Question about Montgomery Ward (223600UP) Heater
Wall furnace model # SFB50146B Thermal Coupler. Does it have 2 wires?
I am working on a "made for Montgomery Wards" wall furnace for some elderly people. Pilot light is working however the burners never kick on. Suspected the thermal coupler, so purchased one from my work and went to install it. Upon arrival, I notice a small copper tube, which I thought was the thermal coupler, but it was open on the top and hooked into a port marked "bleed" on the control valve. The new suspected thermal coupler runs down and has a red and white wire hooked up on the front of the control valve. So my question is...is this the thermal coupler and is there anyway to check it to see if that is the problem?
  • kragan62 Oct 28, 2008
    pilot stays lit but the burners wont ignite. thermostat wires are all attached except the white one where it goes to the unit. should the white wire connect somewhere?
If the pilot light stays lit, but the burners don't kick on, it's a problem with the thermostat or thermostat wiring, or a problem with the valve inside the gas actuator
Posted on Oct 25, 2008
My furnace keeps making an explosion when it ignites
The amount of gas buildup is too great. Make sure the burner ports are clear right next to the pilot light area. - run a small wire into the holes to make sure they are clear then make sure the pilot light is burning into the area next to the burner. A bit of whoosh is to be expected but if it becomes too great it will blow the pilot light out. Sears wall furnaces are prone to this the burners have to be kept clean
Feb 02, 2015 | Heating & Cooling
Just need to know how to light the pilot on a Montgomery Ward wall furnace model sfb-50219
I can't speak to the specific model but with most pilot lights, there is a switch setting or button for lighting. If you release that switch or button too soon, the pilot will not remain light. Hold the switch or button ON while you light the pilot. Keep holding the switch or button for about a minute until the heat sensor is sufficiently warmed that the pilot light stays on. Good luck.
Nov 13, 2014 | Heating & Cooling
Old anthes gas furnace with pilot light. burners will not light.blows cold air
Have to think that the thermocouple has failed if the pilot is on but the furnace main burner doesn't ignite
Apr 05, 2014 | Cozy (W352E) Heater
Gas wall furnace pilot goes out when burner turns off.
When the main burner turns off, does it make a whoosh or pop? If so, this would be the issue causing the pilot to be disturbed. And have you tried to adjust the pilot/thermopile strength, if possible? A stronger pilot may help. Now if the main burner slowly goes out, and the pilot also slowly goes out, and also slow to ignite, and you've replaced about everything else, it may be the gas valve itself that has/is giving up. Gas is impure and causes a sticky residue. And if the main burner is "slow to act", this tells me the piston that's inside the valve is slowly opening or closing, and may be the reason the pilot is acting up. Make sure you check the outlet to your flue pipe also for obstructions. If the unit doesn't vent properly it can have more heat in the flue. That heat can have a downward rush when the burner goes out, kinda like forcing air through a clogged tube. And when you quit forcing the air, some of it comes back at you. Before condemning the valve try to check all else as you have done with the thermopile and such. Please work safe and I hope this helps.
Oct 09, 2017 | Williams Heating & Cooling
I have a montgomery wards furnace model srm54013a. won't shut off, keeps putting out heat
SOUNDS LIKE A BAD THERMOSTAT OR THE RED & WHITE WIRES IN BACK OF STAT ARE TOUCHING ONE ANOTHER COMPLETING THE CALL FOR HEAT.
Dec 25, 2012 | Heating & Cooling
We are having difficulty lighting the pilot light on our wards gas wall heater. Is there a diagram that shows where we are suppose to put the lit match and which way to turn the knob? Thanks for your help
you may have to push down on gas knob to start gas flow for pilot move flame so it licks thermo couple detector.
if thermocouple gets too old it will not generated enough power to keep relay open for pilot
Nov 25, 2010 | Montgomery Ward (223600UP) Heater
How do i relight my standing wall heater light, where is it?
There should be a removable panel on the bottom front. Remove this panel and you should see gas valve with two lines going into combustion chamber. The larger of the two will be for burner and the smaller to the pilot light. There may be lighting instructions on the inside of panel,or on front of burner compartment. If not look at gas valve and see if you can see where it is marked off pilot and on. Turn thermostat to lowest setting and gas valve to pilot ,locate pilot light and hold match to it while you depress pilot button . Pilot should light. If it does hold button depressed for 1 to 2 mins. Release pilot button and if pilot stays lit turn valve to on. Turn thermostat up to desired setting and see if burner comes on. If it does you should be done. Put cover back on. If pilot light does not stay lit or burner won't light I Would recommend you call a service tech as there are several things that could be wrong. Hope this helps you.Thanks
Nov 12, 2010 | Montgomery Ward (223600UP) Heater
Pilot light goes out when burner kicks off
Sounds like the pilot is dirty....when dirty it gets smaller and lazy...tends to go out easy...try gently tapping it with a screwdriver...make the pilot bluer and bigger....when it's dirty it has yellow tips or yellow completely , the pilot should fully envelope the thermocouple as well
Nov 01, 2009 | Desa International GWP20T GLOWARM Wall...
Montgomery Ward (223600UP) Heater Logo
1,585 people viewed this question
Top Montgomery Ward Heating & Cooling Experts
Paul Carew
Mack Baxter
Are you a Montgomery Ward Heating and Cooling Expert? Answer questions, earn points and help others
