Question about Dell Computers & Internet
How do i get my computer out of the resolution mode?
  • Brad Brown Feb 12, 2012
    What version of windows
  • Dell Master
  • 5,660 Answers
Apparently the monitor screen resolution setting is not correct. Screen resolution stays up until it is corrected.
Either the setting is off in Windows, or you have been changing the monitor settings, with the monitor.
WinXP:
Right-click on an empty area of your desktop screen.
Left-click on Properties at the bottom of the list.
Left-click on the Settings tab.
Go down to where it states Screen Resolution.
What is the pixel setting? For example mine states 1600 x 900 pixels.
I am running dual monitors, and this is the correct screen resolution for the Primary monitor.
If it wasn't I would Left-click on the Slider, hold the left mouse button down, and slide the Slider to the correct native resolution.
(Under Screen Resolution is a line. To the left it states - Less
To the right of the line it states - More
The Slider is the rectangular down arrow on the line )
ALSO;
Under the Color quality heading, make sure in the box under it, that it states - Highest (32 bit)
IF not, left-click on the blue down arrow to the right.
Then left-click right on - Highest (32 bit)
How to know what is the native resolution for your monitor?
Look at the manufacturer name, and the model number on the back.
Type this information in your browser search bar, then click on the search icon.
Look for Specifications.
If you changed the screen resolution settings with the monitor, press the Menu button. The screen should go off.
ALSO, with a new monitor there is an Installation CD Disk, provided with it.
This disk MUST be used. It has the drivers for the monitor on it.
[ Drivers: Small pieces of software that allow the Operating System to 'communicate' with a device.
The monitor is a Device.
Windows XP, and Windows 7 are two examples of an O/S.
Operating System ]
If you have Vista or Windows 7, post in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Feb 12, 2012
Zoom on desktop
Try Right Clicking on a empty space on the desktop and select Properties. Click the Settings Tab and go change the screen resolution. The higher the resolution, the smaller the icons. Normal resolution is about 1024x768, but you can make the icons even smaller by increasing the resolution.
If you can't get into the screen resolution that way, turn off the computer and boot up into safe mode.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
When the computer boots up click Start/Control Panel or Start/Settings Control Panel and look for Desktop or Appearance and Personalization.
Look for Screen Resolution or open the desktop and click the Settings tab. Make the resolution higher to make the icons smaller. Normal is 1024x768 but you can make it higher.
In Windows 7 just click Start and in the search box type: Screen Resolution. Look up at the top for the returned search results and click on Screen Resolution. Go in and set the resolution higher.
After you change the resolution reboot and let windows go into it's normal boot up mode.
May 23, 2012 | HP Compaq 6710b Notebook
Cannot Display This Video Mode!!!
Restart your computer Press F8 key it shows Startup option choose VGA mode and Select the resolution after getting your desktop
May 06, 2010 | Dell Inspiron 530 Desktop Computer
When i turn it on it says out of range and i have a black screen
Hi, The reason behind the out of range (frequency of monitor) because the video display adapter is trying to set resolution more than what the monitor (screen) is capable of. In this case, try to boot your computer in Safe Mode using F8 function key while starting your computer. Once you are in safe mode, try to decrease the resolution of monitor to the lowest resolution level and apply the settings. Now try to boot computer in normal mode once again, you will get the settings which you have applied in safe mode. Adjust the screen resolution accordingly till the settings work with the monitor (screen).
Cheers!
Mar 01, 2010 | Microsoft Windows XP Home Edition
My acer v223w monitor popped p "you are not in prefereed mode so i clicked on preered mode and it wnt blank pleae help
The preferred mode is the resolution at which the display looks best. Unfortunately, you switched to a higher resolution than your monitor can handle.
Now you must start in safe mode and change the resolution.
If you can't do that, hit the F8 key as the computer starts and if you see the option to start in VGA mode, choose that. You can then set your display back to a lower resolution.
Feb 01, 2010 | Acer V223Wab Widescreen Lcd Monitor Blk
QUESTION: Monitor says:
Reboot your computer and press the F8 key right before you see the XP loading splash screen. You should get a menu that lists things like safe mode and vga mode. Select the vga mode option and hit enter twice. This will boot windows into 640x480 resolution and will allow you to change the resolution back to 1024x768 at 60hz
Nov 23, 2009 | Computers & Internet
Not optimum mode
This means your computer windows resolution is not display in the correct resolution which your samsung LCD will take.
What you need to do it boot the computer in safe mode. (pressing F8 at start up and select safe mode) This should bring the windows to start up in the generic 800x600 resolution.
Once you are able to see the display in safe mode, go onto the display properties and change the resolution.
* right click on desktop -> properties -> settings
Please rate this if it solves your issue. If you need further assistance please post.
May 29, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Monitor resolution
What do you mean that you were unable to get the native resolution of 1440x900? Are you saying that the resolution varries?
Since you mentioned that the mother board supports 1440x900, try to set the monitor resolution to that same resolution and then restart the computer.
If you will get the same problem, you have to make sure that the video card supports 1440x900 resolution.
Apr 15, 2009 | LG L194WT 19" LCD Monitor
Error of resolution
when u power up the computer press F8 key then enter in enable vga mode then go to disaply properteis then set display resolution to 1024*768
then apply and ok.
Mar 23, 2009 | Computers & Internet
Resolution is too high
You need to start the computer in VGA mode. To do that, turn on the computer. Keep pressing the F8 key every second until a boot menu appears. Select enable VGA mode. The computer will boot to a 640 x 480 resolution. From there you can go to your graphics properties and select a more suitable resolution for your monitor.
Jul 04, 2008 | Gateway GT5028 PC Desktop
Unknown mode
Check the instructions for the default resolution for your monitor. Start your computer in the safe mode. In the safe mode, the resolution should come up at the minimum. Now go in to the screen properties and set the resolution recomended for your monitor.
When you start the computer normaly, it should now come up in the last setting that you put it in to while you were in the safe mode.
Jerry G.
Jun 03, 2008 | GoVideo TW1730 17 in. HD-Ready LCD...
Computers & Internet Logo
91 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
