Question about Fisher and Paykel DEGX2 Dryer
Fisher and Paykel Intutive dryer smartload Lid switch
My dryer is telling me my door is not shut. The switch is not being pressed far enought to make it work. I can make it work manually but i would like to know if there is a way to by pass switch? If there is another way please let me know. . .. very frustrating
Thanks a bunch!
Danger Russ
5 Suggested Answers
  • 686 Answers
SOURCE: Dryer is working but not heating up or drying clothes
bad heat element
Posted on Feb 20, 2009
localwonder
  • 6784 Answers
SOURCE: The dryer won't run. Dry, extra dry, and coold down process lights are lit.
Hi, the lights are signaling a control fault the is concerning the logic sector of the control board/timer. you will need to make sure that the wiring harness is connected to all points and it should be in good condition. if there are no apparent issue with the wiring harness, replace the control.
Posted on May 29, 2009
  • 70 Answers
SOURCE: My fisher and paykel smartload dryer has run just
Not my brand of skill, but I am guessing the door needs to be open to exhaust an overly hot and burned up motor, that may be close to on fire.
Posted on Jun 23, 2010
  • 32 Answers
SOURCE: fisher paykel smartload dryer degxius does not dry
Check and make sure that your exhaust tube and outside vent are not clogged. If they are clean them out and you may have to buy and new lint screen that come with a seal whcih will solve your problem. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ . This forum will further help you through your problem.
Posted on Oct 15, 2010
  • 552 Answers
SOURCE: I have a Fisher Paykel
The link below is to a video that explains how to access the resettable fuse on the heater canister.
http://www.appliancerepairlesson.com/
Posted on Mar 06, 2011
Drying and Lid Locked lights flash red and it beeps continuously. Dryer will not start.
look on coolblueworld.com or paperwork for error code is in back consol . please unplug dryer if you remove consol.
Mar 21, 2015 | Fisher and Paykel SMARTLOAD DE62TG1...
Fisher paykel troubleshooting
place your hands on the drum and push it backwards . the door will open when it comes around .
Jul 19, 2014 | Fisher and Paykel DEGX2 Dryer
Our dryer is making a squeeling? sound when we turn it on. Also, the power button on the switch board no longer works properly. I hsve to press so hard that my thumb hurts just to get it turned on.
You have two different problems... the start switch is bad and you have problems with the guide wheels...
Replace the start switch and here is a tip about the noise...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Nov 25, 2010 | Fisher and Paykel SMARTLOAD DE62T27G Gas...
My top load dryer does not vent enought air to open vent door i have cleaned the filters and the fan
Check the exhaust tube, then go to to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 21, 2010 | Fisher and Paykel DEGX1 Electric Dryer
I recently had a horrible repairman recommended by the company come to my home to fix the dryer because it wasn't drying properly. Not only did he lose a screw in the front and not replace it (the front is...
Is it still not drying? This happens when the heating element goes out and can be replaced by yourself and the heating element coil is about 20 dollars. I'm not sure which wire is not connected, probably connects the button that shuts off when you open the door.
Mar 01, 2010 | Fisher and Paykel SMARTLOAD DE62TG1...
Heating element no longer working. dryer still operating except clothes wont dry
it is the theromstats or heater element has gone the only way to tell is to meter them out u need an expert to do this
Jul 31, 2009 | Fisher and Paykel SMARTLOAD DE62TG1...
Fisher and Paykel DEGX2 Dryer Logo
41 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
sonic boom...
sonic boom...
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
