Question about Whirlpool Washing Machines
Whirlpool AWO/D5526. fault lights Water tap closed and clean pump
Half of the filter is stuck in machine. Unable to get out so filter and filter chamber cannot be cleaned.
  • 1294 Answers
SOURCE: washing machine will not drain
You shd check out your pump, refer
to manual. There shd be some block there.
Posted on May 09, 2008
jsrock516
  • 5911 Answers
SOURCE: whirlpool awo/d 4305
If you're talking about the drain pump clean out trap, the following link explains how to check it and clean it:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
This is the only "filter" on this washing machine. If you need service information, the manufacturer normally places technical information inside the appliance behind the bottom panel under the door. Look inside and there should be a tech sheet taped to the inside of the cabinet walls, or inside the bottom panel. I hope this helps you. Let me know if you require addtional assistance.
Posted on Aug 28, 2008
whilpool awo/d 4305 light onclean pump can i do this myself
Posted on Nov 23, 2008
SOURCE: whirlpool awo 3761/5/s
have you checked that there is not a blockage in the outlet pipe or that it is not kinked?sometimes if the pipe is lying to low (ie creating a u-bend) this can prevent water getting in & out & so the machine interprets it as either taps off or the pump needs cleaned (this has happened to me numerous times :) )
Posted on Jan 12, 2009
jonniewalker
  • 1029 Answers
SOURCE: fault codes f 13 Whirlpool Washing Machine AWO/D 5716
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it’s proper position.
Potential Causes
• Check mechanical linkage from dispenser motor to the top of the dispenser.
• Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
• Check Dispenser Motor
Posted on Jan 29, 2009
Where do I clean the pump filter? Light keeps lighting to clean pump. Whirlpool front loader. A+A 5kg / 1200 AWO/D 4505
You have a code telling you to clean the pump now thats a first are you sure it says clean the pump filter? more info as to why you are needing to clean the pump filter its not really easy trust me, unless you have done it before which i am guessing you havent.
Mar 07, 2016 | Whirlpool Washing Machines
AWO 3551 have a FP fault . help
thanks for your advice. I have an AWO 3551 Whirlpool front-loading washing machine. It works but I think it's highly likely that the filter needs a clean and is long overdue. I've opened the front plate and unscrewed the plastic cover but the filter doesn't come out at the same time. It seems pretty stuck and there is nothing to get a purchase on (unless I get pliers and turn counter clockwise - but slightly concerned that might break it...?) Any suggestions of how to make it 'come out to play'?!
Feb 21, 2012 | Whirlpool Washing Machines
Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
May 11, 2010 | Whirlpool AWOE8748 Front Load Washer
The clean water pump is flashing on my whirlpool awo/d4505 washing machine where is the pump and how do i clean it ?
There should be a access panel on the front of the machine at floor level.
This will have a filter which you need to clean. This filter is on the input to the pump.
Feb 03, 2010 | Whirlpool Washing Machines
Whirlpool washing machine say clean pump/ modal awo/d 4605 how do i do that?
Unplug the machine.
Remove the bottom front panel.
The pump will be directly in front of you. Twist and pull and the pump filter will come out.
Jan 07, 2010 | Whirlpool Washing Machines
WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
May 19, 2009 | Whirlpool AWM8163 Front Load Washer
Whirlpool awo 3761/5/s
Nov 24, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Washing machine
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
99 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
