Question about LG LRE30755 Electric Kitchen Range
All my burners arnt working! HELP!!!
I was cooking dinner today and all the burners stopped working. All at the same time. The oven will work. Heats up great. But the main burners wont work. I think that it is one of the fuses. Any suggestions?
There is a cooktop PCB (power control board) which is separate from the oven. Perhaps that is the problem. That board is located behind the cooktop control membrane panel.
Posted on Oct 30, 2008
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
Burners wont work any more
Good Morning Fern mullen, I appreciate your post!
Based off what you have described your burners are no longer working on your Frigidaire range. This could be an issue with your control panel or the switch. I would recommend performing a reset on your range and you can do that by disconnecting power from the range for at least ten minutes. If that does not help correct your issue I would suggest having a technician out to your home for a proper diagnosis and repair. Best of luck! -Matt
Feb 28, 2015 | Frigidaire FGEF306TMF 30" Freestanding...
How do i change a whirlpool model wbp88800 burner control
Unplug stove. There should be two screws under edge of the cook top. You need to open oven door to get at them. Remove screws, lift cook top up at the front and prop it up. There will be two or three screws with spring clips holding the burner to the cook top. Unplug the connections, remove screws, remove burner. Install in reverse. I did this at Christmas just in time for dinner. It takes about ten minutes.
Feb 06, 2015 | Whirlpool Kitchen Ranges
AEG Oven Heats But Buzzes
lots of them do it. (Including ours unfortunately) in our case this is down to vibration in the casing the fan is screwed to and can be stopped temporarily by pressing something strongly against the top black casing just inside the grill door with the two ventilation slots in it. I wouldn't recommend doing this every time you need to cook obviously. Ours has done it for years it doesn't get any worse. it's not dangerous ( in my unqualified opinion ) and it doesn't affect cooking performance.
Mar 19, 2013 | AEG Ovens
Kitchen aid sparking on all burners
one of the burner switches is shorted, take off plate that covers the switches and remove the wires one at a time on each switch then reattach wire before going on to next switch.continue until sparking stops,replace switch (easy fix)
Sep 08, 2009 | KitchenAid Kitchen Ranges
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Tricity bendix fan oven
The element is almost certainly burnt out .A replacement element is fare cheaper than a new cooker and relatively easy to fit
Apr 07, 2008 | Ovens
No heat in oven or on range
when you turn on the top burners do you hear the ignighters clicking please hold my rating for now as i need to ask a few questions
Jan 11, 2008 | Frigidaire FES367 Electric Kitchen Range
Burners Blew
if you will send me your model number off your serial plate on your range will be on front open oven door or lower drawer some where and when you bought it i need to check the service bulletins before i reply but dont rate me till were done
Jan 02, 2008 | KitchenAid KESC300 Electric Kitchen Range
LG LRE30755 Electric Kitchen Range Logo
320 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
