Reduced sound from one speaker
Hi. My very elderly amplifier has recently developed an issue where it's now outputting great sound from one speaker, but barely any from the other. Balance is set ok, and if i swap the speaker connections at the back of the amp, then the opposite speaker is affected, so i know the speakers themselves and the speaker wires are ok. Not knowing anything at all about it's internal workings, i was wondering if anyone could advise me if it would be worth taking to a repair shop? It's unlikely parts would still be available, but it did have great sound, and if possible I'd love to be able to get it fixed. Many thanks in advance...
  • Vivienne Boyd Feb 17, 2012
    Site not the easiest to use for a novice when it comes to answering posts, however I sincerely hope I have managed to pass on my grateful thanks to both contributors. Particularly joecoolvette, whose help and information was totally outstanding!! My first time on the site, but I will undoubtedly be back!! Thank you again!!
  • Computers & ... Master
  • 5,660 Answers
Only 30 years old? I thought you were referring to an OLD amplifier.
One that used vacuum tubes.
One side isn't playing?
1) Could be the Balance 'pot'. (Potentiometer )
http://interactiondesign.sva.edu/classes/physicalcomputing/files/potentiometer_diagram.jpg
http://interactiondesign.sva.edu/classes/physicalcomputing/files/potentiometer.jpg
The top link to the illustration, shows a basic schematic of the workings of the 'Pot'.
The bottom link to the photo, shows an example of the 'Pot'.
The object to the right that has three wires going to it.
Looking at the illustration note the circle in the middle, and the line issuing from it. This represents the movable sliding contact, that is connected to the stem.
The knob you turn is connected to the stem.
http://en.wikipedia.org/wiki/Potentiometer
The problem may be a $4 Potentiometer.
Easily replaceable by you if you have basic skills.
2) However the problem could be further. More than likely it's Electrolytic Capacitors that have broken down.
Electrolytic Capacitors have a chemical paste inside them.
Electrolytic Paste.
This paste breaks down over time. When it does it produces a gas. (Hydrogen Gas)
The gas expands inside the capacitor, and breaks seals.
When this transpires paste will ooze out of the capacitor, and the capacitor fails.
Electrolytic Capacitors are the weakest link in an electronic circuit. Designed to be. Engineers know that the capacitor will break down as time goes on, and use capacitors that are rated 2 times, as much as what is needed.
This way when the capacitor breaks down to 50 percent good, it is
still 100 percent good for the circuit it is in.
The Electrolytic Capacitors that are used are Radial Aluminum Electrolytic Capacitors. May, or may not have Axial Aluminum Electrolytic Capacitors.
(With the Radial design, both leads, Positive and Negative, come out of the same end. With the Axial design each lead comes out of an end,
http://en.wikipedia.org/wiki/File:Capacitors_electrolytic.jpg )
3) Transistors:
May be transistors in the final output stage for that side.
Could be a power transistor though. (MOSFET)
Little expensive.
If the shop determines it will be expensive to fix, HOLD onto the amplifier.
Could be blowing smoke in your eyes, and want the amp because it is a collectible.
Talk to older musicians about the amp.
Regards,
joecoolvette
(For example a Fender Twin Reverb amplifier. Amp from the '60's, and used vacuum tubes. The sound is great, and I would take it in a heartbeat over an amp with transistors.
Sears Silvertone amp's.
Worth bucks )
Posted on Feb 12, 2012
Testimonial: "Amplifier now working perfectly!! Turned out to be just the potentiometer, and thank you Joe for the links to the wiring diagrams. Didn't do it myself eventually,( was afraid of wrecking it completely) but a friend of mine with more knowledge than me sorted it from your links. Have saved the other information you provided for future reference, you're a star!!"
  • Vivienne Boyd Feb 13, 2012
    Wow! Such a comprehensive answer, thank you so much for taking the time to post both the info and the links. I've not looked at the workings of the amp yet as I thought it would be beyond any knowledge I have, however I will now certainly have a go at checking out the potentiometer. If this isn't the issue, I can hopefully pursue the other avenues you have suggested with the benefit of now having some degree of insight. Thank you so much again!!
  • joecoolvette
    joecoolvette Feb 13, 2012
    You're very kind, (Blush) Thank you for the kind words!
    (Not asking. Since you indicate you haven't visited FixYa very much, just would like you to know that all solutions may be rated. (Isn't like a certain website, Y.A. )
    If you get into the workings of your amplifier;
    1) Visual signs of Capacitor failure,
    http://www.capacitorlab.com/visible-fail...
    (Info is about capacitors on desktop computer motherboards, but the information crosses over when dealing with any Electrolytic Capacitor )
    2) One supplier of electronic parts, and I have linked the page to the Aluminum Electrolytic Capacitor section. (I can also guide you in obtaining the capacitors you may need, IF needed),
    http://www.mouser.com/Passive-Components...
    (Capacitors are a Passive Component)
    The two major suppliers are Japan, and Taiwan. The information needed however, is not always readily apparent. (Voltage and Microfarads) It is usually in a manufacturer's code on the side of the capacitor,
    http://www.hardwaresecrets.com/article/5...
