Question about JVC Cybercam GR-DX76AG Mini DV Digital Camcorder
Zooms to maximum zoom... when on position
Whenever i start this cam up, it zooms to maximum zoom setting.. either 15x or 40x digital. then i have to zoom down by pressing the button, i release the button, zooms in again. what could be going wrong ?
2 Suggested Answers
  • 169 Answers
SOURCE: Zoom malfunction
the zoom control button is malfunctioning. try to clean the contact. check the resistant of the variable carbon. if it is not open, try to adjust the contact point away from the damaged area.
Posted on Aug 08, 2007
SOURCE: zoom problem with JVC GR-DV800U Camcorder
I have the same problem...if you figure this out, please let me know!! ctfmailbox-online at yahoo
Posted on Jul 18, 2009
0 characters
1 Points
Taking macro photos
when you use macro, you must stay really near the subject... so if you use the zoom to get closer, that want to say that the camera is too far, you may put it nearer and so, use less zoom, or get rid of the macro and only use the zoom (and you can move the camera to good distance) you'll get better results !
Nov 07, 2014 | GE X5 Power Pro Series 14.1 Mp Digital...
Have a Sony DCR-DVD108 DVD Handycam Camcorder with 40x Optical Zoom and wondering how to hook it up as a webcam
I guess my question to you, why would you want to use a DVD Handycam Camcorder with 40X Optical Zoom as a webcam? The optics on that camera are great and I would use the camera as intended. It would be bulky to mount and use as a webcam. Most webcams are mounted on the front of your monitor. It seems to me it would be easier to just pick up a webcam that is designed to sit on your monitor. Logitech makes some great ones.
Here is link: for some webcams.
Dec 28, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Setting the ''digital Zoom''
The digital zoom works fine on mine. It sounds like your have encountered a couple of defective models.
However, even once you get the digital zoom to work, it gets really grainy, so I don't use it.
Nov 30, 2008 | Video Cameras
Zoom problem with JVC GR-DV800U Camcorder
Nov 28, 2008 | JVC GR-DV800U Camcorder
My zoom problem was a combination of the software and hardware when it came to the neutral position for the zoom slider. When the camera is first turned on, if the physical zoom slider (hardware) is in the neutral position (you are not touching it) the camera software does nothing, but if you are pushing the physical zoom slider when you turn on the camera, the software resets the "zero zoom" position into memory. The solution to my problem was to push and hold the physical zoom slider towards the wide position and the software realize reset the "zero zoom" neutral position. This may take a few tries to get it right (if you over compensate, do the opposite and push the slider towards "T" when you turn it on), but I hope this will solve your problem and save you a few bucks.
Jul 04, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Sony Handycam DCR-DVD108 - Carl Zeiss Vario-Tessar Optical Zoom 40x
Please, I need support of camera technical carl zeiss vario tessar with otptical zoom 40x
Jun 14, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
JVC Cybercam GR-DX76AG Mini DV Digital Camcorder Logo
15 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Shekar Avadhani
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
