Question about Sony Bravia KDL-40S4100 40 in. LCD TV
Goes on and shuts down at different times - Sony Bravia KDL-40S4100 40 in. LCD TV
  • Sony Master
  • 8,617 Answers
Does the power light blink when it shuts down? If so let me know how many times it blinks and I will assist with the issue.
Posted on Feb 12, 2012
My sound plays for a while and then the amp goes into protection
Try a different set of speakers or if it keeps going into protection you have a channel going bad.
Jan 14, 2014 | Audio Players & Recorders
The ac shut down by it self every night
the ac shut down by it self every 30mints
Mar 03, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
Engine makes noise when starting and shutting off for a short time
Your car or truck engine can make a number of different kinds of sounds when it is shut off. The most common is a ticking or pinging sound from the catalytic converter because it is cooling down.
NEXIQ 125032 USB Link + Software Diesel Truck Diagnose Interface and Software with All Installers
Dec 22, 2012 | 2006 Buick Rendezvous
I have a 2002 Sony KP-57WS500 that occasionly (randomly?) flashes red lines and then goes to a full screen red while giving an electrical "cracking" sound before shutting down. Once shut down,...
Seems like your RED CRT is shorting out or failing. Do you notice any other colors besides just red having problems? The blinking of the red light eight times is a High voltage error. It could be your D board but I'm thinking it is more likely the red crt is probably shorting out.
Mar 08, 2011 | Sony KP-57WS500 57" Rear Projection...
1999 toyota battery keeps going down with new alternater this makes 2 alternaters and batteries
The most likely cause if you have changed batteries and replaced the alternator is that you have something that is an electrical drw when the car is shut off.
I assume the battery goes down while the car is sitting?
If it goes down when you are driving, it is likely a different problem.
If you don't have a multimeter to check for current draw when everything is shut off, an easy test to remove the negative battery cable and let it set the time it takes to discharge.
Then hook it back up and see if you have a full battery. If it doesn't go down with the batteryt cable disconnected, you either have a short somewhere or there is something left on (like a glove compartment or trunk light) that is draining the battery.
I assume you checked for the obvious things like brake lights staying on when the car is shut off (brake light switch problem).
Oct 01, 2010 | Toyota Tacoma Cars & Trucks
My pc turns it sef of regularly. It usually happens when i'm doing something important. I've used different memmory but still same problem. There is a click and it shuts down.
Try a different power supply to make sure that its not a voltage that is shutting down.
Clean the contacts on your memory and take a can of air and blow out the memory slots to make sure there is no specs of dirt in them.
Also take out the processor and blow out the contacts on it and also the socket it goes into.
After going thru these steps. Try a different hard drive cause a bad hard drive will cause the machine to shut down at times.
If none of these steps help, the motherboard for sure at this point is bad.
Dec 27, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
It stays on for a different length of time each time it's turned on. Sometimes will work for many hours per night and 4 or 5 nights, sometimes will stay on for only a few minutes. When it shuts down, you...
This tv is aging and you many bad grounds on the deflection board [it has the flyback transformer] And many bad grounds on the signal module [has convergence ICs]. And many many bad capacitors..I know as I repaired a few of these.
Nov 20, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Laptop not goes shutdown
get a program called tweakui and tell it to shut down you computer faster.
Apr 21, 2009 | Computers & Internet
COMPAQ CQ60-104Tu goes blank... improper shutdown
It might be a problem with the computer. I would advise going back to where you bought it and returning it to either get a new one or a different one. Glad I Helped!
Jan 28, 2009 | Compaq Presario Notebook
Monitor goes blank , power light goes off.
Click start, then then control panel and click on the power management icon. When you see the screen, look at the power management "scheme" and pick the appropriate setting. I assume that what you are experiencing is what's known as "Power management" . In order to achieve an "Energy Star" rating, the computer must shut off various components to conserve power. If you don't want to have your monitor shut down, select never from the options in the Power Management screen. Thanks for using Fixya.com
Jan 27, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
Sony Bravia KDL-40S4100 40 in. LCD TV Logo
43 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
