Question about Husqvarna Garden
I have a Husqvarna 44 chain saw,s/n 5031839 and need the stud that actually holds the chain var and cover on.Any help would be great.Just getting the year the saw was made would be helpful.Thanks in advance.
  • Husqvarna Master
  • 2,239 Answers
The stud never changed through production, it is part no. 501454301 should be available through your local dealer, or on the web, it can be fitted without splitting the crankcase, with some thin wall tubing and pulling through the oil filler hole.
Posted on Feb 12, 2012
Testimonial: "Thanks Andrew White for the help.I have ordered the stud and the nut.Do you know if the stud screwa in from the outside or do i have to take it apart?I will know the anser when the stud gets here,but thought I would ask.Thanks again for your help."
  • Andrew White Feb 20, 2012
    The stud is a press fit from the inside, if you have a magnet on a stick you can feed the styd through the oil filler hole, you will need to mark a top dead centre on the tip of the thread, the reason for this is the stud has a sqaure on the back and must fit into a square opening on the inside of the oil tank, once the threaded portion of the stud is through to the outside of the crankcase make sure your top dead centre mark is upper most ( to align the square ), then use the nut and spacers to drag the stud fully home
  • btf77
    btf77 Feb 21, 2012
    Andrew,Thank you so much for the help.I think I can do as you said and work it thru the oil fill hole.will save me alot of time and trouble.Thanks again.Bill
SOURCE: husqvarna chain saw oiler
Hi!
Oil pump mechanism is broken or the oil exit is clogged
Mark
Posted on Oct 24, 2008
  • 211 Answers
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Posted on Dec 01, 2008
SOURCE: Cant get clutch cover off new Husqvarna 235e chain saw
Mine did this when nearly brand new. You likely have a nasty jam of oil and sawdust stuck between the chain brake and the flywheel. It can be loosened by either careful prying of the case or precise shots of carb cleaner up in the housing. While you are in there look for a buildup of oil around the chain brake connection to the kickback paddle.
Posted on Dec 31, 2008
  • 149 Answers
SOURCE: Ineed to remove flywheel from 365XP Husqvarna to split crank case
The thread is RH, loosen the nut un till its just flush with the top of the crank threads, use an soft metal drift, copper, allly, brass etc.
hold the fly wheel and strike the top of the nut with the drift it will pop the fly wheel off. you may need a hand. if it wont come off use a screw driver under the fly wheel and pry it up when you strike the nut..Dont hit the nut /shaft without the soft drift...you will destroy the shaft.
the clutch thread is LH..
Posted on Jan 15, 2009
  • 4088 Answers
SOURCE: Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Posted on Jul 08, 2009
Chain wont tighten
Pmorrow1975:
When you can't adjust the chain any more, the chain has stretched so far that you will need to remove the chain and replace it, or the tensioner pawl has slipped out of the bar and the chain tensioner will not work. Let's start with the easier solution. First lay the saw on it's left side so the bar is up and you can see two studs with nuts on them. These nuts hold the bar and side cover on. Remove the nuts (a 1/2 inch socket is what you need) and remove the side cover. The side cover holds the chain tensioner. Check to see that when you put the side cover on, the pawl on the chain tensioner fits into the small hole in the bar. If it does not, adjust the chain tensioner screw (below one of the chain retention stud holes in the side cover) until the pawl fits into the hole in the bar, and reinstall the side plate. You'll be able to adjust the chain tension now. If the chain tension is still too loose when the back of the pawl (visible through the slot in the side cover) is at the back of the slot, it is time to replace the chain as it has stretched beyond adjustment parameters.
Hope this helped.
Jul 22, 2012 | Husqvarna 455 Rancher Chainsaw - 20" Bar
Ive removed the cover on the crankcase side in order to change the chain itself. The cover is held in place by two studs. I cleaned the crankcase and then went to fit the chain assmebly and cover back on....
I really can't see the studs falling inside but it sure could drop out. But to make sure and satisfy your curiosity take your saw and shake it, or turn it upside down then right side up and listen for noise to see if it could be inside your saw. Sometimes when you remove the nuts the stud comes with it and you don't think too much of it. I have done that myself. I hope this helps, thanks.
Nov 20, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
No problem; using a borrowed Husqvarna 44-don't know fuel mixtures (if any). The chamber for "oil"-is that engine oil (if so, what do you recommend) or chain saw oil (if not, is there another...
The mix fuel mix is 40:1. Use Husqvarna 2 stroke oil not the cheap stuff on sale at car service stations. The chamber for oil is for chain oil which can be bought at most places that sell or hire machinery like chainsaws, lawnmowers etc.
Nov 14, 2010 | Husqvarna 44" Chainsaw Bar Fits Jonsered...
The chain cover will not go back on because the break is engaged and I would like to know how to disengage the break band.
If the blade brake is engaged, it can be extremely hard to disengage when not mounted on the saw, as I'm sure you already know. One thing you can try is loosely mounting the cover on the bar studs with no sprocket installed so that you will have the leverage you need to disengage the brake band. Good luck.
Oct 06, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I need to replace the chain and can not figure out how the cover/plate comes off
Depending on the model, you should just release the blade brake, if engaged, remove the bar stud nuts and remove the clutch cover. You should then have access to the bar, chain and sprocket.
Aug 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Is there a replacement clutch cover for the Poulan PP4218AVX?
Hello Dave;
If a Poulan PP4218 your answer follows; if not post back with the correct model number and we can replace that too.
Poulan “PP4218AVX” IPL (exploded parts list)
We are going to replace this page 1; item 47
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2010/NIUS2010_545103408.pdf
Poulan “PP4218AVHD” IPL
http://www.ordertree.com/modelinfo/PWE/PP4218AVHD-Gas-Saw-Type-2/75.PP4218AVHD-Gas-Saw-Type-2.1.59.1.html
With this; “Handle, Chassis & Bar Assembly” print; item 44; Clutch Cover Assembly; $9.50.
You also need;
• Item 43; Bar Mounting Nut; $0.56 each (need 2) and
• “Engine Assembly” print; Item 44; Scrench; $9.75.
This is the configuration professionals have used forever. The only thing to remember here is to hold the nose of the bar up when adjusting and tightening the bar nuts.
You will need retain the original model number IPL, there may be internal differences.
Down loadable PP218AVHD IPL
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2006/NIUS2006_545014325.pdf
Poulan “PP4218AVHD” OM
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2005/NOUS2005_545047503.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
May 16, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain oiler stop working
remove side cover,bar & chain.ther is an ob long channel above the bar mounting studs that lines up w/the small holes near the edge of the bar,thats where the oil comes out.clean everything.sawdust gets packed in the holes & stops the oil flow.
Sep 22, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
93 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
