Question about Garden
Do you have a Briggs and Stratton Series 675 Engine Exploded view manual?
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
  • 3600 Answers
SOURCE: what type of oil for a 650 series briggs and
Use 30 Wt. motor oil, I prefer castrol but it is up to you, Mobil is also good and Texaco or Union 76, if you use it in different times of the year say in the winter you may want to go to a mid range of oil say 10/30 depending on the conditions you use it in at extreme cold and extreme hot temperatures you want a oil that makes it easy to start and still protects the engine with a good film of oil. If you have any more questions about this post here with a response.
Posted on Aug 29, 2009
  • 93 Answers
SOURCE: BRIGGS/STRATION 675 SERIES, 190CC SELF PROPELLED
Rust on the Flywheel and Magneto wire brush off., Pluged Fuel Filter or Bad Gas.
Posted on Sep 14, 2009
  • 17 Answers
SOURCE: craftsman 19.5 lawn tractor w/briggs & stratton keeps flooding
This could be a number or items from no spark to a faulty carburetor, a plugged up air filter, valves out of adjustment, poor gas, faulty spark plug.
First, see if your getting spark, how about taking the wire off a plug(s) and holding it about 1/8" or so away from the plug with some masking tape while you crank the engine. You should be able to see the spark jumping the gap, it helps if it is not too light outside. If you attempt to do this with your hands, you will get a spark jolt, it hurts, so use the tape and remember, the engine could start so proceed with caution.
If you have no spark there, then you ignition or magneto is faulty. This would be unlikely in the broader scope of things. You will likely get spark. Make sure the plug is clean, take it out and inspect. If it is covered in gunk well clean it. It will smell like raw gas but you already know that. Change the plug if in doubt.
Remove and clean and replace the air filter.
If you have spark, and a clean filter it is likely a carburetor problem, Depending on the carb, it could be the choke is faulty or, as per the below.
Depending on what model you have there is a float assembly in the carburetor that stops the fuel from flooding the carb and air intake. The gas tank is higher then the carb right, so if you dont have a mechanism for stopping the fuel from leaking out the hole that goes into the engine, it will all leak out right, as into the fresh air intake because its easier than going into the engine. So, there is a miniature float assembly, sort of like your bathroom toilet float to stop the water. Well there is a small wedge type needle that seats into a hole and it is attached to a float. As the gas rises in the bowl, it pushes up the float, sealing the gas into a chamber, as you use more gas, the float lowers and more gas goes in. So ,there is dirt jammed into the float bowl sealing needle, just a little, thats all it takes. So, shut off the gas somehow, hopefully you have a valve, or squeeze the rubber line, then undo the float chamber, its one nut on the bottom. Clean carefully. The needle, little spring and float assembly are delicate. Also, the needle could be worn from engine vibration, so it may need a new needle. It would help if you described the engine and carb though.
I posted that as a solution to another problem, but yours may also be the valves need adjusting. Depending on the amount of hours, say over 200, then the valves timing will likely be off a bit. Check the clearances with a feeler gauge, it is not as difficult as it seems. Check your Owners manual for the clearance at top dead center. TDC is when you take the plug out and watch the piston arrive at the top of the cylinder through the spark plug hole when you are turning the engine over (do this by hand, battery off. Make the adjustments with the valve cover off. Follow the instructions.
Hope some of this helps.
Posted on Sep 21, 2009
rwvanlue
  • 486 Answers
SOURCE: B & S 675 series engine timing question
The gear on the crankshaft is 'keyed' and has a dimple on one of the teeth. That dimple aligns with the dimple made into one of the teeth on the camshaft.
Posted on Nov 16, 2009
I see no vent holes om my 675 series briggs and stratton engine fuel cap
there are holes in it should be three or four. a rubber diaphram is covering it but they are there
Jun 09, 2016 | Briggs AND Stratton Intek Briggs &...
Briggs free repair manual
Check the compression of the motor
Aug 22, 2014 | Briggs & Stratton 675 Series 190 Cc...
Where do you spray carburetor cleaner in 675 series Briggs & stratton engine
Remove the air cleaner cover and the air filter then spray into the filter box.
Jul 14, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
How much oil does a 675 briggs & stratton 22" lawn mower take?
HI There try adding oil a bit at a time. They will only need minimum amount to lubricate the engine. Firstly put in about a quarter of a litre and check the dip stick after 10 mins.
Sep 23, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Craftsman Briggs and Stratton 675 series Mower fuse location
Is battery powered, did you try calling sears tech center for further info ?
i have found them to be very helpfull with mower problems.
Sep 12, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
What kind of oil do I use in my 675 series engine
4 stroke synthetic is most likely what you'd want to run if it's a new unit to yourself. Otherwise any 4 stroke motor oil is fine, you can find it at any retailer that sells small engine machinery.
Apr 21, 2010 | Briggs & Stratton Gas Pressure Washer...
Nov 15, 2009 | Briggs & Stratton Garden
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
