Question about Whirlpool Kitchen Ranges
Hi I have a whirlpool stove model yxfe361lvq0 the plug-in at the top 110volt is not working is there a way I can fix it?
SOURCE: whirlpool oven doesn't work model gs563lxss
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
Posted on May 28, 2008
aborcass
  • 2651 Answers
SOURCE: Error message FSEO appear on display of whirlpool stove
Door and switches
do not agree
1. Unplug range or disconnect power.
2. Check wires and connectors from control to door switch, then from door switch to control.
3. If no damage to wires or connectors, replace door switch.
4. Replace all parts and panels before operating.
5. Plug in range or reconnect power.
6. Press Cancel/OFF key. Program and start the CLEAN mode, and observe for 1 minute to ensure that
operation is normal.
7. Go to step 1 and complete checks.
Posted on Jan 11, 2009
erpaalai
  • 999 Answers
SOURCE: How do I raise the stove top of a ceramic glass mo...
Open the oven door and look up across the front for 4 screws.
Eric
Posted on May 23, 2010
  • 1416 Answers
SOURCE: Pressed broil for the stove
This error code on a Kitchen Aid range indicates a keypad short on the Electronic Range Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
searspartsdirect.com appliancepartspros.com
pcappliancerepair.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-your self offer. If you decide to order the part and wish to repair this on your own, follow these steps:
1. UNPLUG the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the ERC. Take note of how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on the circuit board. However, if the colors are not printed on the board, write them down. (A digital camera also comes in real handy for this).
5. With the connectors removed, remove the mounting screws to the ERC and the assembly will come out.
NOTE: Most replacement ERC boards do not come with the overlay. This is the plastic pre-printed number display. The overlay can easily be peeled off and re-used. Just make sure you properly orient the overlay so that you don't inadvertently place it on the new board upside down. If your existing overlay is damaged, you will need to order separately.
6. Install new ERC using the steps provided in reverse order. Minimize handling the new circuit board with your bare hands to avoid damaging the board.
I hope this instruction helps you.
Thank you for using fixya.
Posted on Sep 20, 2010
oldTech2332
  • 2341 Answers
SOURCE: i have a whirlpool super
The problem with the oven not lighting believe it or not is going to be that the igniter is weak and not drawing the correct amount of power to allow the gas to flow.I know it would seem since the igniter comes on that it could not be the problem yet since it comes on to me a oven technician with 30 years experience the igniter is exactly what it is.
GENE
Posted on Sep 23, 2011
How do I fix stove top lights?
Find the manual online by going to Google and put in the make and model of your stove. It's usually found on the inside of the door. In the manual it will tell you how to replace the lights (bulbs).
Oct 12, 2014 | Whirlpool MH6130XEB/Q Microwave Oven
I have a whirlpool slid in gas oven. model # GW395LEGQ5 the stove top works great but my oven goes on for about 15 min. or so and shuts its self off. its coming up on the holidays and im a baker so please...
you may need a sensor change if the oven is on and sensor is gone there is a protection on oven to shut down cause of over heating ... i would try un plugging the stove for 10 min .... plugging back in and seeing if it resets ....also make sure when oven is on there is nothing on the element blocking the oven from releasing the heat if this doesnt work may need a new sensor
Oct 23, 2013 | Whirlpool SF368LEP Gas Kitchen Range
My whirlpool electric stove a burner don't work l
my whirlpool electric stove top two big buner is not working
Nov 28, 2012 | Kitchen Ranges
I have a whirlpool electric glass top stove (model # rf364pxpq ). our electricity went out for only a moment, and when it came back on, the control panel is blank and the oven doesnt turn on. the stove top...
I just encountered the same problem. Power surge during storm caused the control panel to go blank. I removed the panel to get the part number. Reinstalled control panel and it started working. Below are the steps 1) Turn off breaker 2) Unplug unit 3) Remove rear panel 4) Unplug all connections to control panel 5) Wait 5-minutes 6) Reconnect all wires in reverse order 7) Install rear panel 8) Plug in unit 9) Switch breaker to on position Control panel came on, set clock and all oven functions worked.
Jan 02, 2011 | Whirlpool Kitchen Ranges
Whirlpool electric oven not heating (has a functional stove top)
Hello Daniellel583! We are terribly sorry to hear of your concern with your Whirlpool Range. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Daniellel583), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool RF111PXS Electric Range
Power, no heat unless oven is set on "simmer" mode.
it sounds like u have a voltage problem, do you have a volt meter? check to see if you are getting 220v at the outlet where your stove plugs in, next check the plug cord and the connections where your cord attaches to the unit, connections good and tight? plug stove back in and check the voltage, unless you have a serious problem burned wires in stove problem should be corrected by now
Sep 17, 2009 | Whirlpool Accubake RF362LXTS Electric...
PF on Whirlpool super capacity 465 electric Stove Model RF366PXGW2
PF = Power Failure. Sounds like you have a bad electrical connection. With your breaker off, check that the connections from the cord to the range are all good and tight. Next, check the receptacle where the cord plugs in. Remove the cover and check the connections there as well. Examine the power cord also. There could even be a poor connection at the breaker box (at the circuit breaker or the neutral buss bar) but not as likely, as your problem appeared when you moved your range.
Oct 19, 2008 | Whirlpool RF378LXKS Electric Kitchen Range
Whirlpool oven doesn't work model gs563lxss
May 15, 2008 | Whirlpool GS563LXSS - stainless Steel Gas...
Kitchen Ranges Logo
61 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
