Question about Haier RWT350AW Washer
I have a Haier RWT350AW Washer it intermittingly doesn't spin or pump the water out. It works fine for a while and then it will not spin and pump out the water.
  • Randy Chaumont Feb 12, 2012
    I have just fixed the problem by blowing very hard into the drain hose once I drained most of the water out. I think this machine has a very sensitive pump and any little debris causes problems, however I'm wondering why it just started doing this after about a year and a half of use. My pump may be getting wore out anyway it's spinning and draining as I'm typing this update.
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: haier XQB40-F water will not pump out
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 26, 2010
BIKER T
  • 909 Answers
SOURCE: Haier HWc1460tve wont enter spin mode, water pump
check the sensor that normally is attached to the motor. If it has come loose, speed becomes erattic .If good, suggest brush check as well.
Posted on Sep 08, 2010
sonicboomele
  • 1557 Answers
SOURCE: I have a RWT350AW washer
if it is still washing then your not in real trouble in most cases the problem is to do with your water pump have hubby take the hoses of and see if any tubes are blocked if not see id=f the water pump is turning if not replace it then you should be right as water pumps often fail within months as to poor line production in some cases
Posted on Sep 29, 2010
  • 3 Answers
SOURCE: spin cycle doesn't work
bad drain pump or clogged drain line. some units have drain trap you can clean,if so you can clean it out yourself but will make a huge mess if you don't pinch close the drain hose between the tub and pump.
Posted on Nov 18, 2011
Wont spin ,belt isn't broking
is the motor operable ?? can you hear a wirrings sound when the machine in set to run?
Oct 17, 2015 | Haier RWT350AW Washer
Is it normal for liquid to be present in the top part of the drum?
Yes I have this type of washer and it has the water in a ring at the top of the drum to help balance it out during spin, not quite sure why but yes it should be there. The gargling sound you describe could also be the balancing hooks that attach the drum to the top of the washer which sometimes make strange noises but there fine.
Mar 10, 2013 | Haier RWT350AW Top Load Washer, White, 3.0...
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Washing machine does not empty
see the causes and use the common sense, God bless you.
Sep 19, 2012 | Ariston Technologies Washing Machines
I have a Haier RWT 350 washer and the tub sinks a few inches when filled with water. At least 3-4 inches! Can this be adjusted?
If you just purchased it, either have it sent back for a replacement, refund, or have the company send out a repairman to service it.
Apr 28, 2012 | Haier RWT350AW Washer
Spin cycle doesn't work
Nov 12, 2011 | Haier HLP21N Washer
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
I have a RWT350AW washer we bought a year ago. It started making some noise recently (like coins or marbles were in the washer) and now the rinse cycle stopped working. When you set to rinse, it humms...
Sep 29, 2010 | Haier Washing Machines
Haier RWT350AW Washer Logo
321 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
