Question about Kenmore 98702 Stacked Washer/Dryer
Problem with kenmore 97812
Started a wash when it got to spin cycle it just started making a buzzing sound. i took some clothes out and put the lid back down, it filled up again and started making the buzz again. it spins but the motor started making a burning smell.
  • 1937 Answers
SOURCE: Kenmore Series 80 Washer Burning Smell
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts. Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Oct 19, 2009
  • 262 Answers
SOURCE: Kenmore Stackable Washer/Dryer
THIS COULD BE THE MOTOR IF IT IS UNDER WARRANTY LET THEM PAY FOR THE REPAIRS
Posted on Feb 01, 2008
Jimster
  • 240 Answers
SOURCE: Mid-cycle my washing machine stopped working.
Could be one of three issues, timer, capacitor, or the most like canidate the motor assm. Usually 90% of the time, its that motor. Those motors are pretty expensive (part number 389248) and you need to replace motor coupler (part number 285753A) when you change it.
Posted on Apr 26, 2009
  • 109 Answers
SOURCE: series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Posted on Jun 16, 2009
  • 240 Answers
SOURCE: Buzzing sound
does it ever give an error code? a common problem on whirlpool made machines is the dispenser arm getting caught when changing positions. This part is in rear of detergent dispenser housing and uses a motor and a arm to select detergent/ softner/ bleach/ and fill. you can remove top (screws on back) to watch this.
Posted on Jul 05, 2009
Kenmore washer needs two spin cycles
Have you checked the timer? Sometimes the little motor inside of it gets stuck or the concacts become burnt.
Good luck,
Marty
Jun 21, 2014 | Kenmore Washing Machines
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
My washer fills and agitates, but when it gets to the rinse/spin cycle it stops and makes a loud grinding noise. Thanks for your time
If it doesn't drain the water after the wash cycle and the sound is more like a buzz then the first thing that I suggest you check is the lid switch. If the lid switch is damaged then the machine will not pump the wash cycle water out and it will not go into the subsequent cycles. The "grinding" or buzzing sound can be caused by an intermittent signal reaching relay switches or solenoids.
Feb 03, 2011 | Kenmore Washing Machines
My kenmore washer model 110.27802690 will not spin and will not drain the water. the motor will make a humming noise but won't come on. we took all the clothes out and it will now fill up the washer, wash...
Under the lid there should be a small hole with a push down flap and that should be the automatic stop, which can either be a bad switch under the top of the machine or could be a broken trip/ prong on the lid that pushes this button when the lid is dropped. When the machine reaches it's spin cycle time leave it turned on and raise the lid push down on this flap with something careful to keep hands out of the washers tub and see if it works then!
Mar 02, 2018 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore direct drive,will not spin.
Hi, If the coupler is ok, you might have a spin basket drive going bad. You can try and put the machine in spin, put something in the lid switch activator slot and then try and start the tub with you hand.
I hope this helps you. Please let me know if I an assist you further.
Thanks
Vic
May 14, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore SM9711031
ok sounds like you have a bad pump or lid switch. ok i want you open and shut the lid really quick...do you hear a click click. if so your lid switch is good and you have a bad pump. write back when you do this. kelly
Dec 22, 2008 | Kenmore 22422 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
66 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
