Question about Vivitar 70-210mm f/2.8-4 for Nikon AFD
Vivitar lens 70-210
I used my 70-210 on a minolta xg7 / now I would like to use it on some new digital camera/ what camera will my Vivitar 70-20 fit.
  • Bowke Nov 30, 2008
    I also have a Vivitar 79-210mm 1:4.5-5.6 MC auot focus zoom which I use on my Minolta Maxxum 3xi 35mm camera. I also want to change to a digital. Is it worth keeping this lens and findinga digital camera which will fit this lens? Thks Ken
5 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: i need the software for Vivitar ViviCam 20 Digital Camera
Like all other Digi camera the provided software is not required to transfer images to a Windows computer
The computer will do this-
plug in the camera set to upload the computer will put up the Camera/scanner Wizard and asked where you want the images to go.
No Software Required
Posted on Feb 19, 2008
bob490527
SOURCE: Quantaray 28-300mm F3.8-6.3 Autofocus Lens for Minolta on digital camera
Try SONY
Posted on Aug 24, 2008
SOURCE: vivitar vivicam 5385 digital camera
wont power on even with new batteries please email m e with suggestions www.aol.com
Posted on Oct 17, 2008
hichama9
  • 65 Answers
SOURCE: Camera lens stuck!
Hello Friend,
First i would let you know that the Brand Vivitar is one of low quality cameras, it's sad but it's true.
Now regarding the issue that you have with the lens, you probably drop it because this the only way to have the lens stuck. but anyway, to repair it it will cost you more than a new one. and again i suggest to buy a branded camera like Canon,Sony,Nikon,Panasonic ... these are top quality cameras and you will not have any problem for life except if you drop it ;)
Best Regards,
Posted on Oct 29, 2009
  • 98921 Answers
SOURCE: using vivitar 70-300 lens
Yes and yes. Bear in mind that not all features may work. You probably won't get autofocus or metering with the Nikon D90, for example.
Posted on Dec 28, 2009
Cross threaded lens on minolta xg7
Take it to a camera repair shop for an assessment of its being worthy of repair.
Aug 03, 2014 | Cameras
Can the Vivitar Series1 28-300mm AF Zoom Lens for minolta Camera fit a canon?
No. Minolta and Canon cameras have completely incompatible lens mounts.
Sep 08, 2010 | Vivitar (218488) Lens
Cameras compatible with Quantaray AF 70-300mm lens
Depending on how new your Minolta SLR film camera was, the lens may or may not work on a Minolta Digital SLR. In many cases, a lens with the correct mount (in this case, a Minolta mount) can be used on the same brand of camera in the digital format.
One thing you should know is that DSLR sensors are, generally speaking, smaller than the size of a 35mm film negative. Long story short, that means that your lens will have a magnification factor on the DSLR. Usually, it is in the range of 150%, so a 70-300 lens from a film camera would cover 105 to 450 on a Digital SLR.
To be sure about the mount, you'll need to seek advice specific to Minoltas -- probably best to take your lens to a local camera shop and see for sure if it fits and what features will work (aperature, auto-focus, etc) and which won't work on the DSLR.
May 31, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Using vivitar 70-300 lens
Apr 10, 2009 | Vivitar Zoom Telephoto 70-300mm f/4.5-5.6...
What cameras does this lens fit?
Vivitar made this lens with several different mounts, including mounts for Canon and Minolta cameras. Your best bet is to take the lens with you to a large camera store. The staff at the store may be able to simply identify which mount your lens has, or they can try the lens on different camera bodies to see which it fits.
Dec 18, 2008 | Cameras
Used on a Minolta Maxxum 800 si
Hello
The Minolta AF lens will fit and work on most of the Minolta AF bodies (it will depend on exactly what lens it is as to the compatibility), you will also find that it will fit and work with the new range of Sony
digital SLR camera bodies.
The Quantaray lenses are a little bit more difficult as Quantaray make lenses for several different types of camera body, it should mention on the lens what make the lens mount is for. If you post further information about the lenses it might help.
Sep 19, 2008 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
Minolta 7000 Maxxum
The Minolta Maxxum 7000 uses a Minolta A mount, which is also used on the Sony Alpha series, as they bought out Minolta's technology. All Maxxum lenses should work for the most part on the Sony Alpha series of DSLR's, including the autofocus.
-John
Sep 15, 2008 | Tamron 28-300mm f/3.5-6.3 XR Lens for...
Compatibility of vivitar lens with Minolta x370
Minolta X 370 is not an auto focus camera so provided you are willing to use the Vivitar lens in manual AND provided the lens has minolta mount , you will be able to use it.
Sep 04, 2007 | Cameras
Vivitar 70-210mm f/2.8-4 for Nikon AFD Logo
293 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
