Question about Garden
Motor running cutting head not moving - Garden
  • 2,239 Answers
There is either a problem with the gears in the gearbox at the end of the shaft, or the shaft has broken, remove the gearbox from the end of the tube and see if the shaft is rotating when running the engine, if not the shaft may have broken.
Posted on Feb 18, 2012
Intermittent motor head
Hi there, it's Jack at Dyson.
If your DC35's motorised cleaner head seems to work intermittently or cuts out when moved, this suggests that there could be a loose connection somewhere. We're keen to help you check for this, and our experts can talk you through some simple diagnostic checks to pinpoint the cause of the issue. If a replacement part is needed, we can also confirm whether or not your DC35 is still covered under its Dyson warranty.
When you have your DC35 fully charged and easily to hand, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Mar 19, 2015 | Dyson Vacuums
Ryobi line strimmer hedge cutter attachment won't cut even though the blades are moving can you give any idea what he problem might be?
grass,string or vines can get wound around the motors shaft, you will need to take off the spinning head to remove debris from motors shaft
Jul 25, 2014 | Ryobi Garden
Why doesn't the cutting head on Stihl F38 trimmer spin?
Maybe the cutter head has come loose from the shaft. make sure the head is engaged to the drive tube properly
Jul 09, 2014 | Stihl Garden
Cutting head will not drive
sounds like the drive cable inside the shaft is broken
Aug 09, 2012 | Garden
Put in replacement spool cutting great as usual went edge the head with spool of line wont turn went back to normal position spool will not spin to cut motor runs spool head not engaging how can I fix
pull the head completely off and make sure that the shaft is not broken, if not then line it back into the head slot and put back together and test it out, Tim
May 29, 2011 | Black & Decker 14" Grass Hog Xp...
Canister vac - the motor on the cleaning head cuts out while vacuuming. does it as you draw back the head while cleaning , goes off momentarily and ten when pushed forward engages the motor again. this...
Unplug the vacuum then pull the bottom off the head and clean the brush. Check for debris on the brush and around the ends of the brush. Insure the brush moves freely. Check the motor by turning it by hand to see if it rotates freely. Check the belt to sdee if it is tight. When belts get old the will sometimes stretch and won't work properly. Hope this helps.
Jan 03, 2011 | Vacuums
High trottle is not working it's full power
griffofarm
  • Rank: Master
  • Rating: 79%, 49 Votes
They have two separate screws? one for fast, one for slow.for the slow setting, first start the saw then screw until motor runs smooth without chain moving....if to slow the motor will stop....for fast screw....rev motor flat out then adjust so it screams its head off so to speak....it will need all its power for cutting wood so don't think you are opening it up to much as its designed for it.
Nov 06, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What are the high and low carburetor settings on a poulan 3416 chainsaw?
are they two separate screws? one for fast, one for slow.for the slow setting, first start the saw then screw until motor runs smooth without chain moving....if to slow the motor will stop....for fast screw....rev motor flat out then adjust so it screams its head off so to speak....it will need all its power for cutting wood so don't think you are opening it up to much as its designed for it.
Jul 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Craftsman gas weedeater. Engine runs, but the head won't run
Cut 1/8" off outer (aluminum) shaft. Lube inner shaft with STP or heavy gear lube this will re-engage worn square drive .Replacing inner cable is un-necessary this is normal wear. Sears Master Tech BB
May 26, 2009 | Craftsman 25cc Gas Line Trimmer
Maytag Model# LAT 8616AAE. The timer seems to work(runs/moves), but certain cycles are missed/bypassed.
sounds like the motor could be cutting out on overload possibly
motor has built in overload
check this first
if cutting out possible faulty bearings in motor
replace motor
Mar 07, 2008 | Washing Machines
Garden Logo
241 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
