Question about Denon Audio Players & Recorders
My denon DRA 297 shutdown inmediatily when i turn on it. the volume is low (0)
4 Suggested Answers
SOURCE: looking for Denon dra 1025r Service &/or user manual
I have a Denon Dra-1025R operating instruction book,if this what you need and I can offer some info let me know
Posted on Sep 21, 2009
techman007
  • 1112 Answers
SOURCE: Denon DRA - 297 Sound doesn't
Hi:
This may be due to a faulty DSP Board. Called the Digital Sound Processor board, check the solder connections on this board first, especially the connections it makes to the Main Amplifier board assembly.
Posted on Nov 23, 2010
  • 6771 Answers
SOURCE: my denon dra-697ci receiver volume
You have bad connections on your circuit boards, if you are handy with a solder iron then you will need to touch up the solder joints.
Posted on Jan 03, 2011
Display reads "not connect" for v.aux input; how do I reconnect?
I would have thought simply making certain that whatever is connected to your Video Aux connection is actually in the socket and is not hanging out or even a faulty lead.
Apr 14, 2015 | Denon DRA-297 AM/FM Stereo Receiver
Can dra 37 be used as a pre-amp without connecting speakers
If you mean a sa control center for source selection, volume and tone control, yes, but NOT for a turntable (no PHONO).
Controlled audio goes emerges from the pre-out. Page 9.
http://www.retrevo.com/support/Denon-DRA-37-Receivers-manual/id/696dj086/t/2/
But you could still use its own speaker terminals if your exxternal amp has is remote or has its own volume control to match it up with other speakers.
Sep 05, 2011 | Denon DRA-37
Is the denon dra-395 compatible with an ipod?
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
Feb 13, 2011 | Denon DRA-395 Receiver
Denon dra 397 shuts done if I turn on both zone a & b. Have a 100 watt volume control on each pair of speakers. Works fine with only zone a or zone b on, but not both.
Let's understand this - you have an external volume control wired in series with each front speaker set?
Can you elaborate on their electrical characteristics?
http://www.retrevo.com/support/Denon-DRA-397-Receivers-manual/id/696dj087/t/2/
Page 24.
A + B 8 - 16 ohms
Jan 22, 2011 | Denon DRA-397
My receiver DRA-395 turns on and in a few seconds it kicks off - the standby light remains blinking the whole time and after shutdown. it will not stay on. i unplugged it for a minute fiquring it would...
Try unplugging everything, including your speaker wires. It's possible that you have a damaged or crossed cable or wire causing a short that activated the receiver's internal circuit. It might have also reheated.
Let the unit sit for an hour. Plug it in (just the power), set the volume to minimum, and turn it on. If it stays on, the issue MIGHT be with a wire or connection, so you should examine all of the tires for damage or crossed connections.
Turn the receiver off, unplug it, reconnect the wires and cables. Plug it back in, make sure the volume is set to the minimum level and turn the receiver on.
Jan 18, 2011 | Denon DRA-397
My denon dra-697ci receiver volume plays fine for a couple of minutes then the volume cuts off how can i fix it easy
Jan 03, 2011 | Denon DRA-697CI
Denon dra-95vr receiver has no sound out. All
Two things to check. First, the 95VR can be deceiving because it has a "variable loudness" control that some may mistake for volume. The actual volume is controlled by the big up and down arrows on the upper right side. If the volume is turned up, you should see the volume bar graph display show up. If none of the inputs are giving you volume, and the volume is turned up, then try running the output from the processor loop output in the back to another amplifier. The processor out is jumpered to the processor in for normal operation. Missing jumpers could cause a problem also. If there is sound coming to the processor out, then you have a problem with the power amplifiers. Best to refer that to a technician.
Dec 29, 2009 | Denon Audio Players & Recorders
Back channel turn off and on
Same problem with the 2.1 channel DRA-297. All sound cuts off and screen reads h/p input. I don't even know what that means. What's wrong here?
When it happens, the receiver makes a clicking noise. it goes back and forth from being on to h/p input shutdown. sounds like someone repeatedly flicking a lightswitch.
Thanks to whoever can help!
Jan 28, 2008 | Denon AVR-1700 Receiver
Denon DRA 395 volume creeps to max by itself
I also had this problem with my Denon DRA 395. I fixed it by replacing the batteries in my remote! Apparently when the remote batteries are nearly gone, but not 100%, they are capable of prompting the remote to unilaterally increase the volume at irregular intervals. It was kind of spooky!
Oct 01, 2007 | Audio Players & Recorders
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
