Question about HEWLETT-PACKARD Computers & Internet
Mouse pad cursor works but cannot click
I can navigate my cursor with the mouse pad, but can no longer tap to click .. what can I do?
My laptop pad is not working the cursor is moving but not clicking on anything ......now wot can i do ???
Posted on Feb 24, 2013
    Master:
  • 388 Answers
Touch pad drivers are missing or the plate is worn out cheapest option use an external mouse or replace the touch pad
Posted on Feb 12, 2012
SOURCE: how do you fix a frozen mouse for a acer aspire 5315-2077 laptop?
Fn F7 probably got pressed (turns on and off the trackpad. probably the dumbest thing to have a hotkey for)
Posted on Apr 23, 2009
  • 45 Answers
SOURCE: the mouse touch pad doesn't work
Fn+F9 is the hot key for enabling or disabling the touchpad
Posted on Aug 21, 2009
leecom72
  • 4806 Answers
SOURCE: my touch pad has stopped working
Hi there'
Hold down Fn and hit F7 to see if the touchpad reactivates.
Please post back if you have any more trouble.
Good luck and thanks for using FixYa!!
Posted on May 11, 2009
  • 55 Answers
SOURCE: keyboard and mouse inoperative
the best thing you can do is hook a wireless keyboard and mouse to your laptop. That's what i did and all is working well
Posted on Dec 16, 2007
  • 5 Answers
SOURCE: On the laptop the scroll thing on the laptop mouse pad wont work
Be sure to use the latest available Dell Drivers. Browse to this page and select the settings that apply for your system. Then, under Input Device Drivers, download and install the Dell Driver: Touchpad/Pointing Stick.
Since I do not know the Operating System you are working with (xp, vista, linux,...) I can not give you more specific help.
Posted on Jul 22, 2009
Toshiba laptop touch pad click not working
Its possible that "tapping" is off, as yo udont adentify a model or anything its hard to be accurate, normally goto mouse settings , find synaptic touchad tab and then check the detailed settings, you will find a tapping feature.
Feb 03, 2013 | Computers & Internet
Hp pavilion dv4 left buttom not work
left click is membran switch it was fix in motherboard
need to replace it .
for tapping control you can set as per your comfort from
start menu ---> setting ---> control panel ---->mouse
in "Buttons" tab select double click speed and check it right side yellow folder open and close when you tapping
Feb 01, 2010 | HP Pavilion dv4000 Notebook
Mouse pad's not working
HAVE YOU REDONE THE DRIVERS IF PRESS ON THE PANEL AT TOP OF PAD DOSE WORK IF IT IS A BORD PROB SAME AS HP NX6110
Jan 31, 2010 | HP Pavilion dv4000 Notebook
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Dec 30, 2009 | ASUS A6U Notebook
Mouse tap single tap not working I can navigate the cursor but not tap
This may due to faulty tap button. If the mouse is in warranty, ask the vendor to replace/repair the same.
Dec 15, 2009 | Logitech V220 Mouse
Mouse keeps shifting the cursor to a different place in document
On touchpads if you touch the pad twice in quick succession it acts as a click and the cursor will move to the mouse pointer location. In mouse settings disable "tapping"
Aug 31, 2009 | Acer Aspire 5720 Notebook
Jumping cursor
This is a really common problem thats not actually a problem.
Go to trackpad settings and make sure tap to click is off.
Most laptops allow you to tap the track pad to act as a mouse button, try it go to an icon tap the trackpad youll see that the icon highlights as if you are actually left clicking.
When your typing the trackpad senses your arm or wrist occasionaly and thinks your tapping the mouse, thus moving the cursor.
So go into trackpad settings and turn off tap to click.
Jan 19, 2009 | Acer Aspire 1690 Notebook
UNABLE TO DOUBLE CLICK USING THE TOUCH PAD
you can solved this problem by following these: 1. Find the icon of your pointing device in the taskbar (mine is synaptics pointing device) 2. point to the icon and right-click on it. 3. check if "Tap To Click" option is checked. 4. if not, then click on "tap to click" option so that it will be checked. 5. try now to double click using the touch pad...and you will be okey now.
Sep 04, 2008 | Dell Latitude C610 Notebook
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Toshiba laptop touchpad click not working
Ok so here goes.... I had the same problem:
Go to the 'start' button and then hit the 'control panel' option, then click 'mouse' then go to 'Device Settings' and then to the 'settings'. When you get to this screen it shows a list on lthe left hand side choose the 'tapping' option and then ok.
Hope it works for you...it did for me.
Feb 09, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
434 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
