Question about Watches
Where can i find the tool to open the back of watches
How can I remove the back to change battery?
Yep.. unless you have a self winding one. They require a sharp jewelers tool to open.. Sometime you can do it yourself , but you chance ruining the watch with scratches. The jeweler puts the watch in a holder that protects the crown and steady the watch. He then takes a tool and inserts it in the seam of the watch back and pops the back open. After the battery is changed the back is pressed back into place by the devise that can put pressure on the back without risking cracking the crown.. Come on man it's only 8 bucks. Just remember once the back has been opened water proof can not be guaranteed anymore.
Jul 06, 2015 | Watches
How do you take the back of a wrist watch off so you can change the battery
The Proper way is with a "watch case wrench". They can be purchased for a few dollars on Amazon and E-bay. In most cases unless you are changing many watch batteries the best option is to call around to local jewelers and pawn shops and ask how much to replace a watch battery. In my town it ranges from $30 to as little as $5.99 battery included.
Dec 14, 2013 | Meco 2PCS Watch Case Back Opening Tool...
How do you open the back of a bulova watch
You need a special tool called a case opener, if you flip the watch over you should see 6 square slots on the outer rim, this means that the back case is screwed on and probably has a water proof seal, keep in mind there are different sizes. I suggest you check ebay for watch tools, you might find what you are looking for.
Dec 17, 2010 | Bulova Men's Watch
I have a fossil watch model fs4255 leather strap dress amber dial and I want to open back to remove old battery and replace with a new. i have a watch repair tool kit and replace all my own watch batteries...
mcdevito75 here, Even with the proper tools we still have to improvise at times, Instead of useing your case opener from your tool kit, use a steak knife or similar with a sharp edge inside that groove you"ve described, the cover will pry off.
Jul 04, 2010 | Fossil Strap Dress Amber Dial FS4255 Watch...
Watch battery size
mcdevito75 here, Best Bet For correct Battery Number is to call Kenneth Cole T 1-800-KenCole / 536-2653
Jul 01, 2010 | Kenneth Cole KC1346 Watch for Men
How do i open the back of a rolex watch
ROLEX watches can be opened using special case back press and dies. Without those tools there is no way to open ROLEX watch.
Feb 07, 2010 | Rolex Daytona 116520 Wrist Watch
How to Open a Gucci watch
Most watches are either screwed on and typically have a series of small notches around the circumference of the case back. A special tool is generally called for. Otherwise they are "snap back" . These are simply pressed on. To remove you can carefully use a regular knife in the absence of a "case knife". There is usually a small gap/groove/notch area to insert the balde and lift the back off.
Jul 25, 2009 | Watches
Phillipe Stark PH1079 watch - Can't get back off to replace bat
There is nothing wrong with your watch. The problem is in tools the jewellers are using for opening the watch.
Despite being under one roof, watchmaking and jewellery are completely different trades and are miles apart. Jewellers usually are equipped with very basic watch repair tools and the case openers are no exeption.
You have to find your nearest watch repair shop and ask for watchmaker, not jeweller. Any decent watchmaker will have the right tool to open your watch and replace the battery in a matter of minutes.
Do not forget to rate, please.
Jan 14, 2009 | Fossil Philippe Starck PH1035 Wrist Watch
How to take the back off of my Wenger swiss watch
There is a tool that you need that adjusts to the three holes or openings in the back of your watch and it just screws off. If you don't have access to the tool, simply take two push pins and CAREFULLY insert them into the openings and unscrew the back cover. Remember that it unscrews counter-clockwise.
Sep 26, 2008 | Swiss Army Wenger Sportedge Bracelet Watch
Canot get the back off my Indiglo watch to change the battery
There is different proccedure for different watch to take out the back. Following are some of the proccedure to open the backcover of the watches:-
1. Some plastic watch have four screw in the back, you just have to unscrew the screws and take out the back.
2. Some of the watch have press back technology, which enables the watch to be water resistant and thus, the backcover of these watches are pressed very tight. You just need a back opener, and at the back if this back opener has to placed between the case and backcover and has to be tilted and backcover can be opened.
(Backopener is a tool which is like thick & hard blade with sharp edges like knife but not very sharp; these edges can get easily between the gap of backcover and case. - this tool can be obtained from any watch tools store easily)
Jul 23, 2008 | Timex Watches
Watches Logo
21 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
