Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
My lg tromm front load washer smells - LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
    Problem Solver:
  • 4 Answers
Try this, It's involved but it worked on my Kenmore HE4tDrain the machinePull the filter (have a sheet pan, wet vac and towels handy, there's a lot of water)Disconnect the drain boot from the pump and tubDisconnect the pump drain hose (waste)Disconnect the pump electricalWash everything (not pump motor) in a 25% bleach solutionReassemble.Put 1 gal boiling water, 1 gal hot water and 1/2 cup bleach in washer compartment. check for leaksWash entire compartment with the bleach water and spin the drum time to time for 15 minutesAdd TechnoFresh (which claims to loosen gunk) to the powdered soap dispenser, through a bunch of rag towels in and run the machine on the hottest cycle.This process works well until machine is stinky again (about 6 months depending on bleach usage)BTW "the leave door open trick" only helps the door gasket and does not address the constant reservoir of fermenting water in the bottom of the machine
Posted on Mar 02, 2012
  • 8 Answers
SOURCE: washer smells bad
A colleague had trouble with clothes smelling bad after washing them. Turned out it was due to using a low temperature wash all the time which allowed the build up of some nasty bacteria inside the machine. The manufacturer recommended he used a high temperature wash about once a week to keep it clear and it's been fine ever since. Just a high temperature (non-economy)wash, no need to add bleach.
Posted on Feb 26, 2008
SOURCE: Why won't the drum spin on my LG Tromm front load washer?
I had the same problem and it was a bad sensor assembly (#6501KW2002A). You can order
it from an online electronics store (www.mcminone.com). Cost is approx. $20.
I fixed it based on a thread from 2007:
See http://www.fixya.com/support/t159708-lg_washer_wm1832c
But, here's what I did:
1. Unplug the machine.
2. Take off the back plate that has 4 small screws.
3. Unscrew the big bolt in the middle.
4. Take off the hubcap looking part the bolt was securing.
5. Unclip the two sets of wires on the bottom of the circle you are looking at
(the set of wires to the right are connected to the sensor assembly you want to replace).
6. Unscrew the 6 smaller bolts to take off the circular piece that the sensor assembly is snapped to.
7. Mark with a pen where the sensor attaches so you know where to snap the new one.
8. Unclip the old sensor assembly and clip on the new one
9. Reassemble.
Posted on Feb 01, 2009
  • 4 Answers
SOURCE: lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Posted on Feb 23, 2009
Karthik316
  • 187 Answers
SOURCE: Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
Posted on May 22, 2009
  • 72 Answers
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Posted on Jun 19, 2009
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Lg tromm front load washer smells like burning and going to catch fire?
Unplug the washing machine from your electrical plug immediately, and do not run the washer at all. The longer you run the machine with smoke coming out of it, the more expensive will be the repairs. Not only that, but, you could have smoke damage, and cause yourself health problems by breathing in the toxic smoke. Your question can only be answered by physically inspecting the machine. Please have it serviced by a qualified service technician.
Nov 25, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM WM2496HSM MILDEW & MUST SMELL
I have had the same problem with mine. I have started taking the rubber seal off at least once a month to clean it with bleach and water. I would not recommend doing this unless you are handy with tools. You might try cleaning the seal with bleach and water while it remains on the machine. Careful to pull the inner sealing lip down to get to the "Slime" behind it. Good Luck
Jul 26, 2009 | LG WM-2277HW Front Load Washer
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM - awful smell while washer is running
Use the aafesh tablets as instructed, this will clear hoses that have developed some mold, also inspect drain at the wall, these get moldy and as machine runs, smell comes out of there as well.
Jan 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer a Tromm LG DLE377W leaves a bad smell in clothes after washed the smell is in the washer also smells sour
Sears has tablets for front load washers that work great. I use one every month and it has helped the stinky washer smell and the bad smell in the clean clothes. It is called Affresh and it works better than any of the cleaners you can buy in the grocery stores.
Aug 07, 2008 | LG Washing Machines
Mold Smell in front loading LG Tromm
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Good luck!
Aug 15, 2007 | LG WM0642H
Washing Machines Logo
290 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
