Question about Samsung HCJ552W 55" Rear Projection Television
MITSUBISHI rear projection
The tv does not transfer different inputs stuck on a & b does not recognize dvd player or other inputs
    President:
  • 3,130 Answers
What is the TV you have two differant brands /makes?and I dont know what that symbal by the b is?
Posted on Aug 09, 2006
TV will not respond to/recognize remote. I have
Check On the Menu Setup for On/Off Remote utility Maybe your Remote signal is off on the TV Set...
Sep 22, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
How do I change my remote for TV to Input Video 1?
There should be a button on your remote denoting "Input." If you connect the DVD player to the TV on "video input 1" then push the input button on the remote or TV itself until the DVD appears on your TV (which will be Video 1). Some TVs must have the component (in your case) the "DVD" player connected to the TV before the TV will recognize it. Make sure the DVD is powered up and then push the input button until the DVD player appears on the TV. Depending on your TV inputs, there may be multiple inputs like, Video, Component, DVI, or HDMI. The above are listed in the respective order of "quality." HDMI being the best. Whatever input you hook the DVD player up to on the TV will be the "input" you will look for when pressing the input button. Hope this helps.
Oct 26, 2009 | Mitsubishi WS-48515 48" Rear Projection...
How do i change from 480i to 1080i on my mitsubishi ws55315
You can't. Depending on what the output device is sending and what input you are using ion the back, it chooses for you.
ie - if you have a DVD player sending out 480 the TV will only allow different versions of 480.
Oct 21, 2009 | Mitsubishi WS-55315 55" Rear Projection...
Don't know which input the matches which device icon on screen
if you look on the back , the inputs are labled, then go into the tv menue and go under device lable and match the input it is plugged into, to the dvd icon
Jan 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a mitsubsihi ws-65907 and hooed up a sony blue-ray dvd player, I can only get a 480i resolution, is there a way to change it to 1080i?
Make sure the cables from the blue ray player are hooked up to the right 1080 high def input jacks on the back of the TV. There is two different sections, one for regular 480 inputs and another for the 1080i....
Dec 26, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Random flashing streaks on screen
Check multiple inputs and multiple sources. Check your dvd player; does it happen there? If not, you are probably right to suspect the cable box.
When you are checking multiple inputs, you want to make sure that if your cable box uses component or HDMI, that you check your DVD player on the same style input.
The reason for this is that your electrical chassis treats the analog (composite, s-video) inputs different from the HD and digital inputs (component, DVI, HDMI).
If you try your DVD player and cable box on the same input and experience the same probelm, you probably need to have the electrical chassis rebuilt in order to fix a problem on the tv's FMT board.
Cost: $800+
Wait time: 4-8 weeks.
Sep 23, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WS-65713 picture cuts on and off
same damn problem. will be fine for two weeks, and then cut on off constantly for a day. random times
Jun 16, 2008 | Mitsubishi WS-65713 65" Rear Projection...
High Def.
If you are using the component inputs it will select 1080i automatically IF that is what it is being sent. Make sure your device (cable/satellite receiver) is set to 1080i. The TV recognizes 480i, 480p(progressive scan DVD player) and 1080i. It DOES NOT recognize 720p. Since it has no HDMI or DVI input it can't do HD DVD or "upconvert" DVD but it does very nicely with 480p/progressive scan.
Dec 24, 2007 | Mitsubishi WS-65311 65" Rear Projection...
Samsung HCJ552W 55" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
