Question about Philips DVP642 DVD Player
Philps DVD player always says No disc
When I put a disc in I can hear it spin, then it begins to click twice (like something isn't connecting or catching) and then it tells me 'no disc'. Do you have any idea what this might be and if it can be fixed and is worth it to have it done. It was not an expensive player (90$) but I hate it when something doesn't work and if it can be repaired I would like to do so. We do use it frequently.
Thanks for your time and attention.
  • Anonymous Oct 29, 2008
    always show "no disk" either copy wright or copy
  • getsillayyy Nov 30, 2008
    the player doesn't work it just says loading for a long time and says no disk
  • 88 Answers
Mostly laser unit get defective in same model
1.check any dust meterial inside of spindle motor-or replce with new one
2..check&replce flex foil conector cable
3.check&replce flash ram on mpeg pcb
Posted on Nov 14, 2008
    Brigadier General:
  • 6,966 Answers
On the surface, there could possibly be two (2) issues:
  • dirty/defective laser eye;
  • stuck up slider/carriage.
It could initially be tried to clean the lens with the use of a CD cleaner (similar to those used for PC CD ROMs. Otherwise, the unit will have to be opened up flor a look & see, manual cleaning. Re-application of light lubricant with particular attention to the slider rail/lens carriage.
Should the cleaning be not corrective, then repairs would necessitate replacement of some components. At this point, you may have to reconsider your options as cost of repair and downtime may no longer justify service.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 24, 2008
My philps Dvd player won't work correctly
From the description the pladder motor is bad, " disc spins on" or it is missing the 5 volts that drives the motor. The laser pickup that pops up and down appears to be working fine.
Apr 13, 2012 | Philips PET741 Portable DVD Player
Tip
I have a Philips portable DVD player (model PET702/37) and my child dropped it...
The most common mechanical problems that can prevent a dvd player from playing or reading the discs are the following:
1. The spindle motor not functioning properly (this is by far the most common, if the spindle motor is not spinning the discs then the optical lens can not read them). For the most part it is an cheap part to replace averaging around 25-35 dollars if you can replace it yourself. If you do not know how and have to take it to a repair shop expect to pay 50-75 dollars in labor depending on the area you live in. The best thing is to do some comparison shopping and call the different repair shops and get estimates. The key is to listen closely when you insert the disk into the player, you should be able to hear it spin up. If you hear nothing then that is most likely the problem.
2. The tray could be out of alignment. This is another easy and cheap fix if you have the proper tools. This could happen if you drop or pull/push to hard on the tray (which you should not really do anyway, but always use the open and close button). This is an example picture of the drive assembly with the tray open.
3. The small gears are plastic and often break, this will cause the players other parts to not move and function properly. They are difficult to reach, but inexpensive to replace. It is always recommended that you always order any part from the manufacturer of the device. A visual inspection is usually required to determine if the small teeth have been broken, which requires for the most part taking out the carriage assembly.
4. The small belt drives either break or come off. Again, this will cause the other mechanical parts not to function. They are difficult to put back on as well, so you may need an extra pair of hands if you have not done this before. On average you will usually have 2-3 of them inside your player.
5. The Optical reader has malfunctioned. This is the most expensive thing to replace, so you might consider purchasing another player depending on how much you want to spend and the original cost of the device, unless you can find a great deal on the part you need. You can check to see if the laser is firing with a visual inspection (DO NOT LOOK DIRECTLY INTO THE LASER) put in a disc with the case off and you should see the glow of the laser hitting the disc. You can also see the spindle/spindle motor.
Picture of the optical reading assembly dismantled:
6. The tray also has a drive motor which can fail and cause the cd tray not to open and it also has a track that it rides on (located in the drive assembly). Check these two components if you are having problems with your tray not opening and closing properly or stops working completely. Sometimes, the tray will open and then immediately close on it's own. This is usually caused by the track being dirty or some type of debris is lodged in the track. Cleaning the inside of the player with a can of compressed air will help remove dust and dirt. Blowing out the inside of the device once a month is a good preventative maintenance measure.
CAUTION: When working with any electrical device, you should always ensure safety first. Make sure that the device is turned off and unplugged from any power source. This does not completely prevent electrical shocks because Capacitors will hold an electrical charge for some time even if the device is turned off and unplugged.
The following are example pictures of what Capacitors look like:
on Oct 06, 2008 | Philips DVP5140 DVD Player
When I put in any DVD Disc, you can hear the disc spin. I opened the unit and put a disc in and could see it spin and you can see the laser light come on to try and read the disc. After about 10 sec or...
Is this a blueray player? If it is, the disc you put in probably isn't formatted to the blueray. If it is a standard dvd player there is probably something wrong with the player. You have two options. One, to take it in for service or two, to get another dvd player. If you have another dvd player in your home, try the disc you can't play from the one player and put it into the working player. If that works, then something is wrong with the dvd player you are having issues with.
Apr 03, 2011 | Televison & Video
I have a Polaroid pdm-08228bd that whenever we put
when you open the cover for the DVD you will see the laser ..its a small lens like device mounted on a spring like assembly .. you can manually clean that laser with a soft paper towell soaked in eyeglass lens cleaning solution .. dont spray the solution on the laser directly .. make sure the spindle spins freely in the center where the disk mounts ... when you close the lid and turn power on you should be able to hear the disk spin .. if you can hear it spin and hear some clicking but still wont play then you likely have a worn out laser .. unfortunately the cost of installing a new laser is often greater than the cost of a new DVD player ...
here are a few models that might be worth looking at ..
http://www.consumersearch.com/portable-dvd-players?gclid=CITHuImPjaICFchD5godvmnzUw&ef_id=1953:3:s_241d3be5bdd1ae954a703c1c03b3e8bb_3674119072:TAxys0NIYWYAAGzz04MAAATA:20100607041651
Jun 07, 2010 | Polaroid PDM-0723 Portable DVD Player
Audiovox D1998 Portable DVD Player will not load DVD
you need to clean the disc and make sure it fits in wright if that dose not work try another disc.
Sep 15, 2009 | Audiovox D1917
No matter what disc I put in it wont play and Bad Disc comes up on t.v. I know the movie discs are good ones.
Hello marciafoxmar,
If you know for a fact that the discs you are putting in, then there is obviously something wrong with the DVD player. When you put a DVD in your player, can you hear it spinning the disc at all? If your DVD is not even spinning the disk, I'm afraid your DVD player might be toast. If it does spin your discs, try a lens cleaning disc (available at pretty much any home electronics store or large chain store that sells home electronics). If that does not help, let us know and also let us know if you would be comfortable opening your DVD player.
Mar 02, 2009 | GoVideo DV2150 DVD Player/VCR
New DVD player. It spins then says No Disc
Dear who ever, I did not fix the problem nor will I now bother,
I am taking it back and will get my money back.
I tried the calling the number twice. I was in the queue as caller 11 twice!
It hung up on me when I got to caller 2. The second time it said they were
only open 8 am to 5 pm or something and it was 1 pm on a weekday !!!
The web site was not clear and all I have gotten now was 2 emails from you all with nothing to say!
Dec 30, 2008 | Memorex Progressive Scan DVD Player...
Cyberhome 320 wont load discs
This dvd's fails because a dry capacitors on the alimentation source you need to send to a repair service center.
May 13, 2008 | Cyberhome CH-DVD 300 DVD Player
It wont spin
the motor for your dvd player needs to be changed take it to a qualified tech
Mar 04, 2007 | Coby EF1410401 Portable DVD Player with...
Philips DVP642 DVD Player Logo
169 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
