Question about Brother Sewing Machines
Can't remove shuttle race, needle hits it. - Brother Sewing Machines
SOURCE: Kenmore 385. 11607 needle jams into shuttle or shuttle race
had same problem. took thread out...that worked. thanks drazil
Posted on Mar 08, 2008
  • 3422 Answers
SOURCE: Singer 1120 timing
h,
Timing" is the alignment of the needle at its lowest point and the hook on the bobbin case. The point of the hook must pass directly behind the "scarf" of the needle fo the interlocking loop of a "single needle lockstitch" machine to occur. Look closely at the needle. You will see the long groove along the front of it. This is where the thread rides as the needle goes up and down. If you look at the back of the needle you will see a flattened area just above the point. This is the "scarf"; it's flattened to permit the hook of the bobbin case to run right by it and catch the loop.
When a machine is out of "time", the hook is either too early or too late, OR to far away from the scarf to make the connection. You can send a machine out of time by hitting a pin, or breaking a needle "hard" (too fast through too many layers, etc.). You can usually identify a machine that is out of time by multiple skipped stitches at high speeds, or by stitching fast and then quickly putting it into reverse. Sometimes, you can scrape by if you rotate the insertion of your needle a little bit, this can help compensate for minor timing issues.
Posted on Sep 07, 2008
kent581
  • 87 Answers
SOURCE: Can't reassemble shuttle hook and shuttle race
the hook driver (still in machine) is 1/2 moon shape. The hook is also 1/2 moon shape. If you set the machine on its back, it's easier. Set the hook 1/2 into the other 1/2 of the hook driver to make a circle. Then put the hook cover on (machine still on its back) with the tabs for the twist locks pointed out. Needle gaurd to the top of the machine. Snap the twist locks in place and viola!
Kent
Posted on Mar 18, 2009
  • 92 Answers
SOURCE: Hello, hope you can help
Did you change the needle to a new one out of a package? Also make sure that the needle is inserted to the top of its holder, press up hard when you change it. No luck? Maybe its knocked out of time...then its going to need to see a pro.
Derek
Posted on Jan 18, 2011
  • 48 Answers
SOURCE: I was sewing on my
There is still thread binding in the bobbin area. My advise is the remove the bobbin shuttle, I believe there is still thread locking your machine up. This is not an easy task and whatever you do don't lose the small screws. I can talk you through this the best I can, but if you are not comfortable taking the the bobbin shuttle out, please contact a commercial sewing machine repair shop.
Posted on Apr 20, 2011
The needlle is hitting the bobin and breaking
1. Make sure the needle is fully seated and tightened down.
If that doesn't solve the problem.
2. Check that needle is correct size.
If that doesn't solve the problem...
3. remove the foot, and remove the plates in the bobbin area. Get a magnifying glass out and inspect the shuttle race/bobbin carrier. Can you see the stab marks? Rotate the handwheel toward you slowly until you see the needle hit. Is the hook behind the needle? If so your Timing is Advanced and the machine needs to be timed. Have it done professionally. It is likely that you may need a new part or two as well.
Oct 31, 2013 | Consew 199RB-1A
Bernina 130. The upper needle is working but it does not seem to be abLe to catch the bottom thread. Had this machine for 12 years so I know how to put the bobbin in. Any ideas?
Firstly, I assume you've cleaned-out under the stitch-plate and after removing the bobbin, have removed the hook/shuttle, cleaned the hook race and given the hook race a drop of oil. Whilst you've got the hook/shuttle out, just check that the point is not damaged. Also, if you've got the lightweight hook/shuttle often fitted to these machines (it's black plastic with a metal outer/point), make sure there's no needle damage to the plastic - sometimes this can catch the thread as the hook rotates, preventing the loop from being picked-up. After doing that, check if you can sew straight stitch with the needle in centre, fully left and fully right. If it works in one location but not the others, there could be a number of issues such as timing/synchronisation or possibly the needle bar is offset front-to-back so that there's too large a spacing between the needle and hook.
Nov 13, 2011 | Bernina Activa 130
I need to know how to clean and oil the machine
From the Sears Kenmore manual:
Using a small brush, remove the lint that accumulates in the shuttle area and around the feed dogs.
To Clean the Shuttle Area:
  1. This area must be kept free of dust, lint and occasional tangled thread. Raise the needle bar to its highest point and remove the bobbin case.
  2. Push levers of shuttle race aside and lift shuttle race cover and shuttle out.
  3. Clean the shuttle race with a small brush.
  4. Put a drop of oil on the center pin of the shuttle and shuttle race.
Jan 25, 2010 | Sewing Machines
My machine is a Brother XL5600; I think I am having a shuttle hook problem. When I lower the sewing needle to "catch" the bobbin thread and pull through- it won't catch and pull through. I have changed out...
Hi
Thanks for using FixYa. The upper thread could be tangled. Remove the thread completely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine according to the directions in the manual.
Place a spool of thread on a spool pin and check the upper threading.
Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
Also please check that the bobbin is installed in its case rightly. Needle thread is too tight. Hold the thread lightly to keep the end from going down into the shuttle.
The needle could be thread incorrectly. Thread the needle eye from the front to the back.
The needle could be bent or improperly inserted and install a new needle with the flat side of the needle facing the back.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | Brother LS-2125 Mechanical Sewing Machine
The needle does not pick up the bobbin thread
Hi!
There may be so many reasons due to which the needle does not pick up the bobbing thread like---
The upper thread could be tangled. Remove the thread commpletely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine. Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race. You could be holding the needle thread too tight. Hold the thread lightly to keep the end from going down into the shuttle. The needle could be thread incorrectly. Thread the needle eye from the front to the back. The needle could be bent or improperly inserted. Install a new needle with the flat side of the needle facing the back.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 08, 2009 | Euro-Pro 9105 Computerized Sewing Machine
Bobbin and shuttle case pop out of machine .
You might need to clean the shuttle assembly.
1. Raise the needle bar to its highest position and remove the bobbin case.
2. Push levers sideways of the shuttle assembly and liftshuttle and shuttle race cove out by the center pin.
3. Clean the shuttle race of any lint or small particles of thread with a small brush.
4. Put a drop of oil on the center pin of the shuttle and on the shuttle race.
to reassemble, hold sjuttle by center pin and it carefull into assembly opposit the shuttle driver. Slip shuttle race cover into place. Snap the levers into position.
Occasionally remove the needle plate and clean feed dog with soft brush.
I hope that helps!
Apr 23, 2009 | Brother LS-2125 Mechanical Sewing Machine
Singer Merritt 2430
Hi!
There could be several reasons due to which the thread keeps bunching up underneath.
It may be due to tangling of upper thread. Remove the thread completely from the machine, use correct size spool cap for the size of the thread spool, re-thread the machine, now remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
Please rate the solution as FixYa and revert for any clarification.
Thanks
Rylee
Apr 23, 2009 | Janome 6019QC Mechanical Sewing Machine
Kent
Mar 16, 2009 | Baby Lock BL1556
Sewing Machines Logo
26 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
