Question about Dishwashers
I have a hotpoint dishwasher model hda3440g02sa & it leaks water at the motor shaft
  • mike Feb 12, 2012
    is there a seal kit for that shaft going into the plastic piece? i dont want to by a whole new motor.
the dr
  • 447 Answers
SOURCE: Hotpoint DF31 Dishwasher
You need a new inlet valve. Axcessed through bottom panels below door there are screws in the four corners of the upper one. Inlet valve is where the water line meets a plastic body with wires going to it. www3.sears.com for parts.
Posted on Oct 05, 2007
SOURCE: leaking FDW60
Had a similar problem when I removed the lower spray arm for replacement (see http://www.fixya.com/support/t234402-fdw60_dishwasher ) and didn't put the centre retaining nut back. It might be worth checking the lower arm is screwed in tightly as the retaining nut prevents water escaping.
Posted on Jan 30, 2008
  • 105 Answers
SOURCE: dishwasher leak
must need a new air tube or worse still the air chamber has a split in it
clean machine out in w/shop and with sides off check out with a light to see where the leak is realy comming from it may be leaking from the top wash feed pipe leaking around pipe to tub
these do fracture there and water running down to base
if so replace feed pipe
Posted on Feb 24, 2008
SOURCE: Leak from dishwasher
I currently had the same problem with mine and the culprit was the boot that screws on to the spray arm which serves as the seal from the spray arm to the motor.To find out spin the base of the spray arm loose and take off the screw tightened clamp that holds the boot to the motor. Mine had dry rotted and leaked very badly.The part as only about $10. Hope this helps
Posted on Oct 25, 2008
SOURCE: GE 24in GSD980X Dishwasher water leak in pump &motor area
I had the same problem. There is no way of replacing seal/joint between pump and motor. It can't be taken apart w/o destroying parts, it only comes as an assembly. Costs around 130$ for pump/motor assy, so it might not be worth it.
Posted on Jun 12, 2009
I have a Hotpoint BF71 dishwasher. I put it on but it hasn't worked, it filled with water which won't drain not will it even start now. I took out the filter but I couldn't find any blockages Help!
Reset the power at the breaker, but you may need a new pump and motor assembly. The same pump washes and drains on most Hotpoint models- a solenoid is used to open a drain flap and let the water out, but a bad pump will equal no wash or drain... Hotpoint Dishwasher Pump and Motor Assembly WD26X10013 Hotpoint Dishwasher Drain Solenoid Kit WD21X10268
Jul 11, 2016 | Hotpoint Dishwashers
Hotpoint diswasher won't drain or switch off and is constantly flashing f-2 , model is FDYF 2100 K
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
see the diagram attached, and proceed according.
May 24, 2013 | Hotpoint Dishwashers
Hotpoint dishwasher 4th & 6th lights flashing
You will need to provide the model number of the dishwasher. However, the likely causes of the lights flashing are many, including water inlet failure, blocked drain filter, leaking seals causing flood switch to trip. You may want to go to the Hotpoint site and find the manual for your model.
Nov 05, 2012 | Dishwashers
Water leaking from the bottom
The water could be coming from the drain hose or from a failty pump/motor seal.
Feb 06, 2012 | Hotpoint Dishwashers
How old is my Hotpoint dishwasher, model HDA3400G02WW Serial SG8047194 is??? My dishwasher humms, but doesn't runs at ALL. What could be the problem????
The motor is stuck. If you remove the lower cover and see a square aluminum motor it is less than 7 years old. Make sure power is off at breaker and rotate the motor shaft
by turning the fins inside the motor.
If the motor is black and round you have to turn
the fan blade which is located in a slot between the metal pump and the plastic
pump. Also once freed, a light shot of silicone or WD-40 (silicone works better) at the
bearing ends. Also check pump for leaks around the drain solenoid (shiny shaft attached
to a plastic triangle). If it's leaking during pumpout, the seal has failed. The pump runs
around 100 dollars typically. Hope this helps.
May 30, 2011 | Hotpoint 24 in. HDA3400G Built-in...
Dishwasher is leaking from leftside if standing in front of
If you get water when it is not running, then it can be the incoming water line. if it leaks durung running mode then It can come from bad seal on the door, look and see if i has any built up at the bottom seal, or from the pump shaft seals.
By the way, there is no drum in dishwasher machine.
Dec 07, 2010 | Hotpoint Dishwashers
Dishwasher making thumping noise when in cycle and leaking
motor turns to cast the water around the dishes.that motor shaft is in close by a water seal.it must have gone bad allowed water on to the motor bearings which would be your noise.could be bad.open your bottem panel turn on unit and watch whats happening.when you see that decide what parts you will need ,check cost and think if thats what you want to do.God bless,tom
Jan 01, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Nov 22, 2008 | GE 24 in. GSD980X Built-in Dishwasher
Water Leak
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Aug 14, 2007 | Hotpoint 24 in. DF55 Free-standing...
Dishwashers Logo
37 people viewed this question
Top Dishwashers Experts
Owen Barnes
