Question about Toshiba Computers & Internet
Keyboard ribbon connector on the motherboard
Need the retainer cable lock clip for the keyboard connection ribbon to the ribbon in to the motherboard connection
    Problem Solver:
  • 13 Answers
Cut a piece of sturdy clear plastic packaging material (like memory packaging, etc.) or extra ribbon cable - cut it the width of your ribbon cable and long enough to handle.
Insert your ribbon cable into the socket and then insert the clear plastic or extra ribbon cable you cut to size into the socket above the ribbon cable.
This usually will hold the ribbon cable in the socket snuggly with enough pressure not to move and make a good contact for proper operation.
If you want cut and add a small piece of high temperature electrical tape to the socket, insert and cable. I do not recommend scotch tape as it becomes googey at high tempersture.
Posted on Jun 19, 2014
  • 48 Answers
SOURCE: Keyboard replacement problem
in these kind of problems, especially if its a laptop, you should send back your laptop to the manufacturer for them to fix it coz the parts are not really sold in stores and they are the only guys providing these computer parts.. and you don't have to worry about the installation coz they willd do it for you..
Posted on Jan 20, 2008
  • 120 Answers
SOURCE: Toshiba M35X S161 Ribbon Connector
You can buy another one cheap at a computer retailer, maybe. Search eBay too. There are various good things available there.
Posted on Nov 30, 2008
  • 32 Answers
SOURCE: keyboard connector on motherboard dell inspiron2200
personnally I would not try this. If this is the only laptop you have. now if its just a machine you tinker with you can try it. but for functunality I would leave the keyboard intact incase you ever want to use the portability of the laptop.
Posted on Apr 16, 2009
RescueTechLA
  • 2653 Answers
SOURCE: connector for keyboard on a acer travelmate 4220
I just call it the annoying super thin and fragile piece of plastic that holds the cable in place.
You CAN'T get it anywhere. The ONLY thing you can do is try to find another dead motherboard on eBay for parts.
When you do get a board be very VERY careful when you try to remove it from the dead board. If you even look at it the wrong way, it will break ;)
Best of luck!
--RescueTechLA
Posted on May 12, 2009
leecom72
  • 4806 Answers
SOURCE: How to connect ribbon cable from the touchpad to motherboard?
Hi Rob.
The little black plastic clip either pulls up or forward depending on the connection.
If the tab pulls up, slot the ribbon cable in as far as it will go and push the tab down to lock the cable in place.
If the tab pulls forward, again pop the cable in and push it back to lock it into place.
Ge gentle with the cable and the tab as they can be broken easily.
Good luck
Posted on Jun 10, 2009
Keyboard malfunction
OK, if an external keyboard wortks you have diagnised a faulty laptop one.
Search on google for your make model and get a replacement that is the same as your old one.
Replacing the keyboard is straight forward. Usually you need a very thin flat head screwdriver, look at the top of the keyboard where it joins the main laptop and you should see 3 or 4 small clips. Push the scredriver onto the clips and gently pull the keyboard up, repeat this until all the clips on the top and at the sides are loose and the keyboard is free. Sometimes there is a retaining screw which you can get to from underneath the laptop which will need to be removed. When you lift the keyboard up you will be able to see the ribbon cable connected via the keyboard connector. There is a grey clip that you open to remove the ribbon from the laptop. To install the keyboard just reverse the steps.
Always remember to remove the battery beforehand.
Hope this helps
Leon
Feb 09, 2013 | Computers & Internet
Remove ribbon cable
1) Don't know of any daughterboard Donald.
( A Daughterboard connects to the Motherboard, as an extension of the motherboard. Components plug into the daughterboard as they would the motherboard )
http://www.ebay.com/itm/Asus-Eee-PC-1001PXB-Motherboard-60-0A2BMB8000-A05-with-CPU-AS-IS-/170900271610?pt=Motherboards&hash=item27ca7331fa
That is a USB/ Audio/ Ethernet board,
http://www.ebay.com/itm/Asus-Eee-PC-1001PX-USB-Audio-Board-69NA2BB11B01-Ethernet-/280836767618
2) The cables are FFC. Flat Flex Cable,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
The connector/s on the motherboard are a style of ZIF connector.
