Question about Dryers
Missing parts for new light fixture SKU 394-542 162-042 UPC 718212054604 Chrome Fixture need the packet that contains the mounting bracket and chrome nut to hold fixture
  • 537 Answers
SOURCE: this Hampton Bay light fan fixture eats Light Bulbs
Read the manual to find out which size bulbs (base size and wattage) you need.
If you did use the right type of bulb and it lasted only 2 weeks, take them back to the store where you boght them for a refund.
Mike
Posted on Jan 17, 2008
  • 25 Answers
SOURCE: trying to find light kit for Model 56-ANTm Flemish Brass
check the kit at home depot, get name and phone number of manufacturer and call them to see if they can supply the glass that you want.
Posted on Jan 15, 2009
  • 16 Answers
SOURCE: Ceilng Fan light fixture-metal clasps have broken off
For Hampton Bay ceiling fan replacement parts!!!
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Posted on Jan 21, 2009
heatman101
  • 43501 Answers
SOURCE: In changing out an incandescent light bulb in a
Many times with very old wiring the wire can break inside the coating and not be visible. To check for sure what has happened you will need an electric tester. You will need to check for 120 volts acros the two wires with the switch on. If there is no power, then check at the switch. If there is power there then the wire is broken.
Replacement of the old wires in an old house is very difficult and you will probably want to hire a professional to do that.
Heatman101
Posted on Mar 01, 2010
  • 14 Answers
SOURCE: We have the hapmton bay
Contact "King of Fans" (kingoffans.com) in Ft. Lauderdale at 800-330-3267. They made or make Hampton Bay fans. I just ordered an arm for mine. Have your UPC number handy.
Posted on Feb 18, 2011
How can I mount a 9-inch flush mount light fixture to a recessed can that is also 9-inch square?
so you want to mount a light inside a recessed fixture? That won't pass code
Jul 02, 2017 | Cars & Trucks
How to install the alternator belt in a 2008 Suzuki xl-7?
which engine option, you do know belts are not same on all engines right? fact.
2.7L V6 or bigger? IDN.
same on all cars. (answering in generic form do to above)
loosen the tension-er.
take off old
put back new
and if not a spring tension-er,set proper tension
the fSM cover all this.
why not read the manual, RTM?
here is one example (get the book, RTM or see alldata.com)
2008 xl7 engine
Removal Procedure
Remove the air cleaner assembly. Refer to Air Cleaner Assembly Replacement .
Install the engine support fixture. Refer to Engine Support Fixture .
Remove the engine mount strut bracket. Refer to Engine Mount Strut Bracket Replacement - Right Side .
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle .
Remove the engine splash shield. Refer to Engine Splash Shield Replacement - Right Side .
Remove the right side engine mount bracket. Refer to Engine Mount Bracket Replacement - Right Side .
Lower the vehicle
Rotate the drive belt tensioner clockwise to release the drive belt tension.
Slide the drive belt off of the belt idler pulley (1).
Slowly release the drive belt tensioner.
Remove the drive belt from the accessory drive pulleys.
end remove
beg, install
Install the drive belt to the crankshaft pulley, the tensioner and the generator.
Rotate the drive belt tensioner clockwise.
Install the drive belt to the idler pulley (1).
NOTE
Important: Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
Raise the vehicle.
Install the right side engine mount bracket. Refer to Engine Mount Bracket Replacement - Right Side .
Install the engine splash shield. Refer to Engine Splash Shield Replacement - Right Side .
Lower the vehicle.
Install the engine mount strut bracket. Refer to Engine Mount Strut Bracket Replacement - Right Side .
Remove the engine support fixture. Refer to Engine Support Fixture .
Install the the air cleaner assembly. Refer to Air Cleaner Assembly Replacement .
end.
Sep 07, 2014 | 2008 Suzuki XL7
How do I uninstall a ceiling fan?
Turn the power off, to be safe i recommend turning it off at the breaker box, there should be a list on the onside of the panel door showing what switches operate what. or you can simply leave the wall switch that operates the fan in the off position if you're sure nobody will turn it on. If fan has a light remove the glass bowl over the bulbs, should be three screws it the top of the glass fixture, loosen them with your fingers, if they are to tighttry pushing up on the bowl from the bottom to relieve pressure off the finger screw. Remove light bulbs then unbolt each fan blade, once the blades are off remove the motor cover should be one small screw at top of the cover close to the ceiling, once the screw or screws are removed if the cover does not come down you may need toturn it using both hands, it only needs to turn a little bit and no need to be gentle. With the motor cover off the mounting bracket should be easy to spot. Some brackets only have one srcew on one end and a tad that slides into a slot on the upper bracket, by removing the one screw this will allow the motor assembly to swing down but still be attached to the bracket for support. Whith the motor hanging the wiring in the fixture box in the ceiling should be visible, pull the wires out of the box so ythat the wire nuts are accessible. there will bee three wires coming from the fan, one screwed directly to the box or bracket, loosen the screw with a screwdriver and pull the wire from the box, the other two wires attached to wires with wire nuts, one at a time remove the nuts by twisting them off with your fingers, pull the wires apart and twist the wire nut back onto the wires coming from the box in the ceiling, the fan should now be disconnected. romove the motor from the brack by turning it 90? and sliding the tab out of the slot in the upper bracket. remove the upper bracket piece from the fixture box. Now that you have done this installing a new light fixture should bea breeze for you.
the video shows a different easier type of fan removal. There are numerous types of fans and how they are mounted, i hope this helps you
Apr 09, 2014 | Dryers
Replacing a light fixture
This is much simpler than it sounds, but if you're a total novice you'll need to read it all.
