Question about Canon CanoScan LiDE 30 Flatbed Scanner
Cannot scan a picture.
I have a CanoScan LiDE 20/LiDE 30 with Windows XP. The scanner begins to scan. There is no preview of the picture and than it says The Wizard cannot complete copying the picture because the process was cancelled. How do I fix it so the process is not cancelled?
  • Anonymous Nov 06, 2008
    canoscan lide 20 cannot show its scan image
Where is the power button on a canoscan lide 70 scanner?
There is no power button on mine. It gets its power from the high speed usb so it is always ready. Every time I boot up my mac I hear the scanner go thru a warm up scan. I have downloaded the twain plugin for photoshop and access it that way. The lamp will go on when you preview scan something.
Feb 19, 2011 | Canon CanoScan LiDE 70 Flatbed Scanner
Canoscan Lide 30 compatibility with Windows 7.
There are no official drivers for CanoScan Lide 30 for Windows XP, so your problem is obvious. I suggest you sending an e-mail at Canon including details about your scanner (date purchased, serial number in text form or scanned) asking them to develop driver set as this model is very trade and at shops since 2006 or 2007.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 27, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
Is canonscan LiDE20/30 compatible with wndows 7
Here is the link for downloading the drivers for canoscan lide 20 for windows 7 (compatible with XP, Vista e.t.c).
Canoscan lide 30 does not support windows 7, here are the drivers for Vista.
Thanks and regards
Stelios
Feb 25, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
CanoScan LiDE 20 started stretching image at the beginning of the scan, continuing just fine afterwards. Bottom part of the image (in my case a letter-size page) will not fit, about 1/4 of an inch would be...
Hi pallada,
This might be a case where we address the symptoms rather than the problem.
Instead of positioning the paper to be copied at the normal position, drop it down to the 2" mark. Then on the preview screen, adjust the area to be scanned down accordingly.
This should allow a full letter size scan with no loss, truncation or stretch.
Best regards,
Mike
Jul 18, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Canoscan Setup Utility CD-ROM missing
How can i install my canonscan 20 without the cd rom
Sep 07, 2008 | Office Equipment & Supplies
TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver. 7.0.3.1a_xp" and then download the software "Canoscan toolbox" ...here is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
Aug 04, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Canon scanner
TWAIN is the type of scanner driver that is used for this scanner. It is probably the most common type of scanning driver.
Did you install Toolbox? Not sure? Assuming this is Windows, click Start, All Programs, Canon. Look for open CanoScan Toolbox (4.9 I think). Once this is open, click the 'Settings' button. There should be a drop-down menu for 'Select Scanner'. Make sure this shows the CanoScan LiDE 25. If that scanner is not listed, then the scanner driver is not being seen or may not be installed.
Once it has been verified that the LiDE 25 is selected, click OK. Next, click the 'Save' button. Check the box for 'Display the Scanner Driver'. Now click the 'Scan' button at the bottom.
The next window that pops up should be ScanGear. If this happens, then everything is installed and the scanner is being detected properly. Attempt to scan or preview.
If there was a particular application you were trying to use and you are still having issues with it, please give those details.
May 19, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
I'm using a CanoScan LiDE 60 and I have no idea even how to begin. I need to scan in 5 different documents with numerous pages and I was hoping to create a pdf for each. Can you help me get started?
Use the CanoScan Toolbox that shipped with the scanner. If you don't have it, then download it from the Canon Website. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=11446
If you don't have the scanner driver, then download that too.
Once you have Toolbox installed and you open it, there will be a PDF button. The scan to PDF window will open. If you're planning to do a multiple page pdf, then click the dropdown menu next to 'Save as Type:' and select PDF (Multiple Pages). You're now ready to begin, insert your first page into and then click 'Scan'.
Nov 20, 2007 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon CanoScan LiDE 30 Flatbed Scanner Logo
159 people viewed this question
old marine
old marine
