Question about Lindhaus HEPA 14 HealthCare Pro Bagged Upright Vacuum
Lindhaus HEPA 14 HealthCare Pro stopped working
The unit just stopped, no lights nothing. Unit was taken apart and cleaned and checked, nothing obvious. Is there a reset or thermal fuse?
Thanks
3 Suggested Answers
SOURCE: I have no suction on the Lindhause healthcare pro
Make sure that the on switch is in the upright position. Down won't give you give you suction when vacuming.
Make sure that the hose is securly in the lower part of the vacuum.
Test the hose with your hand before you put it back to see if you're getting air sucked in through hose. If not it must be clogged up somewhere. You might contact Lindhause home base.
Posted on Apr 09, 2009
  • 172 Answers
SOURCE: Wire came loose, can't figure out where it belongs
Maybe one of the wires that leads to the power head?
Posted on Aug 12, 2009
I have an Eureka Altima Model 2961AVZ vacuum that suddenly stopped picking up. I have taken it apart, checked the belt which was fine, replaced the hepa filter, and checked for clogs in all the hoses
Is the beater bar actually turning when the power is turned on? Sometimes the belt is fine, but something is jammed and keeping the beater bar from turning. What about the section behind the beater bar, but before the hose upright. I've found large pieces of paper jammed in here and then hair gets caught, ultimately blocking the whole system. Usually you have to turn it over, remove some screws and disconnect the belt and beater bar to get underneath. Just reassemble it in the reverse order to how you took it apart. Double check the hoses and run a "unwound" metal coat hanger through to unclog anything. Does the vacuum " suck" with the hose or tube up to it disconnected? If not you may have a motor that somehow got junk pulled into it. You can open this up as well and clean this out. Of course unplug it all before doing anything.
Nov 03, 2014 | Vacuums
What is the right bag for sebo x4
  1. First, pull out the hose, turn the unit on, check for an obstruction in the hose. (unclog and obstruction)
  2. Separate the body from power nozzle. Check for obstruction in the air hole passage.
  3. Pull and clean both filters in the unit. The inside white long carriage and the exhaust filter located above indicator panel. (nozzle body)
  4. If this is not working. think about where and how dirt is carried or passes from the front floor nozzle or through the hose.Somewhere in the unit the it is clogged. The red light censers a full bag (we know that's not the issue) or an obstruction to the normal air flow.
  5. Last Resort contact http://www.sebo.us/contact_us.aspx
  6. In closing: I've been selling and repairing vacuums for over 30 years. Of all the 5 major brands that I sell. Sebo is by far the, best product on the market.
Aug 23, 2014 | Sebo X4 Bagged Upright Vacuum
Dyson problems
I have a DC-07 Animal and I have taken it apart many a time and cleaned at least the plastic parts. Its all modular. I would just make sure nothing is clogged.. Remember the Hepa filter is not washable just the sponge filter. So if you took out the filter and left in the Helpa filter I would order a new Hepa filter - its probably clogged by now! Beat of luck!
Aug 12, 2014 | Dyson DC41 Animal Complete Ball Upright...
What does yellow exclamation point light mean
YELLO and RED mean danger - clogging, not brush turning, overheating, .... it is time to RESET -- turn it all off and let it sit for half hour - that is what the manual says, check the brush that is not clogged up and check the inlet to the hose and where the hose goes into the body from the head unit where the brush is - make sure those not clogged either. Turn it on, push the RESET button on left back side of head unit by the switch that changes height. The reset button is like a circuit breaker - stops unit when overheats, starts when reset. Yello is ERROR, and fix it before it turns red and stops all the way. Cheers!!!
May 31, 2014 | Electrolux EL8807A Precision BrushRoll...
Sucton motor doesn't come on
If the debris cleared itself, it may have gotten into the vacuum fan assembly and jammed the motor preventing turning. Also, check the vacuum motor brushes and springs for damage. Hope this helps.
Dec 05, 2009 | Lindhaus HEPA 14 HealthCare Pro Bagged...
Aug 11, 2009 | Lindhaus HF6-12 Canister Vacuum
I have no suction on the Lindhause healthcare pro Hepa
Feb 23, 2009 | Lindhaus Healthcare Pro 14 Bagged Upright...
Rainbow e series musty odor
The unit and the nozzle have to be taken apart and cleaned. You almost for sure will need a new HEPA and possibly even the motor cooling filter. There is a lot of dust inside that got moist (moisture in the air,vacuuming wet carpet, maybe you have pets or everything together)
It will require a bit more advanced skills but you do not have to be a vacuum repair professional to do this.
Sep 18, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Hoover Z-400 - Hepa Filter
These filters should be changed at least once a year, they get clogged up and won't clean out. So I would try a new filter and go from there, make sure there are no clogs in the hose and down below where the dirt inlet is.
Feb 20, 2008 | Vacuums
Lindhaus HEPA 14 HealthCare Pro Bagged Upright Vacuum Logo
65 people viewed this question
Top Lindhaus Vacuums Experts
vince
ray gallant
Are you a Lindhaus Vacuum Expert? Answer questions, earn points and help others
