Question about Philips 51PP9100D 51 in. Television
My picture has become a smokey greenish color causing the entire picture to seem behind a green haze... any suggestions?
  • Philips Master
  • 8,617 Answers
The CRT coolant needs to be replaced. You can get the Phillips CRT coolant repair kit from www.tvrepairworld.com the kit has the coolant for all 3 CRTs and the CD with instructions.
Posted on Feb 12, 2012
Every thing is greenish in picture, green color overlays allover
One color predominant screen is the fault. In most cases, it will be due to some loose solder terminal/s at its video output card [CRT base card]. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
May 20, 2016 | Televison & Video
Repair sony xbr flat screen
T'Con board fault. Contact the authorized service center for Sony.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations.
Aug 19, 2014 | Televison & Video
I have an 2001 Mercedes-Benz c240...What color should the coolant be that is used in this car. I paid to have it flushed but the coolant in it looks a greenish-brown color...is this right? Not sure they...
Hi. apparently the mechanic did not rinse the contents out completely after the flushing was administered. During the flushing of a radiator, there may be a good amount of debris that will build up, due to the flushing compounds effect on the crude inside the radiator. This is why there should be a rinsing stage to clean out all that is removed, via the flushing procedure. If the rinse is not done correctly, some of the contaminates will be left behind to mix in with the new radiator fluid. The rust/debris will mix contaminate the new fluid that is poured in, thus, causing the brown color you have noticed.
Most radiator fluids will be green, or orange in color, but never brown or greenish brown. This greenish brown will indicate that there is some rust deposited that were not rinsed out properly, after the flushing of the radiator. I would return the vehicle to the mechanic to request a re-flush of the radiator. They should do it for free.
NOTE_ A more serious issue will be a damaged oil cooler. this will cause the same symptoms within the color of the fluid, if your vehicle is equipped with this device. Once the oil cooler has ruptured, it will cause the engine oil to be transfer into the radiator, thus, changing the color of the fluid.
Dec 03, 2009 | Mercedes-Benz C-Class Cars & Trucks
I have changed my rear projection lamp and now the picture is green can you tell me what is causing this please.
It sounds like your light engine is defective. My Projection LCD had this happen and it started with a growing blue haze, others experienced a yellow haze, I suspect yours is manifesting with a green green haze.
It is a very expensive fix, depending on the age of your set, you may find it cheaper to replace it with something new, because a light engine itself costs nearly $2000 and another few hundred to install and align, not something a do-it-yourselfer is able to do
Oct 01, 2009 | Televison & Video
Color washed out
If the tv has a blue haze and the picture is turning greenish-redish, the problem is that the coolant in the crt's are cloudy due to bacterial growth. The fluid needs changed in the Blue and possibly Green tubes, the red tube usaly does not need the fluid change because the bacteria that seems to inabit the tubes dont seem to like the red light.
To do this yourself is involved and will expose you to electric shock dangers. If you want to tackle this yourself Post back and i can give you explisit instructions.
This service by a Technican could cost around $300.00 to preform, this cost can vary depending on the shop.
Sep 04, 2009 | Philips Magnavox 9P6034C 60" Rear...
SAMSUNG PROBLEMS - Red and Green Shading All Over Screen
adjust vscan  vs & va voltages on power supply, if not that drive pcb's are bad
Jun 05, 2009 | Samsung LN-S4051D 40 in. LCD Television
Greenish haze on my Samsung HC P4741W
If you purchased it new then this clearly should not happen - if it is second hand and therefore older then the red tube could be burnt out. The convergance may simply require allignment if the set has been knocked about trying to get it to its final resting place - this would need a tech on site to set it up.
Feb 14, 2009 | Samsung HC-P4741W 47" Rear Projection...
My 37'' Vizio LCD TV has a green haze and lines on the TV
It is a very simple fix. Replace the LVDS cable will fix it. This cable connect the mainboard to the panel.
Nov 15, 2008 | Vizio L6 20.1 in. HD-Ready LCD Television
Philips 51PP9100D 51 in. Television Logo
69 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
