Question about Toshiba Tecra 8200 Notebook
Remove keyboad help
Would like to replace keyboard on tecra 8200 and can't find one last screw that seems to prevent removal
Thanx Bil
  • woodsvlfox Oct 24, 2008
    They don't have the manual for the tecra 8200
    Thanx Bill
  • 76 Answers
Some of the screws could be under keys (keybord keys) so if you havn't already..pry off the corner keys and the middle ones because thats where the screws are most likely to be. hope it helped =)
Posted on Oct 24, 2008
  • 108 Answers
Heres where you get your manual.
http://eu.computers.toshiba-europe.com/innovation/download_manuals.jsp
G'luck
Tecra 8200 password
use bios password code for reset bios password
Removing BIOS password on Toshiba Satellite Laptop - YouTube
The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS. To clear the CMOS, you must remove the battery from
Jun 18, 2014 | Toshiba Tecra 8200 PT820U-OFG8C801...
Toshiba Tecra A8-S8414 keyboard
I'm not sure if it is worth ..but you can get a new keyboard and change it ..To change the keyboard you have to remove teh hinges cover ..remove the screws and slide the keyboard one inch toward teh display ..and lift it up ..pay attention cause it has a ribbon attached on the motherboard and it is sensible
http://www.uspcparts.com/toshiba-tecra-a8s8414-keyboard-p-9904.html
Dec 22, 2011 | Toshiba Tecra A8-S8414 Notebook
How do i remove the key board
How to replace your Toshiba Tecra A2-S119 laptop keyboard ?
It's easy to break the flimsy keys on laptop. In order to better protect the Toshiba Tecra A2-S119 notebook keyboard, some friends, instead, use USB keyboard. But if you work outdoors, carrying a USB keyboard is not convenient. You still have to use the laptop keyboard. Once a laptop keyboard stops working, there is no option but to replace it. You can use these steps to replace the Toshiba Tecra A2-S119 keyboard.
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Tecra A2-S119 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Tecra A2-S119 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Tecra A2-S119 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
You have to remember that once you open up the Toshiba Tecra A2-S119 laptop computer for keyboard replacement, the warranty provided by the manufacturer stands void. We personally suggest that you do it on your own only if you are in a really desperate situation and there is no way you can get maintenance from the manufacturer. I hope this assists you. John
Jan 26, 2011 | Toshiba Tecra A2-S119 Notebook
Toshiba Tecra 8200 Laptop. when i type on the Keyboard some Characters do not work. A,D,E,I,K,L,P,R,S,T,U,W,X,Y,Z, and Back space do not appear on the Screen, all the rest are ok.
You probably need a new keyboard, but before ordering one go into the control panel, device manager and uninstall the keyboard.
Restart the computer.
If you get the same results, it's time for a new keyboard.
You can get a replacement from ebay for cheap and install it yourself. Usually it's 3-5 screws. very easy diy project.
Jun 17, 2009 | Toshiba Tecra 8200 Notebook
I would like to change the screen brightness on my Tecra 8200 laptop, but can't find HELP on how to do this. Is there a 'hotkey'? Where can I get hotkey descriptions, if they exist?
Normally there's a Function button (Fn) and you can use that in conjunction with the brightness buttons on the keyboard (looks like a sun on most)
Toshiba techra 9100 laptop
Probably you must open the case, much work and hard the first time...
situated under the keyboard, usually and perhaps an antenn-wire to somewhere--
Apr 11, 2009 | Toshiba Tecra 9100 Notebook
I need to change the keyboad on my acer 3680-2633 lap top and c
Laptops have screws that secure the keyboard, they are located on the bottom of the laptop directly under the keyboard. There maybe up to 4 screws holding the keyboard in place, remove these screws. The keyboard should be able to be lifted off to reveal connecting cables. There will be one or two ribbon cables that connect the keyboard to the motherboard, carefully detach these cables before you completely remove the keyboard.
Apr 02, 2009 | Acer Computers & Internet
I need to upgrade my DVD drive in my Toshiba Tecra A8 EZ 8313
you have to remove several parts that cover the dvd drive enclosure
the keyboard is one and the power and light display at the top of the keyboard is another section that you have to remove they pop out and are not hard to remove but be careful as they have little clips that hold them in once they are out you will be able to see what screws you need to remove.
Dec 14, 2008 | Toshiba Tecra A8-EZ8313 Notebook
Memory Install
You can usually find manuals for gaining access to the Ram slots, but I have opened up a Tecra before. Though not exactly the same model. you have to remove the plastic strip along the top of the keyboard (under the screen). Most of these pop up with SLIGHT pressure from a screwdriver but be careful, it may have one or more screws in the bottom of the laptop. Turn it over and look for any deep holes that might have screws that screw into the plastic strip on the top. Once you have the strip off, you can usually see easily how to remove the keyboard.
Nov 09, 2007 | Toshiba Tecra A6 Notebook
Toshiba Tecra 8200 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