ZERO INSERTION FORCE.
The bottom of the rectangular connector is the BODY.
The top of the connector is the Locking Bar.
The Locking Bar wedges the Flat Flex Cable in place.
I HOPE you unlocked the Keyboard's Flat Flex Cable, BEFORE pulling on the cable!
The white tabs of the Locking Bar are just barely visible on each side, of that Keyboard FFC.
They are eased up with the thumbnails.
The Locking Bar DOES NOT COME OFF of the Body, or one of them is broken. If so, I hear the motherboard will skip off of water, REAL GOOD!
Or can be used for a one-way Frisbee.
The FFC's that go over the Harddrive, have a different style of ZIF connector, on the USB board.
The Black rectangular tab Locking Bar, flips up. Break the hinge pins, or the Locking Bar hinge areas, and use the motherboard for a Frisbee.
http://www.insidemylaptop.com/disassemble-asus-eee-pc-1015px-netbook/
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 13, 2012 | ASUS Eee PC Netbook
M200 keyboard removal
Most laptops are secured with screws from the bottom of the laptop. These screws maybe marked with a tiny keyboard symbol next to the screw.
When the screws are removed there is a cable on the keyboard that is attached to the motherboard. There maybe a connector on the end the cable, in this case carefully pull the connector by the tab to release the connector.
OR
The ribbon cable maybe locked to a connector on the motherboard, in this case slide the locking bar away from the connector to release the ribbon cable.
Mar 06, 2012 | Computers & Internet
Replace a keyboard
Most laptop keyboard are secured by screws on the bottom of the laptop. The screws that fix the keyboard may have a tiny heyboard symbol against the screw.
When you remove the keyboard screws you can then lift the keyboard off the laptop. The keyboard is connected to the motherboard via a flat ribbon cable, it may have a connector on the cable or a locking clip on the motherboard. Release this ribbom cable from the motherboard, don't pull on this cable or you may damage the ribbon cable.
Keyboard replacement, LCD screens for mobile phones, Ipodsand computer equipment are available from this WEB site.http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards.
Mar 02, 2012 | Gateway NV7802U Notebook
Some of my keys do not work on my acer 5517 computer
I suggest removing the keyboard and using a toothbrush on the contact point of the Ribbon cable where the keyboard's Ribbon cable connects to the motherboard, because sometimes they can oxidize. So, removing the keyboard and cleaning the Ribbon cable contacts has been known to resolve this type of problem, otherwise a new laptop keyboard might be in order.
However, to get the keyboard removed will entail some steps: First, the keyboard's retaining screws are covered up by a bezel. You can remove this bezel with a flat-head screwdriver by gently prying underneath it and lifting up. This bezel is located just above the keyboard and below the laptop's display screen.
Once the keyboard bezel has been removed, there should be two retaining screws that you can now see to remove it.
After removing the retaining screws, carefully lift up the keyboard because it is still attached to the motherboard via its Ribbon cable.
Before you remove the keyboard, you will have to UNLOCK the Ribbon cable connector and then carefully release the Ribbon cable - by moving the black tab up - about 1 to 2 millimeters. You should be able to move the UNLOCK tab with your fingernails. Also do not separate the Tab from the connector because it has to stay attached to the connector.
If you break the keyboard connector, you will have to replace the entire motherboard, so be extra careful and release the cable and remove the keyboard.
Removing the keyboard will give you the freedom to clean it in case there is any build-up or debris underneath its keys. Alternatively, you should now have a pretty good idea of how to replace the entire keyboard should that become necessary.
Jul 19, 2011 | Computers & Internet
My keyboard sucks
You will need to replace the keyboard.
You can buy one here and install it yourself with a srewdriver.
http://www.amazon.com/Keyboard-Asus-EEEPC-EEE-Black/dp/B0032GVEDG
Power down the 901 and remove the battery pack.