First, make sure power to fixture is off. Best method is to locate circuit breaker or fuse that controls that fixture's power. At minimum shut off the wall switch to it if there is one.
Next, remove the old fixture. Usually there are two screws or decorative nuts holding the base cover (canopy) on. On ceiling pendant fixtures there may be a retaining ring holding up the canopy, unscrew this ring counterclockwise and the canopy will drop over the support chain, exposing the junction box where the wires are connected.
It is critical at this point that the power is off.
Modern house wiring and fixtures are connected with three wires.
Green or bare copper = ground (earth)
White or grey = neutral
Black, Red, Blue or any other solid color other than green, white or grey = power or hot wire (this is the wire that is controlled by a switch.
For simplicity I will call the three: Green, White and Black.
The next step requires you to carefully pull the wires out of the junction box and isolate the black, white and green wire connections from each other. Make sure the connectors (wire nuts) for each connection are accessible.
Warning: With old or over heated wiring, take extra care not to crack or disturb the insulation(wire covering) on any of the wires. If insulation is crumbling away exposing bare wire, stop and call an electrician! Do not turn the power back on until he has repaired those damaged wires, they could start a fire.
Isolate the connection between the black house wire and black fixture wire. Remove this wire nut. At this point I usually use an electrical tester to double check that the power is off by touching one side to the newly exposed black connection and any grounded metal part nearby.
(Note: some multiple switched (three way) circuits may use a white wire as a power wire. If the black fixture wire is connected to a white house wire, mark that white house wire with black electrical tape for future identification.)
Once you are positive there is no power at the fixture junction box remove the connectors from the white and green wires.
Detach the old fixture and it's mounting bracket.
Re-attach the new fixture using bracket and new connectors that are usually provided. Some brackets have a green ground screw. Wrap the bare ground wire clockwise around that screw and tighten it down leaving enough remaining ground wire to attach to the fixture ground.
If the wires to the new fixtures do not have a 1/2 inch of exposed bare wire at the ends (stripped) you must do so. I use a wire stripping tool but you can do it with a sharp knife being careful not to nick the metal wire.
Once the wire tips are stripped, hold the tips of each color pair together side by side, slip the wire nut over them and twist clockwise until snug. (White to white, black to black etc.)
Take care that the new wire nuts are secure at each connection. Do not over tighten them but insure that they are correctly attached by gently tugging on each wire. When completed the black and white connections should have no exposed bare wire showing.
The Green (bare copper) wire is there for safety and never carries current, hence exposed wire is not an issue on ground wires.
Assemble and attach the new fixture according to instructions in the box.
Pendant ceiling fixtures usually require additional assembly steps including adjusting chain height, looping wires through the chain and slipping retaining nut and canopy over chain prior to connecting. Always follow directions that come with the fixtures.
When in doubt, call a professional. Electricity is dangerous.
Apr 06, 2013 | Dryers
How do you clean rust from chrome light fixture
Clean with CLR then seal with car wax.
Mar 29, 2012 | Home
We have the hapmton bay 52 in cameron II plus in chrome and blue neon fan. Is there a different light fixture that can be attached instead the neon light fixture? The fan still works great, but we dont...
Feb 18, 2011 | Hampton Bay 52 In. Cameron II Plus in...
PRPH toilet paper holder. the fixture attached to the cabinet and supports the toilet paper holder has a broken post. The post goes into the toilet paper holder and supports it. During remodeling, I...
Without more specific information or a product number difficult to assit; here is the website for the manufacturer where you can search for more information or find a parts supplier near you.
http://www.robern.com/info/documentation.rbn
Trust this is helpful.
Oct 26, 2010 | Robern Prph Projects Toilet Paper Holder...
I have removed the light fixture on my hunter vista iron model 20538. It looks like there should be some sort of a cap that goes on the bottom of the switch fixture. do you know how I might locate one?
There is usually a blank cover that comes with tyhe fan when new, but when installing a light kit they usually get trashed ,, Try any bnuilding supply store that stocks the Hunter fans ,, bring the part for the light fixture so you can get the exact size and mounting screw araingement as the old kit .
Aug 15, 2009 | Hunter 20537 / 20538 The Vista Iron...
Tailights
hi there....theres always a mounting bracket that should exist....ok try placing the tailight, the correct side left/right onto its position and check the holes..... guess they dont match-up, If its the correct lights you bought and dont line-up to the holes on the vehicle, then you need that mounting bracket
May 17, 2008 | 1994 Toyota Pickup
Dryers Logo
Top Dryers Experts
