Question about Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor
Does not want to start just clicks has new battery
2011 f150 want start just click has new battery worked fine yesterday today want start just click
Possible internal starter problem. Try tapping on starter motor while key is held in crank position. If vehicle starts, suspect a starter motor problem and replacement will be required
Feb 28, 2016 | Cars & Trucks
Put new batteries in and it won't turn on.
  1. New battery, but still needs to jump start. Why? (auto, best ...
    www.city-data.com > City-Data Forum > General Forums > Automotive May 31, 2011 - 10 posts - ‎8 authors
    If the 2nd new battery never could start the car, I would say bad ... the 'clicking' sound and won't turn over with a brand new battery, I'd wager a ... Car Won't Start: Battery Corrosion (auto, GTR, best, buy ...
    Jul 24, 2013
    car won't start and no click, click, from solenoid. (buy ...
    Jul 13, 2011
    More results from www.city-data.com
    New Car Battery Still Won't Start - Auto Repair - TalkLocal Blog
    www.talklocal.com/blog/2012/10/s/.../new-car-battery-still-wont-start/
    Oct 31, 2012 - You have a new car battery and your car still won't start. Use these helpful tips to save money and get back driving on the road in no time.
Nov 02, 2015 | Cars & Trucks
Cannot start loud fast clicking noise
Clicking noise would indicate starter solenoid faulty! This would also be the case if battery low but since you have a new battery you can look at the starter solenoid!
Aug 22, 2015 | Cars & Trucks
New battery and car only clicks like bad battery
Check both ends of the battery cables to insure they are not loose. If this isn't the cause I'd take it back to whoever installed the battery and make them fix it. If you installed it yourself and a loose connection isn't the problem I'd let a dealership mechanic check it out.
Feb 25, 2015 | Cars & Trucks
Charge up a new battery and installed it. Tried to start and only get a clicking noise
Hi Jeff,
Welcome to Fixya.
Double check all the connection wires from the battery gioing to the starter and going to the ground. Clean the terminals if there are any corrosion.
Try tapping the starter using a hammer while someone is turning the key to start the engine and see if it will start.
Let me know if this helps.
Jan 18, 2015 | Ford Explorer Cars & Trucks
05 Wide Glide wont start
If it's a single click each time, sounding like it's coming from under the seat area, starter relay, $10 part.
Apr 05, 2013 | 2005 Harley Davidson FXDWG - FXDWGI Dyna...
Bmw gs 1200r adventure won't start with a new battery
Does the motor turn over when you hit the start button?
If you just hear a Click, click, click without the motor turning over, then your battery voltage is low and will need to be charged.
If your motor actually swings but doesn't fire up, chances are good that it is the fuel pump regulator that had blown. R1200GS 08 09 K25
Part number 16 14 7 720 776 is what you will need.
Mar 05, 2013 | 2010 BMW R 1200 GS Adventure
Car won't start. New battery installed recently. Only clicks when trying to start.
one single click any time you turn the key usually indicates a bad solenoid on the starter. A new starter will typical get you going.
A series of rapid clicks when you try to start usually indicates a weak battery. There could also be a bad connection at the terminals on the battery or even a poor connection at the starter.
If you get a single click and everything goes dead for a couple of seconds than you definitely have a bad connection at the battery.
Let me know what you find or if you have any questions.
Dec 28, 2011 | 2007 Chevrolet Tahoe
Eight days ago 2005 Suburban would not start. Made a clicking sound when I tried to start it. Jumped the battery seemed fine. Today same thing. Made clicking sound, jumped, started up. Went and bought...
Even a new battery will go dead if the car is running on the battery instead of the alternator.
Check alternator output.
First charge the battery up.
Then check voltage with a meter from Harbor Freight ($3).
Should be 12.5.
The start engine and rev it up.
Should go over 14.
But also clean and grease battery terminals, alternator terminals, and check engine ground strap.
Sep 21, 2010 | 2005 Chevrolet Suburban
Got new battery, still won't start. just clicks
probable starter motor
if you can get at it have someone turn key to start and tap on starter with something it may start. it also proves a bad starter
Mar 22, 2010 | 1991 Lexus LS 400
Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor Logo
70 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
