Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Keypad outside garage door
My keyboard was working fine ever since i bought the home in january. Yesterday the keyboard stopped working. Can anyone help me in why it stopped working?
  • Anonymous Oct 28, 2008
    our kepad hasn't worked for at least a week and we would like it if someone could help us NOW PLEASE
  • tatumbelle Feb 25, 2009
    I have this problem. If I program the password again it works for a week or so but then stops again. It seems to lose the password.
Have you checked the battery in the keypad itself? It is usually a specialty battery that you would need to purchase at a hardware store.
Posted on Oct 24, 2008
Why won't the keypad outside mount not open the garage door but the remotes work fine.
U will have to re program the keypad follow the directions on the lid of the keypad now on some models u have to hold down * # at the same time until it stops blinking then enter your 4 digit code press enter hold for 2 sec if opener does not release and press again as soon as u hear the opener click or light blink press 0 to store code then wait 60sec and try
Sep 02, 2014 | Chamberlain 1/2-HP Whisper Drive Belt...
Hi... I have a Sears Craftsman Garage door Opener Model# 139.53600 Outside garage door keypad which is hard wired (electric) isn't working. However the inside keypad and the car transmitter are both...
A wireless keypad will not work with your opener. Your opener is pretty old and the new models are much safer. You might consider replacing the entire thing.
Feb 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
Our garage door will not open all the way. Up until yesterday it worked fine. Then when I came home from work and pushed the button to open the door, the door raised up about 3 inches and stopped. I pushed...
You have either a broken door spring or the drive gear in the motor unit is bad. The drive gear is a white nylon gear just in front of the motor and it will be obvious if it is bad.
Nov 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
We just moved in our house in January and our keypad on our 1/2HP Liftmaster stopped working. I have changed the battery and when I try the code the backlight blinks several times but the door never opens....
Try programming the keypad by doing this:
Press and immediately release the smart/learn button and then walk over to your keypad and key in any 4 digit code you like and press enter. If this doesn't work you keypad has quit.
Aug 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
We have just bought a home. I need to change the code on the Sears Wireless Keypad for the garage door opener - this is located on the outside of the garage. What keys do I need to press to change the...
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Jul 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: outside keypad will not open garage door at all bu...
The inside button is hard wired. The keypad is a small radio transmitter. If the battery in the keypad is good and it doesn't work when you put in the code it has probably just quit.
May 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Keypad Chaimberlain 32B2171-1 does not work any more
You can try programming but if it still doesn't work then your keypad is just bad. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in your 4 digit code and press enter.
May 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote only closes the garage door, will not open it
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
In your case the expansion of the wall in the afternoon may be enough to cause pressure on the wire to increase the problem – works in the morning but not the afternoon.
Also after you change the batteries you need to reprogram the remotes.
HOPE THIS HELPS
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
66 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
