Question about Garden
How do I adjust snowblower auger?
Quite often I press the auger lever to throw snow & it doesn't work. Sometimes I have to press & release the lever 4 or 5 times and then it will finally work. Is there an adjustment to fix this?
  • Joey S. Feb 12, 2012
    2010 Ariens Compact 24 snowblower. Model 920014 LE. I bought it used in Jan. 2010. When I try to engage the auger by pressing the handle lever, often times the auger doesn't work. I just re-try a few times and it will then work. Sometimes it works on the first try, but a lot of times
    I have to press and release the lever 4 or 5 times before it engages. So, I always get my snow blowing job done, but it's just annoying to have to keep trying to get the augers to work.
4 Suggested Answers
SOURCE: Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Posted on Jan 19, 2009
wireguy212
  • 1627 Answers
SOURCE: ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Posted on Feb 17, 2010
ToolBoxHero
  • 171 Answers
SOURCE: I have an Ariens 926LE
Hi, The blower spins at full speed? If it does the belt, pulley, and shaft are good. Look at the shaft from the fan to the gear box while it's running and that shaft should be turning at the speed of the fan.
If the blower spins at full speed and the auger doesn't the most likely problem is the worm gear transmission from the blower shaft to the auger shaft.
A good way to visually inspect this is: With the machine turned off and the spark plug wire unhooked go to the front and try to rotate the auger by hand. If the gear box is good you will only be able to move the auger less than an inch. If the box is bad you will be able to move the auger a lot farther. While you are there recheck your shear pins.
You can also remove the blower drive belt and have someone turn the pulley by hand while you watch the auger. Put resistance on the auger with your gloved hand. If the box is good the auger will move smoothly in you hand. If it is bad, it will ****, move roughly, or stop.
While the other person is turning the pulley and you have some resistance on the auger look closely at the shaft running from the gearbox back to the blower. On some models there is a connecting sleeve and the roll pin that connects the sleeve to the shaft and gearbox will break.
If the gearbox is bad, it will have to be replaced as a complete unit.
Was this helpful? If you have any other questions, please ask.
Posted on Jan 10, 2011
Testimonial: "Have not tried the trouble shooting steps yet. I does make sense to me and will try them when I get home. Hope it works. Getting a lot of snow."
Snowblower will not throw snow as far as before.
two things to do. One, get the carb service and have them check the governor.
Two, have the auger belt replaced.
Dec 27, 2012 | Garden
Auger on craftsman snowblower is very slow.how do i adjust idle
Not sure how long you have owned this machine but the auger does not turn fast. It 's job is to chop up the snow and push it back to the impeller. The impeller is the round plate in back of the augers that actually throws the snow out the chute. That turns fast. Check to be sure the shear pins are not broken. Shut the machine off. Wait for the augers to stop spinning and then try to turn the augers by hand. If they spin on the shaft then the shear pins are broken-replace them by using original equipment shear pins.
Dec 22, 2012 | Garden
Swisher 27" snowblower front impellers turn free
Hi Craig,
Most snowblowers incorporate "shear pins" between the motor and auger. A shear pin looks similar to a nut and bolt or pin that couples the drive to the auger - but it designed to break or shear off to prevent damage to the auger or motor in the event of a jam or overload. They look like these:
Only the shear pin recommended for your particular brand and model snowblower should be used. Under no circumstances should a regular bolt or other steel pin be used instead of a shear pin. Check your manual or consult with Swisher to determine the correct shear pin for your snow blower.
I hope this helps & good luck!
Dec 21, 2012 | Garden
Snow thrower not throwing snow far enough
Your belt is probably slipping Is your snowblower a single stage or dual stage?
If it is single stage, there are normally multiple holes that you can put the engagement cable into on the lever. If so, move the cable to a hole that is further away, so the lever pulls the cable further. If it's already in the furthest hole, it's time for a new belt.
If you have a dual stage blower, the adjustment is usually made at the idler pulley, found under the belt cover.
Dec 03, 2011 | Garden
Snowblower doesn't throw the snow very far, and every time I stop it, it takes a while for the auger to start turning fast enough to blow the snow. Feels like the torque isn't there. This is a Husqvarna...
The most common cause of this is the drive belt is worn.
If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
The belt closest to the blower assembly drives the auger/blower and the belt closest to the engine drives the transmission.
With the engine not running, have someone depress the drive lever and check the blower belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
You can get parts for you Craftsman and most Husqvarana, MTD made models through searspartsdirect.com. You can also get parts through jackssmallengines.com or your local dealer.
If you are unfamiliar with repairing machines take it to your local dealer. They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions to troubleshoot this problem farther. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Garden
Ariens snowblower impeller not throwing snow
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
How can I keep my 2 stage snowblower in high?
I will assume you are referring to the 2 stages in the front of the machine. The spiral auger rakes are the first stage, they are designed to collect the snow and feed it to the impeller. The impeller is the 2nd stage and is to throw the snow up the chute. The lower rakes in the front do nopt throw snow only collect it.
Jan 09, 2010 | Mtd Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
