Question about Smeg Ovens
SMEG SA 388X not working at all
The oven is not working at all. The only sign of life is an 'A' showing in the display. Can't see time or anything else. Power button doesn't light up when oven is turned on and there is no heat or fans at all. When I try and push any of the buttons under the display the whole row of buttons move in the panel as though they are a bit loose.
I've had problems in the past when the oven didn't work but this was always fixed if I pushed the last button under the display which is the Set Manual/Automatic operation. Any help would be greatly appreciated.
Thanks
Lyn
5 Suggested Answers
  • 49 Answers
SOURCE: Smeg oven SA 392 EB - technical difficulties
first of all the yellow/orange light glowing is a known fault. it needs a slight wiring modification to fix it, however it dose not affect the operation of the oven nor is it dangerous.
now to the heating problem, there is a round element at the rear witch surrounds the fan. is this element getting hot? if not then it most likely needs replacing. it could be the thermostat but more likely the element.
Posted on Mar 05, 2008
  • 1462 Answers
SOURCE: SMEG SUK62 MFX
check stat is not open circuit and check selector switch not damaged
Posted on Oct 18, 2008
SOURCE: My step Dad's whirlpool, electric,
Hey there-
He ended up calling a repair tech.. He came out and ended up replacing the whole control panel.
My step Dad says it works fine now and the clock is a lot brighter on the display than it was before, so maybe it was slowly going out then finally just gave in. ?? Thanks for checking in though.
Posted on Oct 26, 2008
  • 189 Answers
SOURCE: New oven won't work and can't set time, display keeps blinking
Hey--  You've spent a bunch of time on this already, so let's figure it out. The first step is to check power connections. L1, L2 , Neutral for proper location and tight connections. Should have 120v and 220v checked at bus block. If these check out, then this new unit should be under warranty and qualify for service. Not unheard of bad board or loose wire on a new unit. Let a tech sort it out on site. Let me know if this info helps- have more if needed-  Thanks-  Ed
Posted on Mar 15, 2010
Testimonial: "I suspect a bad card, as I have 120v on each line black & red to white, (I am connected to aluminum wiring using anti-oxidizant grease)"
drifterK
  • 4924 Answers
SOURCE: Have a smeg SA 9065
It sounds like a thermostat blocked issue ...
take oven out and remove top plate. you will see stat behind the temp control knob - usually just clipped on(sometimes stat becomes un-clipped which will cause your problem as well)
remove stat and undo capillary (wires) from mounts inside oven. reassemble in same way. note where wires go before you remove them!
If you think you can not manage ..better to have it seen by a professional cause it may be a little tricky ..
Posted on Jul 24, 2011
Oven SMEG SUK61PX8 Fan motor working but the fan slipped of motor rod. There are no signs of break there is no thread on rod. The only thing I have is the fan blade on which there is the nut and a hole...
Replace the fan motor, the rod is one unit with the motor, half moon shaped and threaded at the end, normally left hand thread
https://www.google.co.uk/search?q=SMEG+SUK61PX8+fan+motor&espv=2&source=lnms&tbm=isch&sa=X&ei=rY6wU_uRMYfGPfrWgfAN&ved=0CAcQ_AUoAg&biw=1366&bih=643#facrc=_&imgdii=_&imgrc=_rJYFUaBeWyYSM%253A%3Bc9wu4bCdifNlUM%3Bhttp%253A%252F%252Fthesparesshop.co.uk%252Fmedia%252Fcatalog%252Fproduct%252Fcache%252F1%252Fthumbnail%252F600x600%252F9df78eab33525d08d6e5fb8d27136e95%252F4%252F9%252F492831433611_1.jpeg%3Bhttp%253A%252F%252Fthesparesshop.co.uk%252Fsmeg-circulating-fan-oven-motor%3B600%3B600
Jun 24, 2014 | Ovens
Smeg linear oven is displaying sho (showroom mode) and will not heat up. I have held down function knob for 5 seconds which clears SHO from display but within seconds it comes back. Any ideas
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 28, 2013 | Smeg Linear Pyrolitic Single Oven Electric
Fan bake on smeg oven not heating ,mod SA 9066XS
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
Feb 02, 2012 | Smeg Ovens
I have a Smeg SA 398x model. firstly, I would like to know the year of manufacture please. Secondly, for some reason the fan element options do not heat up. The fan in the back of the oven works but no...
Jul 19, 2011 | Smeg Linear Pyrolitic Single Oven Electric
SMEG SA 398X
OK I have just moved into an apartment with this model (SA 398 X/1) and was searching for a user guide (no luck yet).
Anyhow my apartment was owned by a bachelor and it looks as though he hardly used the oven so everything's still intact.
I'm in Australia and these numbers are in Celsius so I hope they work for you.
From top Right (starting at the 2 o'clock position) the four numbers going clockwise downwards are:
50
90
120
160
Then from the left side (starting at 7 o'clock position) going clockwise upwards:
200
230
250 - with dots arching above the 250
Hope this helps -
Jane
Jul 20, 2008 | Smeg SE399X/5 Stainless Steel Electric...
NEED A MANUAL FOR SA 999X CAN ANYONE HELP
try this site for service and user manuals. download pdf files.
http://www.user-manuals.com/
Jun 07, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Oven Not Working
your clock need a reset you need to turn it off and back on then hold in your manul button it looks like a hand and the + that should then be ready for you to cook
Nov 06, 2007 | Smeg SE399X/5 Stainless Steel Electric...
SA280X or SE280X?
go to google then click on shopping it is the best way to get items hope this helps.
Oct 17, 2007 | Smeg SE280X Stainless Steel Electric...
Smeg oven diplaying an "A" in display
I have had the same problem today - trying to change to day light saving time - can you help me too if you find out.
Sep 25, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
53 people viewed this question
Top Smeg Ovens Experts
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
