Question about Xerox - PRINTERS - PHASER 4510 (N) LASERPR MONO 36PPM 1200DPI 128MB
I have a Xerox Phaser 4510N printer, and it shows a error message like
  • 208 Answers
SOURCE: Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Posted on Dec 03, 2007
  • 208 Answers
SOURCE: Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
Try this before replacing the fuser.
You do have to reset a new fuser also.
Reset Fuser Life
  3. Scroll to Fuser, press Reset.
Dadofmykids
  • 25 Answers
SOURCE: Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
installation.
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Unit.
Are the connectors securely
connected?
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Complete.
Posted on Apr 07, 2009
  • 191 Answers
SOURCE: i own a Xerox Phaser 3100MFP and it keeps giving
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
Posted on Sep 22, 2009
  • 78 Answers
SOURCE: model - Xerox phaser 3100mfp - while installation
could be faulty fuser.or you could remove and re instal fuser
Posted on Nov 30, 2009
Communication error try powering down then on again
Xerox Phaser 3635mfp doesn't start it stays please wait and than show this message's. 9797d436-1cd7-4a72-8a18-fedba40002b0.jpg
Mar 19, 2013 | Xerox Phaser 3635MFP/X Multifunction...
When printing a document that contains both a letter and an envelope, there is a delay between the two.
Hi Dawn,
Not wanting to sound silly but I'm assuming that your printing from two separate trays, would a small amount of time to transfer from one paper path to the other.
By this time I'm sure you must have sorted it by now.
Good Luck.
Jan 09, 2013 | Xerox Corporation Xerox Phaser 4510N Laser...
Error 08,035.42:7417 after power loss. on 8650 phazer
my xerox printer phaser 8860 is stop printing. message show, 08,035.42: 138484. Is this fixable
Apr 05, 2011 | Xerox Phaser 8560DN Laser Printer
How to upload firmware in phaser 4510N
After download the firmware from Xerox.com website. Access the device via Http. To do that:
  1. Open a web browser
  2. Type the printer ip address into the Address bar
  3. Navigate to the PRINT tab
  4. From the left menu select File Download
  5. Browse to the file you download previously
Before upgrade I advise to print a configuration page for backup. If you have any doubts just let me know.
Sep 24, 2010 | Xerox - PRINTERS - PHASER 4510 (N) LASERPR...
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8560DN Printer ~ Error Message
An error code due to the print head, check the waste tray area for a spill, has the printer been moved lately? remove left cover and look for spill.
-Carl, please let me know if this helps.
Jun 25, 2009 | Xerox Phaser 8560DN Printer
Xerox phaser error code is : 07.002.44:10318 what dose this mean
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic
test. Also exercise processes run with the process motor;
transfix, drum maintenance and head tilt. This can be caused by
the power control board. The process motor may have more than
one task initiated. Reset all solenoids and the pressure roller
prior to cycling power.
Jun 17, 2009 | Xerox Phaser 8200 Laser Printer
Tektronix Phaser 840 Model Z840 shows error 08 001 44 215264
Check for broken Maintenance Drawer Guides, or the Printhead Cap/Wipe/Purge assembly is defective. (If it is for a Phaser 840)
Dec 05, 2008 | Xerox Phaser 8400 Laser Printer
PRINTING ERROR
> Home > Support & Drivers > Knowledge Base
Solution --> ERROR 0082" name="Note" /> Phaser 790 / DocuColor 2006 Printer's: Cancel print job and cycle the printer's power
  • On the printer's Control Panel, press the Cancel Key (12 KB).
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the CANCEL key.
  • If the error message persists, turn the printer off for at least 30 seconds and remove the computer interface to the printer (17 KB) before turning the printer back on.
  • Use the menu keys to perform a front panel reset (under RESETS menu).
  • If the printer redisplays the error message upon reboot, a file is likely STUCK at the front of the print queue. Use the front panel RESETS menu to CLEAR LOGS AND QUEUES, which will delete all print jobs in the printer's disk spool.
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the MENU key to gain access to the front panel menu.
  • If the front panel menus can not be accessed turn the printer off for 30 seconds and then turn the printer back on.
  • If it is known which print job was last sent to the printer, try to reprint the last job spooled, which may be the cause of the error. Step 4 on clearing logs and queues may need to be repeated to eliminate the crashing job.
Note: Most XX82 or XX1E front panel error messages are NOT hardware related, but caused by a specific print job or application.
Mar 04, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox - PRINTERS - PHASER 4510 (N) LASERPR MONO 36PPM 1200DPI 128MB Logo
91 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