    (Details both Japan, and Taiwan)
    A small capacitor replacement tutorial I like,
    http://www.youtube.com/watch?v=YCSNWi3UH...
    Master:
  • 388 Answers
Yes the transistors or on of them is either gone or about to its worth the repair should only be around TWENTY POUNDS
Testimonial: "Thank you so much for your help, it would certainly be worth fixing then if that's what it'll cost. Would the repair depend on obtaining original spare parts do you think? The amplifier is nearly 30 yrs old, so I would doubt if these would be available. Thanks again..."
  • Vivienne Boyd Feb 12, 2012
    "Thank you so much for your help, it would certainly be worth fixing then if that's what it'll cost. Would the repair depend on obtaining original spare parts do you think? The amplifier is nearly 30 yrs old, so I would doubt if these would be available. Thanks again... (My apologies for leaving this message in the wrong place earlier, not used this site before, hence my error)
Audio went out has a great picture but no sound
Make sure that your speakers on set are turned on. If they are and still no sound then you have developed a problem with the audio board and/or amplifier.
If you have audio outputs check to see if you can feed that output to an external amp. If the external amp works then the issue is with the internal amp of your tv. If external does not work either then the problem lies with the audio circuits that precede the amp of your tv..
Sep 04, 2015 | Mitsubishi Televison & Video
Im running my pc through amp but tweeters start to pop at hight volume .. is there a fault with amp or pc ??
It sounds like you are over driving the speakers. Recommend reducing PC audio output, as it is amplified for the computer speakers. Use the amplifier for volume - not the PC.
Mar 18, 2015 | Audio Players & Recorders
Protect mode?
You added speakers in parallel which reduced the effective impedance to to a value low enough that your Rockford Fosgate amplifier had to enter protect mode to prevent damage to its output stages.
Jan 22, 2014 | Car Audio & Video
Overload light on can't get any sound
here is your guide:
http://www.fixya.com/support/t13907270-sony_str_de925_stuck_in_protect_mode
Note : output transistors are embedded inside the Hybrid IC
on some models.
Aug 07, 2012 | Technics Audio Players & Recorders
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
Left speaker has developed a hum. Checked connections and all seems well. Sounds raspy like the speaker has blown.
This is likely due to a problem with the amplifier. You may have turned up the amp to the point of overdriving the speaker. The distortion at these high levels cause clipping and turn what was once crisp, clear sound into a muddied, garbled mess.
If the speaker is left connected to that source long enough, damage to the speaker and the amp may occur.
Without changing positions of the speakers: You can disconnect the affect Front or Rear L & R speakers and swap them (connect the L speaker to the R output of the amp and vice-versa). If the buzzing / hum "moves" to the other speaker, then the amplifier has the problem. If the buzzing / hum stays with the same speaker, the speaker has issues and is likely "blown".
Either way, it is probably not going to be a "cheap fix"
Jun 24, 2010 | Boston Acoustics VRS Micro Speaker
Amp volume drop with flabby bass sound.
1) can happen if the speaker is dying - voice coil defective or magnet needs recharging. happens sometimes with low quality speakers.
2) faulty pre-amp section can reduce overall gain resulting in lower output volume.
3) for old amps dry solders in pre-amp & power amp section can have the same effect.
4) faulty coupling and filter capacitors can severely effect frequency response too.
Mar 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Internal capacitors keep burning
youre overloading the output reduce to at least 4 ohms impedence speakers
Oct 31, 2008 | Power Acoustik A3000DB Car Audio Amplifier
I just bought a KDC MP-235 to put in a 95 camaro with bose amplified speakers. I ordered a amplifier intergration component to reduce the output of the 50 watt per channel head unit as to have better...
Yes, the Kenwood KDC MP-235 has two (2) line level outputs (RCA types red & white). However, these outputs internally passed through an electronic crossover/filter making them appropriate for subwoofer amps only.
If your unit is an MP-235CR, then the same outputs would be for the rear amp (not subs) and are full range (unfiltered).
If indeed your unit is an MP-235 and if I may make a suggestion, still connect the Kenwood to four (4) speakers. It would not be technically correct to leave the internal amps operating with no load (speakers) connected. Additionally, you would be getting 200 watts (4 X 50) more to your system (since it is already there).
If your Bose amp & speaker are subs, then no issue, however if the Bose is for a full range of speakers, then only the woofer part would be working efficiently.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 15, 2008 | Kenwood Car Audio & Video
No sound coming out
I often troubleshoot these issues via a stereo head set, modify the leads so you can "Touch" them onto the Speakers Output Terminals, connect the "Shields" together, thats "Earth" and the other Two, are Left & Right... with the Amp's volume turned to about 25% volume, connect up the Earth wires to the Chassis with a clip, under a srew etc, just make good contact... then touch the Left & right wires onto the output, ya should hear sound... if not most probably the Output device(s) may have gone faulty.
Aug 07, 2007 | Jl Audio E2150 Car Audio Amplifier
Computers & Internet Logo
351 people viewed this question
David Payne
David Payne
