Question about Miele 24 in. G638 Plus Free-standing Dishwasher
Miele G638 plus what year were they manufactured?
SOURCE: Water leaking from under the machine (Miele G638 Plus) dishwasher
The salt tank is a pathetic piece of ****. The plastic cracks and leaks into the bottom tray, which in turn sets off the safety switch.
Follow the attaching hoses and bypass the salt tank unless you really need it. This will save you around $250 for a salt tank and $300 labour for callout and repair.
Posted on Jun 28, 2009
  • 4 Answers
SOURCE: The G638 finished its cycle but didn't completely
pump maybe on it's way out, though i doubt it, is the washing machine on the same drain out? if so you may have back wash, another could be lengh of drain hose, i had the same problem with my miele dishwasher because of the position in the kitchen i doubled up the drain hose and though it pumped out fine, with the volume of water left in the hose it came back in untill i repositioned the drain hose so it could't run back, hope this helps.
Posted on Aug 05, 2009
caroldon
  • 17129 Answers
SOURCE: My Miele G638 Plus will
It seems to me that the error is a fault in the main program controller unit of the washer.
If the indicator lights are coming ON then the logic of the board seems to show a short or a faulty processor.
It will be good to remove the plug and then get access to open the program controller unit , to see the mother board. remove and plug back all the connectors, if possible take a test voltage of the processor +B and the allied circuits. when the power is applied the processor must start oscillating and show the logic's available,. If not this can be faulty and might need a board swap to confirm.
Make sure the leads to the inputs and drives are not cut or open. Use a multimeter to check the continuity and the voltage to the board.
Posted on Dec 13, 2010
boyrevel
  • 71 Answers
SOURCE: Good morning,i have a miele dishwasher g638
You need to add rinse aid!
There is normally a place on the inside of the door which you unscrew and top up using any Rinse Aid fluid.
Posted on Jan 05, 2011
  • 251 Answers
SOURCE: On my Dishwasher Miele G638
Hi - its possiblily the following issues if its flashing rapidly then the electronic module maybe faulty. The other possibilties are the float switch inside the salt conatner is jammed or the reed switch for the float switch in the salt container does work.
Posted on Jun 15, 2011
G660 door falls open
Hi.
The problem is either because the spring supporting the door half way up is broken or because the spring must be adjusted.
First perform a door spring adjustment procedure as explained at page 28 in chapter 10 of the Installation Manual.
Here Miele installation manual for the G660. The file is in PDF format.
If the regulation procedure does not do the job, then the spring must be replaced.
This video shows how to replace the spring (model and manufacturer are different-operations are similar):
The spring is usually sold as part of the hinge assembly.
To get parts or to book a qualified technician call the Miele support number listed on the owners manual or use the Contact page on your local Miele website. Here UK website: Miele - Contact Us.
Regards.
Ginko
Nov 05, 2011 | Miele 24 in. G638 Plus Free-standing...
Miele dishwaher G638 Sc,,,,Salt PC light is on?
Hi - if its flashing rapidly then there a unrecognized hardware issue -if on permanently - it could be the float switch inside the salt container is not working/jammed - of course theres no salt in the dishwasher container..
Cheers
Jul 20, 2011 | Miele 24 in. G638 Plus Free-standing...
On my Dishwasher Miele G638 Plus, a red light shows up and it says PC salt, I dont know how to solve this, please help me.
May 30, 2011 | Miele 24 in. G638 Plus Free-standing...
Inlet/drain light flashes on miele dishwasher and water will not completely drain away. Model G638l plus help please
the pump is blocked, need to remove the trays, drain plg, the gauze, scoop the water out as much as possible, thge thers a plastic hosing with a spring clip on top, remove this to unblock the pump. assemble & should be good to go.
May 23, 2011 | Miele 24 in. G638 Plus Free-standing...
Aug 03, 2009 | Miele 24 in. G638 Plus Free-standing...
Mar 23, 2009 | Miele 24 in. G638 Plus Free-standing...
Miele G638 CS Plus - Salt PC light flashes and will not run
have you added salt to unit?If so then you have a water intake problem or unit is oversudsing.
Dec 07, 2007 | Dishwashers
Miele 24 in. G638 Plus Free-standing Dishwasher Logo
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