There are 3 retainers along the top edge of the keyboard near the F1, F6 and F12 keys. Slide a thin blade or screwdriver between the case and the keyboard frame next to a retainer and lever the frame over the retainer. Repeating this for the remaining 2 retainers will free the top edge of the keyboard. Lift the top edge of keyboard and slide it towards the display to release the 2 catches holding the bottom edge keyboard in place.
Carefully move the keyboard to reveal the connector on the motherboard for the keyboard's flexi cable. Use a small screwdriver to release the black retaining clip on the connector by sliding one end of the clip at a time away from the connector a few mm. The flexi cable should easily slide free allowing you to remove the keyboard completely.
Reverse the procedure to replace the keyboard.
Hope this helps!
Jul 24, 2010 | ASUS Eee PC 900 Notebook
How do I remove the keyboard from a Advent 7109B laptop, in particular the ribbon cable.
The ribbon cable is connected to the motherboard by either of these two methods.
The ribbon cable has a connector attached to the end of the cable and it fits into a socket on the motherboard.
OR
The ribbon cable just slots into a connector on the motherboard. To release the ribbon cable lift the locking bar up on the motherboard connector and the ribbon cable will be released and slip out easily.
To insert the cable back into the connector, lift the locking bar up, insert the ribbon cable into the connector as far as it can go and push the locking bar down to lock the ribbon cable onto the connector.
Mar 30, 2010 | Computers & Internet
Nonfunctioning keyboard M6750 Gateway Laptop
That small retaining clip is what holds tension to the keyboard cable where it fits in the slot on the motherboard.
If you have the type of retaining clip that slides down into the slot to hold the cable in place then what you can do is very carefully put the cable back in the slot, then take the retaining clip and lay it on the cable, then try to slide the clip down into the slot with the cable, this will lock the cable in place.... Note, in this type of connector, the cable sometimes goes above the locking clip. if it does not go too easy, then it may be backwards, flip it over and try it again. When the cable is reseated, cover the connection with electrical tape to hold it fast. If the retaining clip is the flip up lever type, then you will have to try and look at it under a magnifyer and try to slip the ends of the retaining clip back into the sides of the slot where they lock in place. If these repairs cannot be done to where you recover functionality, then the motherboard has to be replaced in order to fix it...that keyboard connector is soldered to the motherboard.
Jan 12, 2010 | Gateway Laptop Keyboard for MX6930,...
How do I remove the keyboard on a Samsung R610 laptop. I have been able to remove the keyboard, but can't seem to unclip the cable that connects the keyboard to the motherboard. Is there some special...
The keyboard connector come in two types.
A plastic connector and usually has a plastic tab that you pull to lift the connector off, DO NOT PULL on the ribbon cable.
The other type is, a ribbon cable that is inserted into a plastic socket on the motherboard. To release the ribbon cable, lift up the plastic catch on both ends of the to release the ribbon cable. When you want to insert the ribbon cable, make sure the catch is in the up position before you insert the ribbon cable, then insert the ribbon cable and the push the ends of the plastic catch down to lock in the ribbon cable.
Aug 04, 2009 | Samsung R610-64G Laptop
I need to frequently clean the inside of my Acer 5610-4534 laptop...I have never disassembled one before; can you help me to get it open?
Insert a small flathead screwdriver under the keyboard bezel and carefully lift it up. Continue releasing plastic latches and removing the keyboard bezel with your fingers
Be careful, on some models the bezel might be connected to the motherboard as it shown on the picture above. If you accidentally pulled the cable, connect it back. It is not necessary to disconnect the keyboard bezel from the motherboard in order to remove and replace the keyboard, just put it aside so you can access the keyboard screws.
Remove three (or more) screws from the top of the keyboard. Carefully lift up the keyboard from the laptop case
The keyboard connects to the motherboard via a flat ribbon cable. Before you pull the cable from the connector, you’ll have to unlock the connector.
The image above illustrates how to unlock the keyboard connector. Carefully move the connector lock 2-3 millimeters up and after that pull the keyboard cable. To install the keyboard, follow the above mentioned steps in the reverse order.
FixYa !
Az.
Sep 17, 2008 | Computers & Internet
Computers & Internet Logo
193 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
