Question about Garden
Diagram for a mahindra 4500 tractor
Changeing a mahindra 4500 fuel filter
4 Suggested Answers
panilling9
  • 284 Answers
SOURCE: craftsman ys 4500 lawn tractor change oil indicator won't go off
Being a reminder light it should reset itself after engine run hours increase from the programed reminder time
Posted on Jun 07, 2009
mowerman1857
  • 389 Answers
SOURCE: looking for wiring diagram for sears tractor
Go to www.searspartsdirect.com Enter your model number in the appropriate box, when the page loads, look on the left side of the page where it says "Browse sub-components" and click on "tractor-schematic" this will open to a total wiring diagram for you
Posted on Oct 22, 2009
wireguy212
  • 1627 Answers
SOURCE: i need a wiring diagram for a john deere 4500
What are you trying to repair?What on the tractor is not working?Copy right laws prevent me from posting the diagrams but i can help you with your problem,i have access to the diagrams you need so let me know what you need.
Posted on Jan 21, 2010
Mahindra 3505DI runs smooth under 2000RPM, above that it starts smoking and stuttering very badly. I have replaced the fuel filters with no change. Any ideas?
-Sounds like there is not a problem. How about
try clean the air filter it might change. Look like the air filter is clogged so there is not enough air ratio.
Good luck
Mai
Oct 18, 2017 | Mahindra Cars & Trucks
Mahindra 4540 tractor, check engine light flashing, 214 hours on tractor. I have changed all the filters. Tractor runs great but govenor does not work.
the light has come on to protect the engine from a failed governor operation
fix that or have a service technician carry out the repair
Aug 18, 2016 | Light Garden
I would like to see a diagram of the pully under the engine.
Rod, Check the attached links,manual,instruction and guides for Lawn tractor. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
917288320 CRAFTSMAN TRACTOR Manual Sears PartsDirect
craftsman dys 4500 belt diagram Google Search
How to Change Replace Main Transmission Drive Belt Craftsman Lawn Mower...
May 23, 2016 | Garden
What makes a mower lose fire?
need fuel, spark and air. Make sure air filter is clear. Best way to test this is leave it off while you try to start (or restart??). For spark, easiest way is to spray starter fluid in the carb. If it starts, you have a fuel problem. If you havent lately (or ever?), change the fuel filter.
Jun 19, 2014 | Craftsman YT 4500 54" Kohler 26 hp Gas...
Worked fine for an hour then died and will not start
fuel? if old,. change it completely
Check fuel filter.
otherwise a clogged needle valve
Ethanol eats rubber and causes it to clog the needle valve (or other) in the carburetor.
Best regards
Ck
Aug 18, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
How can I tell if my fuel filter needs to be replaced. My mower the ys 4500 quit running the other day so I figured it was the fuel filter or line but how can I tell if it is the problem
Hello. IF your spark plugs are good, and your air filter is clean, and your fuel tank is not close to empty, the next thing to check is the fuel line and the fuel filter. As a general rule, I change the fuel filter every 40 hours and the fuel line every 200 hours. J.
Jul 06, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
How do I drain gas from tank craftsman ys 4500?
disconnect fuel line from fuel filter, snake fuel line over to left side of engine. Remove gas cap and fuel will empty out of fuel tank.
May 15, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a DYT400 Craftsman mower. Fuel is not getting to the carburator.Could it be the fuel pump?
Most likely or look for a fuel filter in the lan to see if it is clogged. if you take the hose off to the car and crank the engne, fuel should come out. in not, trace the line back to the tank to find the filter if there is one.
Nov 20, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Looking for wiring diagram for sears tractor
Sep 07, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
605 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
