont ever do this ... it's dangerous!). Best thing to do if you dont really know what you're doing is to get a complete exchange 'L'-print.
Aug 15, 2009 | Bernina Artista 180
Bernina 180 - winding thread onto bobbin spool
If the bobbin winder spindle turns freely by hand and the macine runs fine with the foot controller then it may be the small motor that runs the bobbin winder that is at fault. If this is the case then your local service tech should be able to relace it. It is not a very costly part so don't be to worried.
Nov 02, 2008 | Bernina Artista 180
Sewing Machines Logo
806 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
