Question about Sewing Machines
How to Oil a Singer 6215C - Sewing Machines
5 Suggested Answers
bargainbox
  • 1388 Answers
SOURCE: how do you thread a singer 6215c sewing machine
Try this page for Threading and Bobbin Winding Diagrams for loads of machines.....even if your model is not specified, there's a good chance you will be able to work it out from similar machines. http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Posted on Sep 06, 2009
SOURCE: Singer 6215c, the bobin thread is catching on the
adjust the tiny screw
Posted on Apr 17, 2010
RichSew
  • 194 Answers
SOURCE: Singer sewing machine 6215c trouble
The problem is actually with the upper thread not having enough tension on it. Check your upper tension setting,,,it should be set about mid range of its adjustment (4,5 or 6). To see if the tension is functioning correctly thread the machine and raise the presser foot to its up position and pull thread thru the needle. It should pull easily, lower the presser foot down to the fabric and now the thread should become harder to pull. If there is no change in the pull,then either the thread is not in the tension correctly ot the tension is not working,
Doug
Posted on Aug 07, 2010
  • 5422 Answers
SOURCE: sewing Machine Manual Singer modle 6215C
Singer has the manual for the 6215 sewing machines on their site for sale or download. The direct link for the downloadable version is http://www.singerco.com/uploads/download/1316_6215.pdf . (Note: Singer does not use the letter suffix in their manuals; one manual will apply to the entire set of machines.)
I hope this helps.
Posted on Nov 05, 2011
My singer model is 6215c where can i get a free copy of instructions on how to set the bobber so it will move .and i need the needle size the needles that came withit keeps breaking.
Sounds like you need to have your machine professionally serviced. The needles that were included with your machine are not at fault--the machine needs to be adjusted to work properly.
Jul 08, 2017 | Singer Sewing Machines
Singer Manuel 6215c
Hi Deborah,
Search online for "user manual singer 6215c". You'll get a number of good hits, like: ManualsLib Makes it easy to find manuals online
Aug 12, 2015 | Singer Sewing Machines
Sewing Machine Manual Singer modle 6215C
I hope this helps.
Nov 04, 2011 | Singer Sewing Machines
How to repair a non-working foot peddle on a Singer 6215C
There are a few things you can do. If you are even a little technically savvy, UNPLUG the sewing machine then take a detailed look at the pedal cord from the pedal all the way to the machine and check for any damage, pinch points, etc. If it all looks good, you should be able to open the foot pedal to see inside. There should be a small limit switch that actuates when the foot pedal is depressed. Manually cycle the pedal to ensure that the pedal mechanism is making contact with the limit switch. Listen to the limit switch as it should click when you first engage the pedal. I cannot tell you exactly what you would have to do to replace the pedal but after you have exhausted what I have suggested, I would take it to a sew & vac shop and they can replace it for you. It should not be that expensive. You can call one or two shops and get quotes for replacing the pedal.
Nov 16, 2017 | Sewing Machines
How do you thread a singer 6215c sewing machine
Sep 05, 2009 | Sewing Machines
Sewing Machines Logo
189 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
