FREE REBOOT/RECOVERY DISCS FOR IMEDIA A5518 UK
COMPUTER NOT STARTING UP, WAS SHOWING ERROR CODE 8302 WHEN IT WAS STARTING UP.
    Master:
  • 388 Answers
Restart it pushing F8 a list will apear select last known good configeration it should sort it
Posted on Feb 12, 2012
5 Suggested Answers
  • 68 Answers
SOURCE: On start up goes in a continuous restart cycle
There is usually a hot key you can press during boot up to start recovery (F11 is typical) This will guide you through the recovery process. I would first check all of your cables going to your hard drive, and also the one going from the hard drive to the motherboard. See if that helps. Best of luck to you!
Posted on Dec 08, 2008
haystack11
  • 55 Answers
SOURCE: when putting the recovery disc in it will run a
Normally you want to boot the pc with the recovery disc in. Some recovery programs work best on boot up. If not check the cd to make sure it is not scratched. Also try it in another pc to rule out a bad cd-rom.
Posted on Nov 11, 2009
  • 12 Answers
SOURCE: I need to reboot my computer and I do not have a
The disk doesent matter, Simply resintall windows with any disk.. To reinstall windows, Boot up your computer.. at the first black screen. press f1 or del to enter the setup menu. go into the boot order and put the cd rom in place of the hd reboot install windows.
Posted on Nov 23, 2009
  • 160 Answers
SOURCE: My HP e9120f gave me
You might have another part that has gone bad. Check the RAM and see if it gives you any problems.
There is a program call mem test that you can burn to a CD and test your memory. But if your no longer able to get to the bios:
you def had a hardware problem.
Posted on May 04, 2011
How to recover data from transcend hdd when not appearing in disk management and not showing under my computer. system detects it first with clicking sound but after sometime error appears as device d
Use hirens boot disc look for programme in hard disc tools called test disk.it will check and repair mft which should then allow the drive to be seen and then fix errors.failing that route try and get spin right which will fix bad blocks.
Sep 08, 2014 | Transcend Storejet 25m2 500 Gb External...
Emachines pc unknown error code 8302-press f1 to continue
http://www.tomshardware.co.uk/forum/295726-30-bios-error-code-8302 READ IT.IT EXPLANES THE PROBLEM.
Apr 05, 2013 | E-Machines eMachines Desktop PC
F3-f100-003 error code what does it mean?
The new HDD apparently has no OS. what is what the msg says.
boot to Bootable media with to install a NEW OS. or boot to your Recovery Media. and let it restore to Factory.
if this does not help - then provide more info.
Jan 18, 2013 | Toshiba Satellite Computers & Internet
My HP e9120f gave me the following error message the other day. "reboot and select proper boot device..." My first thought was my hard drive was bad. I could turn off the computer and after a...
May 04, 2011 | HP DT PAVILION ELITE E9120f DESKTOP PC
I have an acer aspire one D250 laptop and I tried to reboot and restore it. Now it lead me to a blank page that says B00TMGR is missing.press Ctrl alt del to restart. I tried to use ALT F10 and nothing...
*** Remove any external monitor as it will make entry into BIOS utility and recovery process difficult. ***
The following is from pages 29-30 of the 52-page D250 UserGuide.pdf located in folder C:\Book
I want to restore my computer to its original settings without recovery CDs.
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1. Check to see if Acer disk-to-disk recovery is enabled or not.
2. Make sure the D2D Recovery setting in Main is Enabled.
3. Exit the BIOS utility and save changes. The system will reboot.
Note: To activate the BIOS utility, press during POST (Power On Self Test).
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press + at the same time to enter recovery process.
3. Refer to the onscreen instructions to perform system recovery.
Important! This feature occupies 6 GB in a hidden partition on your hard disk.
Sep 30, 2010 | Acer Aspire 3050-1733 Notebook
I tried to reboot the computer with the reboot disks and i keep getting error code 0xd0000009
This is an error that shows that the recovery failed..
try with another recovery disc or try with another recovery disc
May 11, 2010 | Acer Extensa 5620-4020 Notebook
Packard bell pentium3 windows me
F1 is probably the key to enter the Bios setup utility. Press and hold the F1 key immediately after you start the machine. Go to the boot priority section, and set your CD-Rom as first boot device. Press f10 to save the settings and reboot with your recovery disk installed
Apr 29, 2009 | Packard Bell iMedia SL 9553 (P660401806)...
Error code =8302
check your bios settings that the vid output is set to boot from the right device that you want it to be from. try reseting defaults
Feb 24, 2009 | MSI P4M900M-L Motherboard
Installing windows XP - Error encountered
Can you reboot and get into windows or is now corrupt?
What do you mean by 'uninstalled XP'??
You cant uninstall it unless you format the drive, in which case the recovery discs are now probably useless as they rely on a folder on the HDD called i386.
Recovery discs normally dont have the OS on them, they rely on the I386 folder to gather info about the computer and then restores it to the state when it was new.
If you can acess the system, reboot and go into the bios and change the boot sequence to CD, then insert the first recovery disc. then save the settings and the computer will reboot and start the recovery process again, this should clear up the error.
If it does not it will be because the i386 folder is missing in which case you can either explore the recovery discs for it or you will have to buy a copy of Windows XP.
Aug 11, 2008 | Toshiba A105-S4054 Notebook
Computers & Internet Logo
David Payne
David Payne
