Question about Refrigerators
My old GE refrigerator is not dispensing water in the outside of the door.
  • Refrigerators Master
  • 4,654 Answers
Horacio your refrigerator has two sides on water dispenser. It's possible the side for the water dispenser is defective. First you will need your refrigerators model number. The place to locate the model number is=> Side By Side, Top Freezer and Bottom Freezer You can buy your parts where ever is best for you but I will use this is an example. Once you locate the model number click here=> Point and Click Appliance Repair Once that page opens you will see four choices of simular model numbers. Just choose one as the parts are the same for the PSS26. Here is a photo of the back=> Sealed System or Motherboard
You see the part listed as number 800? That is a=> WR57X10051 Dual Water Control Valve for the PSS26MSRSS refrigerator. You can also test the water control valve by using an OHM meter to check resistance you should get a reading of 150 to 300 OHM's if the coil is good. Sometimes checking the OHM's will not work because there may be something mechanical wrong with water control valve. Either way I will be here to answer any questions you may have, Thanks Sea Breeze
Posted on Feb 12, 2012
peyton32034
  • 410 Answers
SOURCE: GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Posted on Dec 16, 2007
SOURCE: GE Refrigerator model #gss25sgress Water dispenser problem
What you describe was a common problem with this model and one that still pops up. Your refrig *might* qualify for an upgrade under terms of a program GE initiated a few years ago. Call 800-432-2737 first it might save you a service call
Posted on Jan 06, 2008
  • 74 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Check the connector at the bottom of the freezer door first , you should also be able to hear the micro switch click when you press the paddle
Posted on Aug 28, 2008
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
Sea Breeze
  • 4654 Answers
SOURCE: No water from door dispenser
This is most times caused by a defective dual water control valve on the back near floor of the refrigerator. Unplug the two wire connections and check both coils with an ohm meter. The both should read the same amount of resistance. Or set your meter on voltage and place the probes in each side of the plug and have someone press the dispense button. You should show the household voltage at the end of that plug. Sea Breeze
Posted on Jun 23, 2009
No dispensing water...GE refrigerator
There may be an interlock switch on the housing where the filter or dummy stopper is inserted. If this interlock is not satisfied, then the water dispenser won't turn on. This would prevent water from spraying all over the inside of the refrigerator if the filter is not seated properly. Check to make sure the filter or plug is inserted properly.
Apr 01, 2014 | GE Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water not coming from gss25lgmb bb
I have a GSH25JSRFSS GE refrigerator. Twice, the water line has frozen near the dispenser. Each time I used a hairdryer to heat either the side of the door where the water line runs and blew hot air up the dispenser. This last time, I took the plastic cover off the outside of the door (it clips on) and blew hot air into the small holes in the door that the outside grate clips into. This allows the hot air to get inside the door, and I heard ice from the frozen line drop. Subsequently, the water line worked. Two points: I did have water running to the line in the bottom of the refrigerator, so I knew it was an ice clog, and secondly, I took care not to blow hot air on the exposed wires inside the door.GKAZ
Oct 23, 2011 | GE GSH25JSRSS Stainless Steel Side by Side...
Ge Monogram built in side by side. Water and Ice
You can do it yourself if you feel comfortable, Here is a service manual for you that should help out. 31 9091 GE Monogram Side By Side Refrigerator pdf
Jun 10, 2017 | GE Profile PSW26P Stainless Steel Side by...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Water does not dispense
there should be a water line that runs from the reservior that is in the fridge compartment under the appliance to a connector at the bottom of the freezer door, if water is getting to there then the water line within the freezer door is frozen . If water is not getting there then the reservior may be frozen or the watervalve may be faulty
Nov 24, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE refrigerator Leaks in back when trying to use water dispenser
That tube needs to be replaced or repaired. It connects to the electric valve with a compression type fitting.
May 26, 2008 | GE GSH22SGRSS Side by Side Refrigerator
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
